Old Jul 16, 2012, 10:44 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Yes people have installed CF gear on the edge. Just do an image search on this thread and you should find what you are looking for. Let us know if you don't
3DNater is offline Find More Posts by 3DNater
Old Jul 17, 2012, 12:18 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
Originally Posted by Olie View Post
After months of shoehorning my edge into my old car, it has a new set of wheels to get around in.
There's plenty of room for friends as well.
sweet ride. I'm thinking of trading in my 3 series for a TDi Sportwagen if they ever come back in stock. Supposed to be this week.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Jul 17, 2012, 12:32 AM
Olie is offline
Find More Posts by Olie
Serial Lurker
Australia, SA, Adelaide
Joined Sep 2007
I'm loving the TDi.
You could easily get 3x 48" in the back without the fold flat seats being down. With the seats down, extend that to 2-3 x 80"+ air frames
Did I mention its an excellent luxo-barge!
Olie is offline Find More Posts by Olie
Old Jul 17, 2012, 04:13 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by brathanke View Post
Good News! I just snuck out for a quick 4 min flight on the edge and it still flies pretty darn nice. I even did a low KE pass . uh oh... here comes the rain... wish I had time for the other 4 packs I have sitting here but I cant wait out this little shower right now
Yall take care. I saw on the news that they are expecting flash floods in St George, UT. I immediately thought of you. Hope everything turns out OK.
Good deal on your repairs BTW.
Eagle34 is offline Find More Posts by Eagle34
Old Jul 17, 2012, 04:20 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Using even 5 min epoxy on that joiner is a good idea though. It gives you time to work and get it perfect where even without kicker sometimes a bit of CA can set before you get a chance to get the pieces situated. I have noticed that on balsa especially it likes to set up really quick. Often within seconds of applying it. Thin CA after the joiners are put together makes sense though.
Another reason I suggest using epoxy. Gives you time to adjust and shim if need be. Once set a little blue painters tape and let it sit for a while. CA does make sense though.
Originally Posted by turnerm View Post
I was shocked at how quickly it set. I had the second half at about a 20 degree angle and it had already cured.
I'm not sure if heat or moving air affects it but I was working in my garage with a large fan blowing on me so maybe the air from the fan really made it set quickly?
I cna't remember which build it was, but one of them I was putting the rudder servo horn in and had put CA on both sides of the horn, went to insert it and it got about 1/2 way in before it cured. I was like OH NO!! generous doese of debonder and brute force and it came back out ... about 45 minutes later. Lesson learned, insert, adjust, apply thin CA.
Old Jul 17, 2012, 07:00 AM
gms is offline
gms
Find More Posts by gms
gms
Winnipeg, Manitoba
Joined May 2007
I found it ... thanks so much for the tip
gms is offline Find More Posts by gms
Old Jul 17, 2012, 07:59 AM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
So one of the first things I did this morning when I got up was glue the elevator control horn. Hehe.
I need to reveal more information as to how I cleared the slot. I has to get out my drill after I tried using debonder. I used a 1/16 drill bit and carefully cleared the slot again, very carefully.
Anyway I have been thinking about something else. Remember I mentioned how tight the fit was for the horizontal stab? Is it possible I installed this the wrong way up or something. I can't inspect it now, ain't at home. It is just bothering me that I if it is so tight, how are things gonna hold up on landing etc... Unless we are just talking about tolerances.
I realise this is a really dumb question and feel silly asking it.
I am excited as tonight I can carry on full steam ahead with the build.
grovey is offline Find More Posts by grovey
Old Jul 17, 2012, 08:43 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Ok nevermind, I see the coloration now of the horizontal stab in some pics so I installed it correctly, I knew it was a silly question.
Old Jul 17, 2012, 09:01 AM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
The fit of my H stab on my third Edge was very tight. Even after removing all the covering and doing some sanding on the slot I still ended up with about a 1/16 of an inch gap in the front. It made no difference. Both of the other 2 fit just fine.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jul 17, 2012, 10:50 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
So using the omega 130g motor, is it possible to use a 1800mah 40c 4s battery?
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 17, 2012, 11:02 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Sure but you need to prop down to a 12x6 or similar.
Old Jul 17, 2012, 11:05 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Ok. Cool.
Old Jul 17, 2012, 11:06 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
Why not? 4S setup will draw less amps than 3S
AlexGold is offline Find More Posts by AlexGold
Old Jul 17, 2012, 11:08 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I asked because 3dhs website states a 2200 or higher is recommended
Old Jul 17, 2012, 11:18 AM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
You might have trouble getting enough weight forward to get the CG right,
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
