Old Aug 15, 2011, 06:47 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Originally Posted by Skree View Post
could this also be done to an eagletree type inline brushless motor speed sensor to replace the optical sensor? we really need that BL RPM sensor. designing/building an interface is way beyond my skills though. i'll have to hope frsky make such a sensor or someone with the skills does a interface
If the Eagletree BL rpm sensor has a regular squared up pulse output (one per rpm) then it might work with no real effort. It would be a matter of matching the signal level and supplying the right sensor power voltage if not right. Certainly could be possible...
PLMS is offline Find More Posts by PLMS
Old Aug 15, 2011, 07:25 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Yep that's what I meant, I would appreciate a picture . Thanks PLMS!
Originally Posted by PLMS View Post
I see nobody answered this one (unless I missed it). If I get you right, yes if you use a DHT-U you need to get power and PPM signal from the module pins on the back of a module type TX, and wire it to the DHT-U.
You could use a 5 or 6 pin header plug for a few cents from a DIY electronic store instead of hacking up an old TX module.
If that sounds like what you asked, I can try find a picture of what I mean ?
Martin
msev is offline Find More Posts by msev
Old Aug 15, 2011, 08:33 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
OK, a quick picture or four. Sorry it's not as sharp as usual, my macro lens is off the camera at the moment.
The first two pictures are of the first matching size plug I laid my hands on to show you tonight. It's a standard 3.5" floppy drive plug ratted from a PC power supply. I bet you can find one around somewhere.
Only four pin plugs are needed (three connections to DHT-U only though), five is nice but one pin can hang in the breeze if it's all you have available. The colors shown are NOT in any significance for the job, just swap them around to suit (Red for Battery, Black for GND, Yellow for PPM etc etc). The plug pins (sockets) can be removed by pressing the barb on the side of the sockets while pulling the wire very gently. Reopen the barbs, then insert in the right order for JR or for Futaba....
The second pair of photos is a plug ratted out of a Toyota Soarer EMV, just happened to be nearby. I also often find them in old DVD players or even old VCR's. I bet you have one somewhere to open up and rat out
Martin
Old Aug 15, 2011, 08:52 PM
Chase Wu is offline
Find More Posts by Chase Wu
Joined Mar 2009
FrSky new sensors
FrSky lipo voltage sensor will be released quite soon, which can monitor voltage for each cell. Amperage sensor and RPM sensor for brushless motor will follow.
Chase Wu is offline Find More Posts by Chase Wu
Old Aug 16, 2011, 03:51 AM
michel49 is online now
Find More Posts by michel49
Joined Jul 2011
Do that quickly Mr.Wu, Corona is a threat...
michel49 is online now Find More Posts by michel49
Old Aug 16, 2011, 05:04 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
Corona a threat ? I must have been asleep lately...
They failed my last testing.
Martin
Old Aug 16, 2011, 09:02 AM
Joined Jul 2011
http://www.hobbyking.com/hobbyking/s...DplusCR8FD.jpg
Old Aug 17, 2011, 03:27 PM
Mike Blandford is offline
Find More Posts by Mike Blandford
Poole, England
Joined Mar 2008
I've investigated the temperature sensor for the FrSky hub. It appears to be a 100K (at 25C) thermistor. I found a spec of a 100k thermistor I could buy, it is
at 25 C: 100kΩ
at 100 C: 4.77kΩ
at 0 C: 352.4kΩ7
so I wired 100K to the pins and got a reading of 25, 4.7K and got a reading of 102, and 330K and got a reading of 5, so this looks to be the sort of thermistor to get if you need a replacement or extra sensor.
If anyone has any info on any of the other sensors please post it. In particular I would like to know what the electrical interface to the vario (altitude) sensor is. At 1 metre resolution this is not very useful to detect lift or sink, but could we amplify the signal from the sensor. I don't want 9999 m altitude, I'd be happy with 1999 m altitude with a resolution of 20 cm, then we could detect lift and sink with it.
Mike.
Mike Blandford is offline Find More Posts by Mike Blandford
Old Aug 17, 2011, 07:53 PM
Charles B is offline
Find More Posts by Charles B
Old retired Electronics Fart
Charles B's Avatar
United States, OH, Centerburg
Joined Mar 2007
there is two three pin chips that take 5 volts in and has an output of
Linear +10.0 mV/C scale factor
This LM35 is 1mv per degree C.
Linear +10.0 mV/F scale factor
The LM34 is 1mv per degree F
So at 100F the LM34 output is 1.00volts
and at 100C the LM35 ouput is 1.00 volts.
Charles B is offline Find More Posts by Charles B
Old Aug 17, 2011, 09:40 PM
Nobert is offline
Find More Posts by Nobert
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
The Eagle Tree RPM sensor works on 3-5volts.
Neal
Nobert is offline Find More Posts by Nobert
Old Aug 17, 2011, 10:13 PM
ssatoru is online now
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Altimeter sensor is Bosch BMP085 according to PLMS's post. It is digital with I2C interface. I am trying the sensor with Arduino, it reads less than 1m but requires processing, at least filtering to get stable reading.
I am curious what FrSky hub processes this sensor input. If it already filters and sends altimeter value in meter, it may not be optimal for variometer use. On the other hand, I am flying How High RT telemetry for a few months as vario. It sends altimeter value in meter at only 2 times per second but it is usable as vario (though calculated audio vario sound is not smooth.)
Satoru
Mike.
ssatoru is online now Find More Posts by ssatoru
Old Aug 18, 2011, 04:12 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
Yep that one...
Old Aug 18, 2011, 04:22 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
That may be true. We don't know how they setup the sensor or filter it.
Both Renato and myself have tried a few things to get the best out of the sensor. Even with the internal oversampling turned on and some external averaging of the out we found that 1m resolution and 1m/s rate of change was the best we got. Unless Renato has improved the PIC code since then...
I think we both concluded that it was good enough for the job though, and considering the much simpler circuit and no adjustments needed (or calibration) I still would use it again.
I've done many analogue sensor designs, and got good results usually, but by heck the R&D time was FAR longer to get the circuits optimized and repeatable...
Martin
Old Aug 18, 2011, 04:30 AM
VHO is offline
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Satoru
Have been using How High RT set to feet = 0.3m sensitivity as a vario with voice output around a threshold setting. Works well, and it doesn't need the FrSky Hub..
VHO is offline Find More Posts by VHO
Old Aug 18, 2011, 04:48 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
Hi Hutton. That sounds fairly good. Is the voice output something you home brewed ?
PS. You flying FrSky these days ?
Discussion FrSky 2.4ghz - Telemetry protocol discussions PLMS Radios 1439 Nov 19, 2015 02:56 PM
Discussion FrSky 2.4Ghz - Telemetry PDA application Mybrains Radios 18 Jun 23, 2011 10:02 AM
Sold FrSky Telemetry 2.4Ghz for JR Module, 2 RXs & extra nizee Aircraft - General - Radio Equipment (FS/W) 1 May 07, 2011 03:28 PM
Wanted FrSky 2.4Ghz DIY Kit with Telemetry purcilas Aircraft - General - Radio Equipment (FS/W) 5 May 04, 2011 05:10 PM
