Old Feb 11, 2013, 04:39 AM
frasenci is offline
Find More Posts by frasenci
Chile, Bío-Bío, Cabrero
Joined Dec 2004
Originally Posted by renatoa View Post
No luck for you, no more serial output in DHT-U, because was considered is no more needed.
Ok, that would be it for so called "open system "....
I have read so many pages on the subject and suddenly all is not was it seemed to be.
I will not , not that I do not have the ideas to do so , but argue with Frsky how they came to this conclusion ( leave out serial output code ) ...
but, how is one going to use the Frsky monitoring software/and used to set alarms, wich I have seen demoed in Video ?
The DHT-U is doing his original job in my case , I am upgrading to Frsky for my RC Helicopters so no lost in that. DRIIPlus receivers..., Lipo monitoring
Would the DIY Kit TX ( no screen ) still have serial out ? , I would be willing to by one for this other particular purpose.
All in all, very disapointed, Frsky, you cut my wings in half...
Thank you for your prompt answer Renatoa
Greetings from Chile
frasenci is offline Find More Posts by frasenci
Old Feb 11, 2013, 05:34 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I think this behavior was described in many places in the main Frsky thread, not sure if here.
Because DHT-U does everything you needed before to do connecting the module to a PC: you can set all alarms, record data for after the flight analysis, etc.
see above, no more need for PC
Yes, because the module itself has no means to set or display anything
Sorry to hear this, but I think they designed DHT-U (which is the last module on the market) with other target customer in mind, to make the things as simple as possible for him.
renatoa is offline Find More Posts by renatoa
Old Feb 11, 2013, 05:54 AM
frasenci is offline
Joined Dec 2004
Ok , thank you for prompt answer Renatoa.
I guess, after going trough so much pages I have miss it...
Agree, on second tought, DHT-U does not need a PC in its original target function. Still, no see the economy on leaving it out,,,,,, ( uProcessor load ??)
I just got too enthusiastic after discovering the implications of an serial output,.... will order the DIY Tx kit for this other , non RC applications,..... I want to remotely monitor my Basic Home DIY Solar Panel install...., Voltages,temperatures,.... wich I must postprocess to calculate power etc....... and , on the most part.... just for the fun of it !!!
An empty Rx,Tx Pin will always make the immagination of one tinkerer like me go fly...
Great product Frsky I think, anyway !!
Greetings
Old Feb 11, 2013, 06:56 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
A1 voltage
One question:
I have 9x radio, DJT, FLD-02 display.
D8R-II plus, sensor hub, amp sensor, altimeter and cell voltage sensor. Turnigy 5A switching bec supplying the power.
All are supposed to be pretty late revision from Hobbyking. I have not flown yet but already finished the setup. All sensors and data works as advertised out of the box without issues.
One anomality though: I have the hub connected to the rx via the supplied data cable. No other telemetry connections to the rx. All sensors are connected to the hub. When I power up the plane the A1 voltage reads like 4.7V Then it starts to slowly creep up. I was setting up the plane one day and noticed what the hell, the A1 reads 7.4V! I measured the BEC output and it is rock stable at 4.97V. Amp draw on telemetry was approx 0.6A from radio gear and six smallish servos. I this common?
B12 is offline Find More Posts by B12
Old Feb 11, 2013, 09:35 AM
frasenci is offline
Joined Dec 2004
Originally Posted by B12 View Post
One question:
One anomality though: I have the hub connected to the rx via the supplied data cable. No other telemetry connections to the rx.....?
Dear,
Sensor Hub needs 2 (two) connections to the Receiver , i.e. 1.- Power ( Red-Black) and 2.- Data ( Yellow-Black)
Please check
Greetings
Old Feb 11, 2013, 10:16 AM
B12 is offline
B12
B12
Finland
Joined Sep 2010
I forgot to mention the hub is powered by the rx/bec like in the picture. Hub does not work without external power.
Edit: It seems the problem is solved. I connected the RX A1 and x-pins with supplied jumper. Now the telemetry A1-voltage is solid 5.0V.
