Old Aug 11, 2012, 12:35 AM
xzuberance is offline
Find More Posts by xzuberance
Where's my orange kool-aid?
xzuberance's Avatar
Australia, VIC, Boronia
Joined Apr 2010
Hi guys
Has anyone done a thrust test with apc/Vox/xoar 13x6.5 and 14x7 with an omega 130? Am curious what kind of numbers people are getting. TIA
xzuberance is offline Find More Posts by xzuberance
Old Aug 11, 2012, 01:30 AM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Finished building!
Description:
grovey is offline Find More Posts by grovey
Old Aug 11, 2012, 01:39 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Why is your stab in upside down???
SteveT
just kidding...but I bet I made you look!! And.... Good job!!
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Aug 11, 2012, 01:46 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Lol dude! You made me look yeah!
Old Aug 11, 2012, 02:52 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
Steve, you made me nervous till I saw this gray letters
AlexGold is offline Find More Posts by AlexGold
Old Aug 11, 2012, 03:21 AM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Good one Steve you had me clicking the picture too!
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Aug 11, 2012, 10:54 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Well the maiden is out of the way.
Turns out though my rudder was reversed which made the flight quite horrible. The plane was also nose heavy.
The landing was quite hard and I bent a strut which punctured the fuse a bit.
Second flight after adjusting cog and some elevator trim the plane is flying better. Had a decent landing.
Next flight coming up.
Old Aug 11, 2012, 11:31 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Well the plane is cool hehe. Had my 3rd flight and heading home right now.
Learnt some lessons but will get there!
Old Aug 11, 2012, 11:35 AM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Good job getting her airborne! Now just tweak it to your liking and have a blast!
quadracer is offline Find More Posts by quadracer
Old Aug 11, 2012, 12:23 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Thanks!
I have noticed something with my motor that I am not quite sure I have heard before.
Every revolution (I tested by spinning by hand too) it seems there is a slight grinding type noise. I really hope this is normal.
The motor is not rubbing against the cowl, so I am sure there is no binding of the motor.
On the bad landing on my maiden flight, I noticed the tips of the blades had hit the runway, I am hoping that that blade strike has not damaged the motor. I had cut the throttle a bunch I am sure.
Thoughts? Is this normal? Something to be concerned about?
Old Aug 11, 2012, 06:08 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I forgot to mention it is the Omega 130.
quadracer's Avatar
Joined Feb 2012
It could be normal, but I don't know. I don't have the Omega motor. I would say try blowing it out with compressed air and see if anything changes.
Old Aug 11, 2012, 06:12 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
My Omega has survived many hard blade strikes and 3 crashes just fine. No grinding but it is still very tight even after over 200 flight in 3 Edges.
Well my Savox servos arrived today. I was beginning to doubt they would and was pleasently surprised when they did. Very nicely packaged in reusable clear plastic boxes. A plus for a parts hoarder like me. Intial impression a nice well made product. Servo leads are 2 or 3 inches longer than Hitech HS-65MG. They might be long enough to eliminate the extensions on the wings. I'll have to try that later on because these are going on the rudder and the elevator. If I end up liking these I'll order 2 more for the ailerons. The center section of the cases is a nice anodized aluminium, but the top and bottom are plastic. Top to bottom the case is slightly longer than the Hitech and it is just a hair wider. I had to shave a tiny amount of material with my xacto knife from the rudder hole for a snug fit. The splines on the output shaft are different from the Hitech so the servo arms are not interchangeable. When I went attach the 3DHS Long Servo arms to the Savox servo arms I ran into a slight snag. The holes don't match up perfectly, and required me to slot the holes slightly with a drill bit. While working on the rudder I was able to get it mechanicly centered perfectly for the first time. Before I have always had to use a fews click of rudder trim on the transmitter. Seems to have much more torque and centers consistantly. Hope to do a flight test or 5 in the morning. If that goes well I will put the other Savox on the Elevator.
Old Aug 11, 2012, 07:20 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Glad you got the maiden done with! Now it's time to have some fun!
ALWAYS check your control surfaces before every single flight! Ask me how I know...
turnerm is offline Find More Posts by turnerm
Old Aug 11, 2012, 07:23 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I may just need to try that yeah.
That is good to know!
Agreed, I was like, something is wrong, it just did not feel right (obviously). Glad I did not lose the plane.
The CoG is good right now, now I need to learn how to land properly. I am gonna have to fix my landing gear and the dent/hole punched into the fuse.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
