Old Sep 02, 2003, 04:11 AM
dimple is offline
Find More Posts by dimple
New Zealand, Auckland
Joined Feb 2003
How to install torque rod for top-hinged aileron made of solid balsa
Hi I am building a small electric plane with solid balsa aileron sanded to shape and is top-hinged to the rest of the wing. What is the best way to install torque rod so that its axis of rotation is well in line with the hinge line?
dimple is offline Find More Posts by dimple
Old Sep 02, 2003, 10:56 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
The torque rod should be bent at 90 degrees on the aileron end. The bent end should fit into a matching aluminum tube imbeded in the aileron so that the bent end can slide in and out of the tube a little. Try to get the axis of rotation of the torque rod close to the axis of rotation of the aileron and let the bent end slide in and out of the tube to allow for misallignment of the two axes.
Ollie is offline Find More Posts by Ollie
Old Sep 10, 2003, 08:19 AM
Terryoc is offline
Find More Posts by Terryoc
Melbourne Australia
Joined May 2003
I make molded wings that are all skin hinged the torque rod end is glued into the aleron as per normal but the torque rod is only supported close to the servo arm so most of the torque rod can float in the wing with the movement of the aleron . Work great for me in pylon models
Terry
Terryoc is offline Find More Posts by Terryoc
Discussion How much torque needed for different servo applications? infopimp Slope 10 Apr 25, 2006 06:53 PM
Discussion How to install the grip set for blade cp??? SteveCH Micro Helis 9 Feb 25, 2006 03:21 PM
torque rod how to for a light lift pss scratchbuild windsox Slope 11 May 25, 2004 08:57 PM
GWS Zero Aileron Torque Rod carguy Parkflyers 8 Oct 19, 2002 06:58 AM
Aileron Torque Rod Connections Gene Bond Parkflyers 11 Aug 14, 2002 10:29 PM
