Old Jul 19, 2012, 09:55 PM
AeroHeadTW is offline
Find More Posts by AeroHeadTW
AeroHeadTW's Avatar
United States, NJ, Berkeley Heights
Joined Nov 2009
Originally Posted by brathanke View Post
Here are some decent batteries... not sure what to say on the LG.
http://www.valuehobby.com/power-syst...-lipo.html?p=3
Thanks; is there any practical difference (for 1.5 buck use) between the 30c, 40c & 55c rated batts (holding punch throughout flight, more cycles, eyc)?
AeroHeadTW is offline Find More Posts by AeroHeadTW
Old Jul 19, 2012, 10:31 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
25C to 30C is more than enough for this plane....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 19, 2012, 11:00 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
30c is fine with the Omega 130, I have a 40c but can't tell any difference in flight performance. Some of my 30c GForce batts have over a hundred cycles on them and have been used in my Stryker, PZ Extra 300 and Edges.
Replaced the rudder servo a few minutes ago and discovered the top case was split from side to side right through where the output shaft(?) exits. Thought about taking the top off of the HB case and putting it on the MG. Maybe tomorrow. No recent crashes or very hard landings, but many, many KE spins, pop tops, and KE laps around my landing area.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jul 19, 2012, 11:07 PM
AeroHeadTW's Avatar
Joined Nov 2009
Thanks again
Old Jul 19, 2012, 11:25 PM
SteveT.'s Avatar
San Jose, CA
Case is the same....
SteveT
Old Jul 20, 2012, 12:24 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
I'm using this one: http://www.hobbyking.com/hobbyking/s...dProduct=21393
If we talking about zippy batteries, they are overrated, so 25C will not be enough. You have to go with 35C
Speaking about landing gear, mentioned above will be too little. I have this one: http://www.hobbyking.com/hobbyking/s...idProduct=4504 but couldn't find time to install it.
AlexGold is offline Find More Posts by AlexGold
Old Jul 20, 2012, 12:30 AM
SteveT.'s Avatar
San Jose, CA
I'm using Zippy 3S 30C 2800mAH packs in my Omega 130 gram motor powered Edge, and having no problems....Also flew my 89" Slick with Hacker Q8-8M motor on 6S 30C 5000mAH packs, again no problems....The 30C don't seem to be overrated...just sayin....
SteveT
Old Jul 20, 2012, 12:50 AM
AlexGold is offline
AlexGold's Avatar
Joined Mar 2011
30С 2800mAh = 84A
25C 2200mAh = 55A
max current with Omega 45-50A, so you have huge margin...just sayin...
I just wanted to say that with 2200 zippy pack you have to order 35C pack, because 25C gives realy only 15-20C and this is not enough.
Old Jul 20, 2012, 12:56 AM
SteveT.'s Avatar
San Jose, CA
30С 2800mAh = 84A
25C 2200mAh = 55A
Well....I don't fly too hard, so that is probably why I don't have any problems with them....
SteveT
Old Jul 20, 2012, 02:24 AM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
Alex how are you getting those figures? I do not doubt them just curious as to the formula you are using. I like to know how and why things work or don't work. Your numbers do seem to agree with the 498 watts and 46 amps I saw during some static testing.
Old Jul 20, 2012, 02:57 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Amp hours times the C rating. IE 2800 mAh = 2.8 Ah times C rating (30 in the case above) = 84A
Eagle34 is offline Find More Posts by Eagle34
Old Jul 20, 2012, 03:06 AM
AlexGold is offline
AlexGold's Avatar
Joined Mar 2011
Thats right
Old Jul 20, 2012, 03:51 AM
AZAerobat is online now
Find More Posts by AZAerobat
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
I am not a big fan of the two piece landing gear myself. I am wondering if you could just grab say the 3DHS 47" SHP's carbon gear or heck maybe even the 51" AJ Slick's CF and fabricate a way to put it on the Edge. That has me thinking about doing a CF landing gear mod to mine now. Has anyone tried one yet? Just curious on how difficult it was. I am not much of a builder more of an assembler.
AZAerobat is online now Find More Posts by AZAerobat
Old Jul 20, 2012, 05:11 AM
winndaddy is offline
Find More Posts by winndaddy
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
Can someone please help me? I ordered the Edge recently but the long servo arms for the Hitec 65mg are out of stock. Tried calling them yesterday, but they don't answer, and it says their voicemail is full. Is there any other long servo arms people are using that work with the Hitec? Or, is the long servo arms even nessecary? Any info will be greatly appreciated.....
Winn
winndaddy is offline Find More Posts by winndaddy
Old Jul 20, 2012, 06:55 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Winn
Depends really on the radio you are using, if you are using the DX6i then they are pretty much a must have on the elevator and rudder, ailerons not so much so. DX7 or DX8 or the new Futaba 8FG not really needed.
If you really need some you can use carbon fiber ones like these for the elevator and these for the rudder. You can find the same things at HK for cheaper (and they come in pairs) but you will have to wait for shipping from China.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
