Old Nov 22, 2012, 07:00 AM
Capt. Roll is offline
Find More Posts by Capt. Roll
Capt. Roll's Avatar
United States, TX, Fort Worth
Joined Dec 2010
Originally Posted by Fastest3 View Post
Edge ordered last night orange one, omega 130 and ice lite 75! So excited, any advice on build let me know. I fly spektrum, how crazy should I go on my receiver?
When you mount the wire landing gear, use the no epoxy method. Makes for a very clean install and will allow for you to easily remove the wire and replace it should you need to at some point in the future.
There are several post within this thread on the mod.
Also, you may want to fly your Edge without the gear leg fairings. I've read several posts about the fairing poking a hole in the fuse when the wire bends on a hard landing. If you are greasing your landings then you probably won't have any issues but there is always that "one" time.
Regarding props.........APC, Xoar and Falcon are all great; 14X7 and 13X6.5 seem to be the preferred size. The beechwood props are half the weight of the APC (faster spool up) but twice the expense and certainly more fragile.
The wooden props do not fit the 1.5" spinner factory prop cut-outs; you will need to enlarge the blade openings. Take your time and you can get a nice fit.
Capt. Roll is offline Find More Posts by Capt. Roll
Old Nov 22, 2012, 07:09 AM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
AR6115e would work, but if you could get your hands on an AR400 (or preferably an AR500, so you don't need a Y harness for the ailerons so they can be adjusted individually) that would be best.
Not a spektrum guy anymore, but thats what my opinion is!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Nov 22, 2012, 08:15 AM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
I'm using the AR6115E in all my 3D planes from 40 size and down. Works very well and has more than enough range. I.e., I've taken the Edge and my other planes up so high that they were just a dot in the sky, and the AR6115E's link remains solid as a rock. Been using them for two seasons now and not a single problem with 'em.
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Nov 22, 2012, 08:51 AM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
im thinking that i might sell 48 for a 47 shp.
cale10 is offline Find More Posts by cale10
Old Nov 22, 2012, 10:10 AM
Joined Feb 2011
Old Nov 22, 2012, 02:00 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
AR600 will work fine...personally, I like AR7000 or AR7010..
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 22, 2012, 04:01 PM
ramoooo is offline
Find More Posts by ramoooo
United States, CA, Oakland
Joined Sep 2010
Originally Posted by Capt. Roll View Post
If I was going to purchase an Exceed motor again I'd get the Rocket 3020-950kv or the 3020-990kv motor. Hobby Partz was out of those when I put my Edge together. The 3015-820 is okay but I think you will find it a little lethargic.
The D658 is great for the rudder and would work for the ailerons and elevator as well. However you will need to enlarge the servo openings in order for the case to fit. No prob for the rudder, I'd think twice about doing that for the elevator and aileron locations. Plus the D658 is heavier, 26 grams, no big deal sitting by the wing tube.
ESC and spinner look fine.
The APC prop has good performance but it is heavier than a Falcon or Xoar 13X6.5 or 14X7.
Sorry, I don't have any experience with the Nanotech packs. I've had very good results with Glacier (EP Buddy), GensAce (Hobby Partz) and GeForce (Value Hobby). All 3S 2200mAh and 30C discharge or higher.
When setting up your plane and using the recommended 3DHS setup, everything is "proven" to work. Also if you need some assistance there are plenty of guys flying with the recommended setup and could provide some help.
If you are willing to experiment (like me) and take a risk on trying some alternate components you can find a setup that will provide great performance, be reliable and save you some cash.
would the exceed have enough power ?
the power looks like its much lower ?
any suggestions ?
thanks
ramoooo is offline Find More Posts by ramoooo
Old Nov 22, 2012, 04:16 PM
ramoooo is offline
Joined Sep 2010
What propr did you guys try on the exceed moto 3020 ?
thanks
Old Nov 22, 2012, 07:40 PM
toolman18 is offline
Find More Posts by toolman18
toolman18's Avatar
United States, TX, Portland
Joined Apr 2008
I like the 12x6 Apc with 4 cell 2500 batteries. Flies awesome fast and hovers like a dream.
toolman18 is offline Find More Posts by toolman18
Old Nov 22, 2012, 07:42 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
It's a rocket on 4s! I've flown it on that setup as well. I personally prefer the lighter/floatier 3s setup but it's nice to have a choice!
turnerm is offline Find More Posts by turnerm
Old Nov 22, 2012, 07:56 PM
ramoooo is offline
Joined Sep 2010
I Have 2200 3s... what setup do you guys recommend if I go with the exceed motor
Does it have sufficient power for 3d?
And what prop do u suggest on a 3s setup.
Old Nov 22, 2012, 08:06 PM
quadracer is online now
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
14x7 or 13x6.5 seem to be the unanimous winners for 3S.
quadracer is online now Find More Posts by quadracer
Old Nov 22, 2012, 09:09 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
I like the 14x7 on this plane.
3Daddict is offline Find More Posts by 3Daddict
Old Nov 22, 2012, 09:29 PM
ramoooo is offline
Joined Sep 2010
Are guys referring to the prop with the exceed 3020 motor.
And which one should I go with the 900or 950kv
Old Nov 22, 2012, 09:35 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I don't know which motor you are referring to or what the specs are. But if it's similar (in weight and KV) to the Omega 130 then you will want a 14x7 or 13x6.5.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
