Old Aug 23, 2012, 12:13 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by brathanke View Post
It's easy to stop buying them when you run out of cash
Amen to that!!
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Aug 23, 2012, 01:19 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
I had 173-th flight this morning Today was the first good morning without rain and wind in a week, so I had 5 flights. Very happy with savox - very tight KE loops. I think, that before I installed them I experienced some blowback, despite of I used 125% end points on rudder.
And I got 2 rotations at the top after doing pop top today - it was cool. Edge flies better and better with every flight. Also got all stuff much lower today. Was doing slow rolls at low altitude and high speed and realised, that I have to lower low rates on a radio as it was hard to maintain altitude.
AlexGold is offline Find More Posts by AlexGold
Old Aug 23, 2012, 07:08 AM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Sticking with my plan of getting Edge #2 back in the air as a float plane. Just need floats and a cheap motor. After that I still need to put the finishing touches on my scratch build prop jet, my old trusty F-27C custom needs a new body. Hum a new helicopter would be nice too. Oh God it never ends does it?
Was loading the Edge back in the car this morning after a few flights when I noticed the gap between the counterbalance part of the rudder and the top of the vertical stabilizer was almost 3/8 of and inch. All the hinges had broken loose and the only thing holding the rudder on was the tail wheel bracket and the pull/pull cables. A couple drops of thin CA and all is good again but something to watch out for.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Aug 24, 2012, 12:27 AM
AlexGold is offline
AlexGold's Avatar
Joined Mar 2011
Recieved Xoar props and found that they are absolutely the same with JXF props that sells HK. The only difference - JXF is only availible in 14x6 and 14x8 size, and Xoar - 14x7. This props have more power consumption in comparison with APC and lower RPM. So APC seems to be more efficient, while XOAR and JXF makes plane more predictable. My flight time with XOAR dropped to 6 minutes from 7 with APC. Think I should try Falcon now.
Haven't took my notebook with me, so wasn't able to get data from ESC. JXF 14x6 was eating more amps than APC 14x7. So I think 14x7 XOAR will take even more. May be this is the cause of failure of some Omega 130.
Old Aug 24, 2012, 02:04 AM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
I would think thrust figures along with power draw and rpm would be the only good comparison between different props. I've mostly heard that wooden props were more efficient since they didn't flex as much.
krexken is offline Find More Posts by krexken
Old Aug 24, 2012, 02:27 AM
AlexGold is offline
AlexGold's Avatar
Joined Mar 2011
http://www.rcgroups.com/forums/showp...postcount=9444
Here is comperison between APC and JXF. I'll do the same with XOAR as soon as I get to the field with notebook.
Old Aug 24, 2012, 05:43 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I love my Xoar props. I agree with you on the power consumption and the predictability. I also get more rapid throttle response.
turnerm is offline Find More Posts by turnerm
Old Aug 24, 2012, 03:47 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
How far down do you guys run your batteries? I check each battery for volts on my power meter after each flight. I don't like to run them below 11.4. Am I being too conservative? I also love the response from the Xoar 14x7 but had to be very careful with the throttle or I was ending up with around 11.1 volts left in the pack. my problem with the Xoar or any wooden prop is my occasional crappy landing busting the tips on the pavement. Not really the props fault at all. It is what it is. The one JXF prop I had was a 14x7 I bought from Value Hobby and now I can't find that size anywhere. It seemed identical to the Xoar. Has anyone tried Vox props? Really curious about the battery question.
Old Aug 24, 2012, 05:01 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
3.8 or 3.7 per cell is usually a good practice so you're in good shape. If you run them down a lot lower than that then they just won't last as long. It depends on the quality of the battery too - some hold up to the abuse better than others.
Old Aug 24, 2012, 05:26 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
My God, I actually by accident did something right? Seriously that must explain how some of my cheap GeForce batteries have survived for over a hundred cycles. Thanks for the quick reply bro.
Old Aug 24, 2012, 07:50 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
cg issue fixed(my bad dumb thumbs) any tips for the maiden?
cale10 is offline Find More Posts by cale10
Old Aug 24, 2012, 07:55 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Give her hell!
quadracer is offline Find More Posts by quadracer
Old Aug 24, 2012, 07:59 PM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Just go up 3 mistakes high and get the feel for it. Use low rates for take off and landing. Have fun and relax
3Dplank is offline Find More Posts by 3Dplank
Old Aug 24, 2012, 08:03 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I got two flights on mine today and zero good landings... arg. I gotta lose the wheel pants. Thanks to Wamsy for the harrier tips I got from him This plane has been the most problematic for me for wing rock. They are still a work in process but much better. My plane is so mis-shapen from extensive repairs it is a wonder I can fly it straight let alone harrier it!
3DNater is offline Find More Posts by 3DNater
Old Aug 24, 2012, 08:55 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Like I tell me wife... every now and then I do something right. Whether it's on purpose or not may be a different story but EVERY now and then...
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
