Old Jul 13, 2011, 06:46 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Help!
Stobel RDS failure and repair
My new V3 has a bad RDS. Not the pocket, but something is slipping in the shaft. Not sure if it is slipping at the front end, or the back end.
Anyone have a picture of what it looks like?
What is the best way to get at it to fix it?
Not looking forward to hacking into a 6 week old $1000 airframe to repair something I didn't break
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Jul 13, 2011, 07:12 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
Likely the coupling has slipped off the spline. This happened to Nick's. I fixed it by cutting a little window through the bottom skin, packing the coupling with goop, and shoving it back on the spline. Test it before you close up the window. If you save the piece and glue it back on you will not even see it. I may have posted this in the Stobel V3 thread if you look back a ways.
I also helped Reto do the same thing on his Salpeter. This time he drilled a hole through the coupling and we dripped very carefully small drops of CA into the coupling/spline joint. You have to be very careful not to get CA near the case or it will wick into the geartrain and solidify. A much nastier repair.
All these planes are pushing the stress and space requirements. It is not uncommon to have to fix the RDS. I had to replace a whole servo in a Twister wing and it was not all that bad.
G Norsworthy is offline Find More Posts by G Norsworthy
Old Jul 13, 2011, 07:14 PM
DProseus is online now
Find More Posts by DProseus
Wilson, NC
Joined Jun 2006
Pat MacKenzie
http://www.rcgroups.com/forums/showp...1&postcount=90
This is the only inside look I know of. I used this info with much success to repair my wing when the servo went bad.
Dick
DProseus is online now Find More Posts by DProseus
Old Jul 13, 2011, 07:15 PM
ShadowFalken is offline
Find More Posts by ShadowFalken
Jim C
ShadowFalken's Avatar
Joined Sep 2009
Pat,
Look in the Stobel V3 thread and look for pictures by Jun. He shows in detail how to open the wing and repair the couple if that is what had come loose. Others have had a sevo come debonded I have heard, can be fixed the same way.
With a little care and patience it can be fixed and you will be hard pressed to see it and no impact on performance.
Edit. If I had given Dick another minute I could have saved some typing......
ShadowFalken is offline Find More Posts by ShadowFalken
Old Jul 13, 2011, 07:19 PM
Master of the Wind
Joined Sep 2008
http://www.rcgroups.com/forums/showp...&postcount=490
Old Jul 13, 2011, 07:24 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
An easier way to repair is to split the leading edge. That way you can pop the servo off its glue and pull both the servo and the RDS system out of the wing. After getting the RDS coupler re-attached to the servo you can slip the whole assembly back into the wing and glue it back down in the exact same location that it was before. I have done this after being told about the procedure by proppy jon. It is scary but it works and it is much easier to glue the RDS coupler back on the servo when all parts are outside of the wing.
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Jul 13, 2011, 07:29 PM
pmackenzie's Avatar
Joined Dec 2002
Thanks guys,
So the tubular coupler is just glued to the spline?
Pat MacKenzie
Old Jul 13, 2011, 08:03 PM
dbone is offline
Find More Posts by dbone
Team ATX Pilot
dbone's Avatar
Phx. Az.
Joined Nov 2004
Same thing happen to my new V2, use the method Charlie described and you will never be able to tell. Mine has been work great. Thanks "Proppyjon".
Donnie
Also I use Black rubberized CA on the RDS and to glue the leading edge back.
dbone is offline Find More Posts by dbone
Old Jul 13, 2011, 08:51 PM
jcats is offline
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
The next time my servos fail in these molded planes- I'll try Proppy John/Charlie's method.
RANT: I really don't see why the manufacturers can't mold a servo pocket in these wings! For a thousand + bucks, these planes should assemble and fly themselves!
Jun
jcats is offline Find More Posts by jcats
Old Jul 13, 2011, 10:23 PM
TomK is offline
Find More Posts by TomK
Tom Knudtson
United States, CA, Redlands
Joined Aug 2004
Thanks guys,
Pat MacKenzie
Yes. The torque tube to servo connector appears to be be just a short piece of Al tube. The Al tube fits over the servo splines. IIRC it appeared to be epoxy in the Al tube.
Here are two pics of the torque tube.
I have made two aileron mechanism repairs. One was due to failed bond between the Al tube coupler and and servo splines. Using a strategy proposed by Thomas Cooke, I was able to split the leading edge and re-glue the coupler to the spline. The other one failed because the top to the servo case cracked and the servo had to be replaced using the Jun's "surgical procedure". (I only had to replace the top of the servo case, so the wiring stayed intact.)
TomK is offline Find More Posts by TomK
Old Jul 13, 2011, 10:25 PM
ROOSWH is offline
Find More Posts by ROOSWH
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
Twister Repair
On my Twister, the steel wiper was slipping inside the CF Shaft and here is the easy repair I used:
Post my Maurice : http://www.rcgroups.com/forums/showp...&postcount=349
Mine has held up since the fix,
walt
ROOSWH is offline Find More Posts by ROOSWH
Old Jul 14, 2011, 06:37 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Is this problem related to the fact that the RDS shaft uses Aluminum and carbon together? I thought I recall that Gerald said that there can be some corrosion and failure is guaranteed in this instance when glued together. Something about a galvanic response. I do not know but it was some chemical related issue.
would it be better to drive a pin through the shaft and aluminum coupler to attach instead of using glue?
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jul 14, 2011, 06:40 AM
Wave Glider is offline
Find More Posts by Wave Glider
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
I think its the coupler slipping off the spline itself that is the common issue, not the Al/Carbon bond.
Wave Glider is offline Find More Posts by Wave Glider
Old Jul 14, 2011, 09:03 AM
The_Builder is online now
Find More Posts by The_Builder
God Created me to Create
The_Builder's Avatar
Joined Nov 2009
Jun
Even if I could afford a couple of these beauties this would scare me. Jun, has a valid point. My brothers new fly rod was about $500 and has a life time warranty...LOL, LOL
Paul
The_Builder is online now Find More Posts by The_Builder
Old Jul 14, 2011, 10:50 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Jun
You have that opinion because you have never developed and built your own planes. $1000.00 is cheap. If it wasn't, more people would be getting rich building them, rather than lining up to buy them.
Shoot, no one is even willing to try to make their living doing it in the US.
Sorry, rant off and flame on.
djklein21 is offline Find More Posts by djklein21
Discussion Radio Actif (RDS) En production vet été au Québec et partout dans le monde!!! sadva Canada 3 Jul 22, 2011 02:13 PM
Sold post Worlds sale: Stobel V3 double D-box and double disser olgol Aircraft - Sailplanes (FS/W) 3 Jul 14, 2011 03:38 PM
Sold post Worlds sale: Stobel V2 olgol Aircraft - Sailplanes (FS/W) 0 Jul 11, 2011 07:24 PM
Sold Vandal RDS / RTF ewers Aircraft - Sailplanes (FS/W) 4 Jul 06, 2011 08:38 PM
Discussion stobel v3 peter.c Hand Launch 5 Jun 30, 2011 06:37 PM
