Old Aug 01, 2011, 02:28 AM
showmaster is online now
Find More Posts by showmaster
showmaster's Avatar
Joined Aug 2006
The telemitry race is on
FYI
Look up Spektrum STi.
Interesting.
showmaster is online now Find More Posts by showmaster
Old Aug 01, 2011, 02:33 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Spektrum, not interesting
renatoa is online now Find More Posts by renatoa
Old Aug 01, 2011, 07:36 AM
danitaly is offline
Find More Posts by danitaly
Joined Jul 2011
PINs Futaba 3 PK and 3 PKS
I found this important topic regard Futaba 3 PK (or 3 PKS) usage
http://www.rcgroups.com/forums/showthread.php?t=387442
this link with Manual_DHT-U provides a very important help to connect DHT-U display and futaba 3 pk.
So, thank your answers and thank this forum, in general I solved all my doubts.
I would like only to know if I could use Airtronics or Eagle Tree rpms sensors with frsky hub. Is there anyone tested rpm sensors NOT frsky?
Thank you
danitaly is offline Find More Posts by danitaly
Old Aug 01, 2011, 10:38 AM
showmaster's Avatar
Joined Aug 2006
I agree with you that Spektrum it's self is not, but...
Telemitry info sent to a iPod or iPhone to me is.
Endless audio alarms, voice , tones, sound effects, ect.
Record all flight info, gps data for playback later. With Internet access even track using google maps, find lost planes fast.
Maybe something Frsky would want to explore for a future product?
Takes the burden off of the main radio link.
I mentioned it here more for the technology concept then to focus on a brand of radio since some are disappointed with Frsky's latest telemetry product offerings.
Exciting times to be in our hobby, both for the flyers, and the technology smart flyers like yourself.
Old Aug 01, 2011, 11:02 AM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
So true there Showmaster.....
A10FLYR is offline Find More Posts by A10FLYR
Old Aug 02, 2011, 06:01 AM
danitaly is offline
Joined Jul 2011
Originally Posted by showmaster View Post
FYI
Interesting.
yes interesting, I hope also frSky will develop a similar app.
Anyway, I am faithful to android
Old Aug 02, 2011, 08:29 AM
lothar2048 is offline
Find More Posts by lothar2048
New in all but 20Y hobbyist
lothar2048's Avatar
Gratens, little place around Toulouse...
Joined Dec 2007
Thank you
Tested, opticall sensor from ET working.
Tested Sparkfun optical sensor and working too.
Tested GPS from ET working.
Tested GPS from flytron, working too, but needs to be set @ higer speed.
Optical sensor port is only sensing 2 blades. I'm working with 3 blades pusher ;-)
lothar2048 is offline Find More Posts by lothar2048
Old Aug 02, 2011, 09:29 AM
fireball2k is offline
Find More Posts by fireball2k
Germany, HE, Bensheim
Joined Jul 2011
Ever seen that?
Demo of Android Dashboard for FrSky Two Way modules (6 min 17 sec)
fireball2k is offline Find More Posts by fireball2k
Old Aug 02, 2011, 09:37 AM
dang is online now
Find More Posts by dang
USA, WA, Olympia
Joined Jan 2001
The android app is pretty neat. Hope it gets packaged in such a manner that anyone can try it.
http://projects.onomato.biz/svn/android-dash/trunk/
dang is online now Find More Posts by dang
Old Aug 02, 2011, 02:25 PM
michel49 is offline
Find More Posts by michel49
Joined Jul 2011
I hope something like "Torque" for car telemetry by OBDII...
michel49 is offline Find More Posts by michel49
Old Aug 02, 2011, 02:49 PM
Emoto is offline
Find More Posts by Emoto
Emoto's Avatar
Australia, NT, Anmatjere
Joined Oct 2010
Originally Posted by fireball2k View Post
Ever seen that?
No! never seen that nice, not to distracting would like this for altitude in my thermal glider.
Who knows what we will be doing in a year
Emoto is offline Find More Posts by Emoto
Old Aug 02, 2011, 07:05 PM
Mike Blandford is offline
Find More Posts by Mike Blandford
Poole, England
Joined Mar 2008
How does the FrSky Hub get its power? From PLMS's test jig pics, it looks as though the only connection between the Hub and the Rx is a 2 wire (yellow and black) connection. I'm thinking about adding code to er9x to handle the hub protocol and display on the standard LCD (when time permits!).
Mike.
Mike Blandford is offline Find More Posts by Mike Blandford
Old Aug 03, 2011, 03:49 AM
debianhot is offline
Find More Posts by debianhot
RC Soarer & wheel re-inventer
debianhot's Avatar
Antarctica
Joined Jul 2003
Mike.
There is a power connector on the top-right corner (same as the battery connector in your rx) .
You must power it allso together with the rx.
In the telemetry values that the hub sends there is allso a "voltage" that I supose corresponds to the power aplied to this connector (rendering obsolete/duplicate the internal AD1 that D8R-V2 has to meter the rx volt, if you use it together with the hub).
PS: Just received my hub together with vario , temp and rpm sensors
debianhot is offline Find More Posts by debianhot
Old Aug 03, 2011, 04:39 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
How does the FrSky Hub get its power? From PLMS's test jig pics, it looks as though the only connection between the Hub and the Rx is a 2 wire (yellow and black) connection. I'm thinking about adding code to er9x to handle the hub protocol and display on the standard LCD (when time permits!).Mike.
Sorry about missing that cable in the picture. At the time I took the image I had not fired up the Hub. The yellow/black is the serial data from Hub to RX. The power is connected via a male-male JR servo cable between aby unused servo channel and the Hub where DebianHot said. Only the power wires are used.
If all servo channels are used then you can feed 5V right from the UBEC you're using
Note: The male-male JR cable I later used was not supplied, I made it from two dead servos leads.
Martin
PS. Anyone seen male-male JR extensions on the web cheap ? Hobbyking don't sell them.
PLMS is offline Find More Posts by PLMS
Old Aug 03, 2011, 06:08 AM
lothar2048's Avatar
Joined Dec 2007
Martin
The Futaba ones are in fact JR ones.... http://www.hobbyking.com/hobbyking/s...airs_set_.html
Chinese sometimes don't know what they are selling ;-)
Discussion FrSky 2.4ghz - Telemetry protocol discussions PLMS Radios 1439 Nov 19, 2015 02:56 PM
Discussion FrSky 2.4Ghz - Telemetry PDA application Mybrains Radios 18 Jun 23, 2011 10:02 AM
Sold FrSky Telemetry 2.4Ghz for JR Module, 2 RXs & extra nizee Aircraft - General - Radio Equipment (FS/W) 1 May 07, 2011 03:28 PM
Wanted FrSky 2.4Ghz DIY Kit with Telemetry purcilas Aircraft - General - Radio Equipment (FS/W) 5 May 04, 2011 05:10 PM
