Its a ziped html document (webpage) that can be opened with your web browser. Tries to be the more "graphicly" possible (1 image = 1000 words) ![]() At the begining I identify all the telemetry data and malformed blocks , but after a while i only identify the malformed blocks. Tell me what you think. |
Poole, England
Joined Mar 2008
I think that if you rescan the data you have in this way the data packets are OK. Mike. |
Poole, England
Joined Mar 2008
Since currently the only hub values displayed are temperature, altitude and RPM, I will convert temp from C to F, and altitude from metres to feet, RPM is the same .I'll consider other values as they are added to the display. Mike. |
EDIT : If the count says by example 6 , this are 6 bytes AFTER the packet secuence byte or does this 6 bytes INCLUDE it (so there are realy 5 useful bytes realy) ?? EDIT of the EDIT , should be "6 bytes AFTER the packet secuence byte" as I visualy rescaned and did not find any malformation. Thanks a LOT !!! |
Joined Aug 2006
I still don't know if I need the hub since you did such a great job of adding the WS HHigh sensor option, but having the hub will let me add features as the need comes up. Having alarms tied to altitude and fuel level would be great for my field and nitro flying. Some thoughts, It may be that these requests max out the display screen and memory of the 9x? Having no idea of how you, and others are able to make these great additions, I'll mention it anyway. One idea on speed measuring when and if that's added would be a max hold if posable? It may end up that I'll/we'll need a er9x for most flying and another er9x 9x with a Frsky display/alarm setup for more telemetry if the 9x gets maxed out with so many feature requests. SM |
Poole, England
Joined Mar 2008
FrSky RPM Sensor
I was flying with the FrSky RPM optical sensor fitted last Sunday. It was bright and sunny. Much of the time the RPM reading was 0.
I had previously tested the sensor in my back garden. Again it often did not read when there was a dark background. It appears that this sensor has trouble with extreme lighting conditions, i.e. quite light and quite dark. Has anyone else tested/seen this? Mike. |
But it was curious that I was not recording ANY packet corresponding to the rpm sensor in my setup . The other 2 sensors (and some more that I dont have ) were sending packets regularly . Need to redoo my routine , not enough free time now .Maybe tonight I can confirm it to you. |
Poole, England
Joined Mar 2008
If you select WSHhi (set to feet) and imperial I think you will get incorrect values displayed, the option is for the hub. I may need to improve this, but it is a start. There are no alarm settings (yet!!??). Mike. |
I tried to buy the Rotorvane kit a few years ago. Clever idea that one ![]() Sorry for the OT post Martin |
Joined Aug 2006
SM |
Italia, Veneto, Padova
Joined Aug 2007
display
hello all
currently use a module tx frsky (V8FT) and to D8R-II RX. Now I would like to know if there 'a chance to have a display with the telemetry. I have to replace the TX module with the new form DHT-U? I would not want to spend some more money for a new module TX .... Bye Umberto |
France, RA, Échallon
Joined Mar 2009
DHT-U issue in V8 mode ?
Hello everybody
I have a strange issue with my DHT-U module when I try to use V8 receivers. When I want to bind the receiver, I put on the TX, then I select V8 mode and Bind in the menu. Then I put on the RX with the bind/failsafe switch toggled on The receivers LED blinks quickly so the bind procedure looks all right. But when I put off the RX an TX, then put ON TX, select the V8 normal mode, and then put on the RX, the led flash slowly = no signal I tried differents orders in binding procedure, but with no success. BUT in D mode everything works flawlessly. I was able to use D8R with updated firmware, D8RV2, D8R-II, and D4FR I also have a DJT module and I can bind the V8 receivers without problems. Have I done something wrong, or do I need to replace my DHT-U module ? |
| Thread Tools | |
| Discussion FrSky 2.4ghz - Telemetry protocol discussions | PLMS | Radios | 1370 | Apr 24, 2013 12:58 AM |
| Discussion FrSky 2.4Ghz - Telemetry PDA application | Mybrains | Radios | 18 | Jun 23, 2011 09:02 AM |
| Sold FrSky Telemetry 2.4Ghz for JR Module, 2 RXs & extra | nizee | Aircraft - General - Radio Equipment (FS/W) | 1 | May 07, 2011 02:28 PM |
| Wanted FrSky 2.4Ghz DIY Kit with Telemetry | purcilas | Aircraft - General - Radio Equipment (FS/W) | 5 | May 04, 2011 04:10 PM |
