Old Jul 29, 2011, 06:29 AM
Dekker is offline
Find More Posts by Dekker
Dekker's Avatar
Delft, Netherlands
Joined Jul 2001
I am going to try them too:
The 4x4000mAh packs are going into my Voodoo 600 heli as 2x10s packs.
The 5000mAh packs are going into a Logo500 6s setup.
Dekker is offline Find More Posts by Dekker
Old Aug 06, 2011, 08:14 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
5300 30c
I thought you all might be interested in the IR of new vs. well broken in packs. To measure IR I used my CellPro 10s at a 1C charge and the temperature was in the mid 70ís.
New out of the box
Pack 1 - 4s 5300: 1.6, 1.5, 1.6, 1.3
Pack 2 - 3s 5300: 1.5, 1.9, 2.7
After 3 weeks of fairly hard flying (maybe 20 to 30 cycles?)
Pack 1 - 4s 5300: 1.2, 1.1, 1.2, 1.0
Pack 2 - 3s 5300: 1.1, 1.0, 1.7
They definitely perform better after properly broken in. I made about 5 easy flights for breakin.
RC Man is offline Find More Posts by RC Man
Old Aug 06, 2011, 09:15 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Tell me it ain't so!
That is one of my sermons that few have taken to heart over the years. It is a shame so few can read and understand a graph as I have clearly shown the increase in performance long before anyone much started to take IR readings.
Charles
Old Aug 06, 2011, 12:43 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Great info, rcman. I usually do 1 to 2 soft flights as break-in. Good to know that it'll pay off.
dude_109 is offline Find More Posts by dude_109
Old Aug 07, 2011, 03:05 PM
Mieciu is offline
Find More Posts by Mieciu
Poland
Joined Feb 2011
Today I tested my Gens Ace 2200mAh 25C 3s1p pack. Below is their 1st cycle discharge test at average ~21Amps
Average voltage 10.99V and capacity 2181mAh gives ~24Wh of energy. Much better than my equal size zippy/turnigy/rhino packs
Now charging to ~2300mAh.
According to previous posts their performance improves over time (first ones are weaker than 5th-10th) We will see.
Next cycles soon.
Mieciu is offline Find More Posts by Mieciu
Old Aug 07, 2011, 04:06 PM
Mieciu is offline
Poland
Joined Feb 2011
2nd test:
2193mah with average voltage 11.15V under ~21A gives 24,4Wh
My smaller discharge station (300W max):
2nd cycle results:
I'm closer to build my hotliner - these will be goooood lipos. I have never seen >11V average voltage for 3s pack under almost 10C discharge rate. Forgot to say that the IR of my pack is just 8mOhm (measured with iCharger106B+)
Next I will try to push the limits with constant 40-50A -need to rebuild my bigger discharge station.
This will simulate the power consumption in the air during 100mph flight
Old Aug 07, 2011, 05:44 PM
Southern Pride
GensAce 3S 2200 at 10-50A CC discharges in 10A steps along with other test.
http://www.rcgroups.com/forums/showthread.php?t=1283407
Old Aug 09, 2011, 02:15 AM
Mieciu is offline
Poland
Joined Feb 2011
cycles 3 to 5 exactly the same: 2200mAh under ~21Amps with average voltage 11,15-11,17V.
Old Aug 09, 2011, 08:45 AM
dude_109 is offline
dude_109's Avatar
Houston, TX
Meiciu,
So does that mean 5 soft break-in cycles is unnecessary and 2 to 3 is sufficient?
Old Aug 09, 2011, 09:02 AM
Southern Pride
These break-in conditioning discharges really should not be taken so deep. It is not good to discharge over 80% of capacity.
Yes I know most all of my LiPoly test show discharges past this point but remember I am testing and do not expect these LiPolys which I test to last nearly as long as one I would only be using under normal conditions.
Charles
Old Aug 09, 2011, 05:07 PM
Mieciu is offline
Poland
Joined Feb 2011
dude109 - only 1 break-in cycle is enough, then you can (ab)use them.
everydayflyer - agree unless you start to compete with others :P
Old Sep 02, 2011, 05:18 PM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
I have a few Gens ace 25C packs. The wires exit the packs at really awkward angles. Is it ok to cut the covering to allow the wires to move?
like2fly! is offline Find More Posts by like2fly!
Old Sep 02, 2011, 05:33 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Rather than that, do like the suggestion in Post #24 above. Works very well.
Harry D is offline Find More Posts by Harry D
Old Sep 02, 2011, 06:19 PM
RC Man is offline
United States
Joined Feb 2001
Thatís the only thing that I donít like. Thereís not always room to bend it over the pack and tape it down. For some installations you have to trim a little from the end covering so you can bend it out straight.
I sure hope they fix that problem for the next batch. Does anyone know if the manufacturer is aware of what a pain it is for customers?
Old Sep 03, 2011, 02:10 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I hope they don't change the design, the Gens ace packs are today among the best in construction and design, wires exit like that makes it good, becas you can secure the wires within the pack at the terminal ends.
I fly and test a lot of planes all sizes, i can't say that a pack with this design has ever been a problem to me, my guess is that if they change it so the wires comes out in another way... there would be people having problem with that also.
You don't have to be so careful with the wires (bending/ pulling....) as for example a HC pack, were the wire can fall off just by looking at it its no problem if you have to bend the wires on Gens ace packs some to make it fit in your model.
Jocke is offline Find More Posts by Jocke
Discussion Gens Ace batteries from Hobbyparts Melnic Batteries and Chargers 66 Aug 18, 2012 07:56 PM
Rave Gens Ace Batteries :) lazor 22 Electric Heli Talk 7 Aug 06, 2011 10:39 PM
For Sale Multiple LiPo Batteries FlightPower- EM -Gens Ace!!! (New and Barely Used) Wattsup23 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Jun 10, 2011 01:25 PM
Discussion Many Lipo Batteries Back in Stock! Sky Lipo + Gens Ace maarset HobbyPartz.com 2 Apr 05, 2011 04:04 PM
Discussion Nitroplanes 10% all gens ace batteries nitrojohn Nitro Planes 1 Nov 23, 2010 03:11 PM
