Marco....
Get rid of that HS-82, it has NO bearings in it at all. The output shaft rides on the rim of the case and they wear out very quickly, and get real sloppy, real quick... SteveT |
Latest blog entry: My hangar...
Marco, I disagree with Steve on this... use the 82 till it IS sloppy and then replace it. I hate to have someone waste money not getting the use out of equipment they have already purchased.
Latest blog entry: Southern Utah Huckin!
Snoopy has to stay he is a legacy and only made out of dollar tree foam board so is VERY light. The weight, tail wheel and Snoopy were in Franken Edge along with hot glue, packing tape, extra balsa from repairs, and a bunch of decals and vinyl graphics and it still only weighed 45.6 ounces with the same battery. Not going to sweat the weight difference as I said it flies fine.
Steve thanks for the heads up on the servo. That explains why it was only 19.99 instead of 29.99 for the HS-85MG I thought I was getting. It will get pulled soon. |
Had the "SFG'd" Edge out again for some quick flights before going away for a few days. Getting used to the "new" Huck. Flew in gusts to 25 yesterday- no worries, only getting blown over on the ground or off the bench! Did some blenders, KE spins and flat spins, wow- flat as a pancake and even climbing flats! Also the lomcevaks are awesome. Still tweaking the poptops. Oh, parachutes, elevators straight down. Really enjoying it. KE and slow rolls are much cleaner too. Can you tell I like the SFGs?
Glad you like those SFG's. They also a good for not scrapping up your wingtips on a crappy landing.
Has anyone tried any of the OS electric motors? Seriously considering getting the .25 960 kv for the newest Edge and putting the new Omega in the Franken Edge. SPECS: Rated Voltage: 11.1 Rated Current: 40A Maximum Current (10 sec): 80A No Load Current: 1.7A Phase Resistance: 26.7 miliohms Maximum Efficiency: 80% kV: 960 Turns: 12 Poles: 14 Shaft Diameter: 0.20" (5mm) Shaft Length: 0.45" (11.5mm) Weight: 5.64oz (160g) Lead Wire Length: 3.5" (90mm) Lead Wire Gauge: 17AWG Length of Motor Can: 1.7" (43.3mm) Diameter of Motor Can: 1.47" (37.5mm) Length/rear of Motor Can to Prop Washer: 2.3" (58mm) Prop Washer Diameter: 0.87" (22mm) Thickness of Motor Mount: 0.12" (3mm) Width of Motor Mount: 1.96" (50mm) Height of Motor Mount: 1.96" (50mm) Performance for this motor with different props and LiPo cells is as follows (all data with 60A ESC): Prop Size Current LiPo Cells Wattage Thrust RPM 11x5.5E 31A 3S 391W 1.9kg 10,100 11x7E 37A 3S 466W 2.1kg 9,750 11x8.5E 44A 3S 554W 2.1kg 9,350 11x10E 49A 3S 617W 2.0kg 9,100 11x4.7SF 44A 3S 554W 2.2kg 9,400 11x7SF 59A 3S 743W 2.7kg 8,540 12x6E 40A 3S 504W 2.4kg 9,650 12x6SF 66A 3S 832W 2.4kg 8,280 12x8E 49A 3S 617W 2.5kg 9,170 12x10E 66A 3S 832W 2.0kg 8,050 13x6.5E 50A 3S 630W 2.8kg 9,040 13x8E 56A 3S 706W 2.9kg 8,730 13x10E 65A 3S 819W 2.7kg 8,120 14x7E 61A 3S 769W 3.1kg 8,520 14x10E 75A 3S 945W 2.9kg 7,600 |
looks ok... a little on the heavy side but over 700 watts on this plane would be nuts!
Is there any way you could give more prop data for the OS? Just kidding!!!! |
Just something I was considering and as far as the extra weight goes I could just remove the one ounce of ballast I added to the nose. Omega on 4s is supposed to be around 700 watts with a 12x6. A 4s 2200 is probably at least an ounce heavier than a 3s 2200 of the same C rating. Almost 7 lbs of thrust on a 3 lb Edge ought to be entertaining. Like I said I am considering this, will probably come to my senses by tomorrow.
Oh dang I killed the thread again! Life interfered with my flying today but things are looking better for Friday. Bought the wife a new camera that does full 1080 HD video for Xmas so maybe some decent videos in the future. HS-85MG on the way to replace the 82. Thanks again for the warning Steve.
SteveT |
Hi All
Wanted to share the 1st Video Ive ever made of my flying. Made myself a hat cam so I can start video taping my flights Take it easy on my tho.. Ive only been flying 3d style since March of this year. So the flight is nothing special.. But I do love the 48: edge.. it never leaves my car
| Thread Tools | |
| New Product 3DHS 41" Edge "$99 Buck Huck" | Ducati Mechanic | 3D Flying | 17299 | Mar 27, 2012 03:37 PM |
| Sold 3dhs 41' edge buck huck bnf | JBuck | Aircraft - Electric - Airplanes (FS/W) | 7 | Jul 02, 2011 06:58 AM |
| Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck | 6L6Amp | Aircraft - Electric - Airplanes (FS/W) | 14 | Aug 22, 2010 07:45 PM |
