so now for the real build:
i'm not a mechanical engineer, so i don't now solid really well- i learned as i went along. i also don't have experience designing airplanes and no experience flying flying wings. all this means that it could have probably been done a lot better. i used the general dimensions from the FFF simple wing and the MH45 profile and completed the design with what looked right. i designed a 2deg wingtip washout- after reading some more, it should probably should have been over 5deg, but it seemed strange to me to warp the wing's shape so much, so i left it as it is. to fit into the printing tray of the printer and to save printing time, i designed the wing in several parts- left and right halves, each of them in two parts. i used the abilities of the software to calculate the expected weight of the design, which after some calibration came out as about 300gr empty weight, and added the motor and battery to the model in order to verify that the CoG will be in the expected place. i want the wing to be relatively slow so i ordered a 1400kv, 30g motor. i intend to use a 8X4 or 7X5 prop and a 1000mAh battery. i hope to print it over the weekend, and the parts are expected to arrive next week, so i hope to be able to get it in the air pretty soon. what do you think- do i have a chance to get it in the air and land in one piece?
most of the 3D printing market today is indeed fragile plastics and condiments, but there are even today printers that can print fiber reinforced plastics and even (with laser sintering) metals. I'm also quite sure there's someone out there printing ceramics. the parts should be printing as I write, so I'm crossing my fingers everything comes out as i planned. shai |
well, i got all the parts printed.
it wasn't easy- over the weekend, one printer didn't print at all and another stopped in the middle of printing. after handling the smaller parts that were printed properly, i felt the material i chose was too flexible and the structure would flex too much. so i left some parts like this, but i printed the components of the main wing from a stiffer, but more brittle, material. it looks OK to me now, almost everything fits (just a little sanding here and there), it feels strong enough, and the weight is about as planned- 240g for the frame. after some tests on leftover parts, i found i may have another problem- the material is not very temperature resistant, so when i try to shrink the covering film, the heat deform the part. i can get a loose covering, or a crooked part, but not a properly covered, straight part. i don't know where i can get reasonably quickly low temperature covering film, so i'm considering using a shrink wrap (like i did on my printed small gliders) or maybe an adhesive tape. we'll see. for now i'll start assembling and gluing everything |
assembly
glued everything together. it feels strong enough, but not straight enough. after joining the center and edge of the wing you can see the curve of the leading and trailing edges to not run smoothly form one part to the other. this is probably due to some deformation of the parts during the printing process. it's hard to show this in a photograph, and i hope it won't effect the flight characteristics too much.
finally, i covered it with clear adhesive tape which i shrunk just a little bit by heat from a cosmetic hot air blower. the colored trim is partly self adhesive and partly shrink-covering i ironed on at a low heat setting. the doubly curved surface of the canopy is to complex for covering with adhesive tape so here i used food shrink wrap. getting all the equipment in took a little more sanding and fitting, but now it's all done and everything is working as planned. |
maiden
well, the big day finally arrived. packed my wife and my camera and went to the flying field.
i planned on using a 1000mAh battery, but according to my markings, it did not bring the CG forward enough, so i decided to use a 1600mAh battery to bring the CG forward enough and hope it will not be too heavy. i had quite a bit of trouble with the launch, i couldn't get it to power up and gain some speed before it reached the ground. i also noticed it had a hard time keeping the nose up, so i switched back to the smaller battery and it seemed to improve the diving tendencies, but i still did not manage a good launch. all this crashing caused a little damage to the front of the battery compartment from the battery sliding forward, but otherwise everything seemed to stay structurally sound. the color trimming, however, was starting to peel- apparently i used too low a temperature when ironing. in the end my wife left the camera and launched the plane for me. after 2 tries we finally got it and the wing was truly airborne. then she had to rush back and pick up the camera, and this explains the rather shaky video. |
and crash
i had to trim the controls quite a bit to get it to fly level, but then it was just great. it could putter along on a few clicks of throttle, and power up and go nearly vertical. i manged to do a roll and a loop and a little inverted flight, but then, maybe a little because a piece of the trimming started coming loose and adding drag, and maybe because i was being too cocky and flying inverted, i crashed.
when flying, the wing felt light and powerful, so that makes it harder for me to understand why it was so hard to launch. any tips about launching technique would be appreciated. |
competition
i see i'm not the only one testing this technique for producing RC planes:
sintered_aircraft they have a better launcher, that's for sure. |
| Thread Tools | |
| Discussion 3D Printed Rigid Rotor System for Blade CX2/3 coaxial helis | tiltrotorcoaxial | Coaxial Helicopters | 33 | Jul 22, 2011 03:03 AM |
| For Sale 3D Printed Rigid Rotor System for Blade CX2/3 coaxial helis | tiltrotorcoaxial | Aircraft - Electric - Helis (FS/W) | 7 | Jun 17, 2011 08:42 AM |
| For Sale 3D Printed Rigid Rotor System for Blade CX2/3 coaxial helis | tiltrotorcoaxial | Aircraft - Electric - Multirotor (FS/W) | 3 | May 28, 2011 11:49 AM |
| Discussion 3D Printed Rigid Rotor System for Blade CX2/3 coaxial helis | tiltrotorcoaxial | Micro Helis | 2 | May 27, 2011 05:38 PM |
| 3D Foam Planes with printed graphics? | GBR2 | 3D Flying | 0 | Mar 08, 2004 02:50 PM |
