Old Jul 17, 2012, 08:49 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
make sure you pre-drill. I would hate for the formers to crack
3DNater is offline Find More Posts by 3DNater
Old Jul 17, 2012, 08:53 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
The smallest drill bit I have is 1/16. Is that sufficient forth screws provided?
The drill I have also cannot reach, lol, this is a mission!
grovey is offline Find More Posts by grovey
Old Jul 17, 2012, 08:58 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
well I suppose you could start your hole with a servo screw or something. A hand drill is a great hobby tool. that being said... I dont have one either
Old Jul 17, 2012, 08:59 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
when I did mine I used a larger blind nut and a bolt. The larger drill bit was long enough to reach with my drill.
Old Jul 17, 2012, 09:06 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
This is what I have right now.
I hope this will hold and not crack or damage the plane when I land.
Description:
Old Jul 17, 2012, 09:14 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
looks good to me. there will be almost zero pressure on that screw. kinda like a wing bolt... doesnt do much but hold the wing snug. the anti rotation pin and wing tube do all the heavy lifting. those formers and the wedge will be plenty strong to keep the gear in place.
Old Jul 17, 2012, 09:18 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Maybe after a few landings the gear will seat properly! Hehe
Old Jul 17, 2012, 09:20 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
I had similar trouble with both of my orange Edges. Had to use sanding sticks that wife uses on her nails to open up the slots in order to get the wire in. Then ended up sanding the wedges to get them to fit all the way. This was not a problem with my blue Edge. I think the covering on the orange Edges for some reason shrinks a bit tighter than the blue. I had some slight warping of the bottom of several formers in the rear fuse on both orange ones but not on the blue.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jul 17, 2012, 10:10 PM
theK2 is offline
Find More Posts by theK2
3D-wanna-B
theK2's Avatar
Lynchburg, VA
Joined Dec 2008
wood screw man. that gear will bend and you will be kicking yourself if you glue it.
+1 - and all you need is a small screw. Don't over-complicate it - like was said... that screw doesn't have to do much but keep the gear from falling out. There is no vertical force (down) being exerted on the gear ---- unless you really screw up.
theK2 is offline Find More Posts by theK2
Old Jul 17, 2012, 10:14 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
I epoxied my gear in, and if I ever have to replace it I am going to have a "FUN" time removing it with a dremal. But I think the plane will go before the gear.
3Daddict is offline Find More Posts by 3Daddict
Old Jul 17, 2012, 10:39 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
293 flights on my original epoxied in gear, well over 400 landings and this was my first 3d plane bought back in Sept of last year, sure the gear bends, I just bend it back
3drcparts is offline Find More Posts by 3drcparts
Old Jul 18, 2012, 01:42 AM
djowtlaw is offline
Find More Posts by djowtlaw
Fly Easy
djowtlaw's Avatar
Joined May 2012
First thing that comes to mind is fatigue! Although I bet there will (hopefully) be a few thousand cycles of bending before any cracks show.
djowtlaw is offline Find More Posts by djowtlaw
Old Jul 18, 2012, 01:45 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
My re-pod edge still has straight gear... against all odds I've probably flown it about 50 times.
Old Jul 18, 2012, 02:23 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hey guys.....
Since I bought myself a lathe, I have been trying to figure out a few things to make to make a few bucks with it. So...for those that would like some of the aluminum "buttons" that I designed for the landing gear mod, I am going to make those... Let me know if you're interested....
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 18, 2012, 03:04 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by SteveT. View Post
Hey guys.....
Those are great Steve, I had Cmala make me a set when he first started machining things. Work great.
Eagle34 is offline Find More Posts by Eagle34
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