Old Feb 11, 2013, 10:56 AM
frasenci is offline
Joined Dec 2004
Ok, attached 2 detail pictures from mine.
For the inner voltage of the reveiver to be transmitted , the Jumper on A1 must be in position
Hope you solve it
Greetings
Old Feb 11, 2013, 11:09 AM
B12 is offline
B12
B12
Finland
Joined Sep 2010
Yep the jumper solved it.
Old Feb 13, 2013, 04:04 PM
pegase is offline
Find More Posts by pegase
France, IdF, Villeparisis
Joined Jul 2003
seems Frsky will release two new vario sensors. One common FVAS-02-C and one high accuracy FVAS-02-H.
http://www.my-rc.ch
Peg@se
pegase is offline Find More Posts by pegase
Old Feb 13, 2013, 07:58 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
http://www.my-rc.ch
Peg@se
Yes, that is correct. I thought that was public knowledge?
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Feb 15, 2013, 01:57 AM
pegase is offline
Joined Jul 2003
-Wayne
I thought the common was the old FVAS-01.
Do someone knows more about the differences beetween FVAS-02-C and FVAS-02-H ?
Do they share the same hardware ?
Peg@se
Old Feb 17, 2013, 04:21 PM
Bruneaux is offline
Find More Posts by Bruneaux
Bruneaux's Avatar
United States, AR, Morrilton
Joined Feb 2013
FrSky Vario's
I like the thought of a vario and I bought the complete package with the Futaba module, display, hub, vario (really it is a altimeter), temp, etc. Having real time data from the model as awesome.
But the vario is not a real vario. It is just an altimeter. I here that there is a new version (FVAS-02-H?). I would really like to see the display reading +/- differences rather than an altimeter. And (yes, I wish) a total energy vario would be awesome. I'm looking at ways to make one and hook it to the hub.
Wayne, when will the FVAS-02-H be out and is a vario or an altimeter? Should I wait for it (flying time is still months away for me)?
Bruneaux
Bruneaux is offline Find More Posts by Bruneaux
Old Feb 18, 2013, 01:13 AM
renatoa is offline
Joined Sep 2007
You can see even in your vario the difference, as the vertical bar graph right to the altitude.
V2 features a DA pin, which outputs a voltage variable with the ratio, centered around 1.65V. You can build/buy a tone generator, or connect this pin to A2, and use the 3 alarm tones to make an approximate scale.
Old Feb 23, 2013, 04:55 PM
Locutus is offline
Find More Posts by Locutus
Joined Aug 2006
Originally Posted by TonkTonk View Post
My FLVS-01 has finally arrived!
However, I've had no success with reading the information from its serial out from the arduino yet.
I guess it's the concept opto coupling which has got me puzzled, is the wiring not as simple as
FLVS-01 DataOut (Black) -> Arduino GND
FLVS-01 DataOut (Yellow) -> Arduino SoftwareSerial RX Pin?
Any pointers as to what I'm doing wrong? Thanks
i tried the same with the same result here. Did anybody had any success in reading data from the new bus?
Locutus is offline Find More Posts by Locutus
Old Feb 23, 2013, 05:06 PM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
You need a pull-up resistor on the processor side due to the optocoupler. FrSky's website has a PDF describing the protocol for the FAS and FLVS, this has a connection diagram too.
Kilrah is offline Find More Posts by Kilrah
Discussion FrSky 2.4ghz - Telemetry protocol discussions PLMS Radios 1472 May 15, 2016 05:38 PM
Discussion FrSky 2.4Ghz - Telemetry PDA application Mybrains Radios 18 Jun 23, 2011 09:02 AM
Sold FrSky Telemetry 2.4Ghz for JR Module, 2 RXs & extra nizee Aircraft - General - Radio Equipment (FS/W) 1 May 07, 2011 02:28 PM
Wanted FrSky 2.4Ghz DIY Kit with Telemetry purcilas Aircraft - General - Radio Equipment (FS/W) 5 May 04, 2011 04:10 PM
