Here's the link because it will be asked for again.
http://www.rcgroups.com/forums/showt...g#post18469604 Ben, I need some rewards points for this. ![]() The advice is spot on. Thanks and thanks for a great product. Jeff |
practice dead stick landing all day with the edge, never bent the gear, if you fly it to the ground (nose down attitude) and flair at the last second this will land itself, if you insist on continuously holding up elevator and bobbing in for a landing you will plop like a pancake and bend the gear everytime
Great landing advice guys! Takes some discipline and practice to let it come in nose down like that and know when to flair. Going out in while for some flights and promise to give this method a try.
OK I'm back and did 4 landings out of 5 per the above recommended advice. Not bad at all no bent gear. Getting the timing of the flair just right was not as bad as I expected. It does carry a bit more momentum and thus more of a ground roll than I am used to. Last flight I did a parachute into a harrier I plopped down right where I intended and only rolled about 2 feet but did slightly bend the gear. |
Click HERE for motor info and HERE for esc info |
Latest blog entry: The family continues to grow
Personally, I absolutely hat "stick programming" on ESCs.....the Castle ICE lite 50 amp is really the way to go...
SteveT |
Latest blog entry: My hangar...
If you are looking for something more economical take a look at one of the Exceed RC Rocket motors. http://www.hobbypartz.com/86mb92-3020-950kv.html Put it with a 50 - 60 amp Hobbywing, ZTW, or Proton ESC. I've used several of the Rocket motors with the above ESC's; the performance has been very good at an economical price point. |
Omega 130 is perpetually out of stock for a good reason, it is a great motor for the price. Mine has been bulletproof for over 400 flights including 4 bad crashes and countless prop strikes. Another decent alternative might be http://epbuddy.com/index.php?main_pa...roducts_id=188
If you don't intend on trying 4s then the Castle Thunderbird 54 has served me well. |
| Thread Tools | |
| New Product 3DHS 41" Edge "$99 Buck Huck" | Ducati Mechanic | 3D Flying | 17299 | Mar 27, 2012 03:37 PM |
| Sold 3dhs 41' edge buck huck bnf | JBuck | Aircraft - Electric - Airplanes (FS/W) | 7 | Jul 02, 2011 06:58 AM |
| Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck | 6L6Amp | Aircraft - Electric - Airplanes (FS/W) | 14 | Aug 22, 2010 07:45 PM |
