Old Jul 17, 2012, 11:54 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
I think 1800 4S 40C will weight pretty the same as 2200 25c 3S. Any way, you can weigh your battery and if it's more than 170g then it will be ok.
AlexGold is offline Find More Posts by AlexGold
Old Jul 17, 2012, 12:06 PM
racerman27410 is offline
Find More Posts by racerman27410
racerman27410's Avatar
United States, NC, Greensboro
Joined Dec 2006
Originally Posted by Olie View Post
After months of shoehorning my edge into my old car, it has a new set of wheels to get around in.
There's plenty of room for friends as well.
Diesel? I've got one in white with pano roof and am loving the room (will hold 2 x 71" slicks) and the mileage! (averaging 42MPG over 5K miles)
ENjoy the new ride!
racerman27410 is offline Find More Posts by racerman27410
Old Jul 17, 2012, 12:17 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
It weighs 220g
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 17, 2012, 12:45 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Ya I think you will be pretty safe flying that pack. I'm guessing you will get similar power to the 3s setup on the 12x6. Maybe it will be a bit faster. Should be fun The only down side is you won't have the big prop for post-stall flying.
3DNater is offline Find More Posts by 3DNater
Old Jul 17, 2012, 06:46 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Made a bit of progress tonight now I am at the point where I need to install the landing gear.
I may use a wood screw to mount the gear, but that aside, I can't even get the gear into the fuse. It is tight and I am afraid to force it. It seems my plane is really fighting me, I am wondering if the weather here is causing this plane to deform causing me grief.
Any tips one how to get the wire gear fitted into the fuselage other than brute force?
grovey is offline Find More Posts by grovey
Old Jul 17, 2012, 07:46 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
How tight it it? Is it just snug and you can still push it in or is it so tight you have to force it in? I would check to make sure the is no debree in the opening such as glue or epoxy or some covering. If there is nothing blocking it try lightly samnding the wood so you can them slip in the grear and epoxy it.
3Daddict is offline Find More Posts by 3Daddict
Old Jul 17, 2012, 07:58 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I have to force it, it seems to be sticking on the corners. I guess I need to take a file to my plane.
Old Jul 17, 2012, 08:25 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
This is not working to well. I am not sure I am going to be able to get the gear installed so that the gear plate is flush. I feel something is going to crack snap or break if I force this gear in. The last few millimeters is the problem now.
This is so frustrating as I am sure I should not be struggling this much.
Old Jul 17, 2012, 08:30 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Can you look into the slot and see anything blocking the gear???
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 17, 2012, 08:36 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
SteveT
It is totally clear I think the gap is just too narrow. I managed to file the opening down a touch, but now I only a fee millimeters out. I think the gear is a touch thicker than the plate and evidently the slot.
Old Jul 17, 2012, 08:37 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
grovey... dont know what to tell you man. I have not had that problem. Mine was very snug but I could get it in ok. Maybe your formers have warped a small amount making the space tighter. How far can you get it to go in before it is too tight to go further?
Old Jul 17, 2012, 08:40 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I agree, I am sure it is not supposed to be this difficult to install.
When you say very snug, how hard did you have press together the gear in?
The gear still needs about 2-3mm.
Old Jul 17, 2012, 08:45 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
so it goes in all the way until the last few mm? Id call that substantial completion and move on...
Old Jul 17, 2012, 08:46 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
So then the question becomes, epoxy or wood screw(s) for the installation?
Old Jul 17, 2012, 08:48 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
wood screw man. that gear will bend and you will be kicking yourself if you glue it.
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
