Old Apr 20, 2012, 06:05 AM
louiealadph is offline
Find More Posts by louiealadph
Joined Apr 2011
hello guys. just a noobie here.. ive got a prob with my FPV raptor 1600mm .. i use ntm 35-36a 1400kv 550w motor.and its FPV setup. my raptor weight almost 2kg.?? will these motor can go lift trust to this weight?? is the 10x6 prop can fit and use with this plane??how its setup?? i tried 9x6,8x6. still no luck.. hope somene help me..
louiealadph is offline Find More Posts by louiealadph
Old Apr 20, 2012, 09:06 AM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
That motor has way to much power for the raptor..You won't get much bigger than a 8" prop on the plane
cody069 is offline Find More Posts by cody069
Old Apr 20, 2012, 02:24 PM
seedo is offline
Find More Posts by seedo
Plane crasher
seedo's Avatar
Joined Jun 2007
no that motor is perfect, but much modding required and dremeling
http://youtu.be/E8odThPWKpY
seedo is offline Find More Posts by seedo
Old Apr 20, 2012, 06:07 PM
Joined Apr 2011
yeah..more mod i modify.. i put some extension on it..so that the 10 size prop will fit... now my question is,,will my raptor lift at 2kg setup with this prop??hope someone helps.thnx!
Old Apr 20, 2012, 06:09 PM
cody069 is offline
cody069's Avatar
Joined Dec 2008
IT will fly...Might start to be a bit of a flying brick, you will have to fly a bit faster to keep it from stalling
Old Apr 21, 2012, 02:09 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
if you have flaps on it will not stall
Old Apr 21, 2012, 03:06 AM
cody069 is offline
cody069's Avatar
Joined Dec 2008
All aircraft can stall..Flaps or no flaps
Old Apr 22, 2012, 05:26 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
am talking as my specs
Old Apr 22, 2012, 07:56 PM
Rick B is offline
Find More Posts by Rick B
Always looking towards the sky
Rick B's Avatar
Joined Nov 2005
Did yall have problems with the plane climbing? I am using one 3,2200- Zippy. Even when coming by on a low pass i am constantly holding down to keep the nose level. I did add some lead weight but didn`t help much. Surfaces all even and level. When i go WOT from idle it will go down for a sec. until i react to it. May hook 2, 3 cell 2200`s in parallel to add weight. Need opinions. thanks
Rick B is offline Find More Posts by Rick B
Old Apr 23, 2012, 02:57 AM
seedo is offline
Plane crasher
seedo's Avatar
Joined Jun 2007
your battery is too light for the plane so its tail heavy but another battery or wights or a bigger battery, i use 4000mah 3s battery and its great.
Old Apr 23, 2012, 04:54 AM
julupanter is offline
Find More Posts by julupanter
Joined Jan 2012
I use a 35-42 1450kv and 650w... yes, pretty big, but flies very well. I use 2 2200 3S batteries, and the balance is perfect, the only problem with this setup is that i cant hand launch it, but its no problem, since I take off from every surface without a landing gear , only tape.
And as seedo have said, if you have flaps on you could fly slow, but without them, you need to have some speed.
Saludos!
julupanter is offline Find More Posts by julupanter
Old Apr 23, 2012, 06:51 AM
ivanhoes is offline
Find More Posts by ivanhoes
Marburg/Germany
Joined Jul 2007
Saludos!
How did you mount the motor? Could you give as some pictures?
ivanhoes is offline Find More Posts by ivanhoes
Old Apr 23, 2012, 11:14 AM
Joined Apr 2011
Guys! how about if i will use the 3 bladed prop. 8x6 3 blade prop?? and a 4s bat? will these add more power?? i check the web on h-king and i found tsome good motor to use...now im finding what motor to be used without modifying its mounting.. these is my choice that i found..can anyone give me idea. what is the best option to choose.
My setup will go around 2kg - 2.5 using fpv raptor 1.6m and can soon fit on 2m..
hope someone give me.what is the best. that ALREADY TESTED AND PROVEN.
these my options..
on NTM series.
http://www.hobbyking.com/hobbyking/s...00kv_560w.html
http://www.hobbyking.com/hobbyking/s...00Kv_875w.html
http://www.hobbyking.com/hobbyking/s...50KV_310W.html
and for turnigy.
http://www.hobbyking.com/hobbyking/s...dProduct=19038
these are my option.. i want to use 3 bladed props.at 8x6 size.. and i will use my esc, 55a turnigy trust. and i want some advice also.what is the best esc. if i use 4s battery. hope someone help me..
Old Apr 23, 2012, 02:01 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi guys, today I made my maiden.
It is 1.75 kgs with fpv gear. I really impressed with its flight character.
I opened a small air inlets for cooling ESC. Name: ImageUploadedByTapatalk1335203641.881154.jpg
Description:
First of all I learned it does need flaps ( I have)
I like ....
Very easy for hand lunch.
Fly fast with stock motor and prop and climbs very well.
Stable in landing and does not stall easily.
I dislike
Stock Esc
Stock motor ( vibrates much)
Rudder connection is weak damaged after landings. Name: ImageUploadedByTapatalk1335203780.092359.jpg
Description:
Can anyone advice me the best way to repair and strengthen it?
(should I put hinge or just band it?)
Firatp is offline Find More Posts by Firatp
Old Apr 23, 2012, 05:02 PM
cody069 is offline
cody069's Avatar
Joined Dec 2008
I cut the angle of the rudder more on the bottom , about 20 mm up at tip.
Stops it touching the ground
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Discussion Skywalker or Lanyu FPV Raptor? alishanmao FPV Talk 141 Dec 27, 2013 09:49 PM
Discussion New home of Trappy's "Ultimate Zephyr FPV Build" Thread timnilson Other Websites 19 Mar 21, 2011 04:58 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
Raptor - how to install thread malcolmm 3D Flying 1 Jan 15, 2005 06:29 PM
