Old Jul 16, 2012, 06:48 AM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Glad all is going well with the rebuild. The Edge is probably begging to be flown again. This was your second Edge right? You first one was orange? I remember the videos. My batteries are on the chargers as I type this. No stick time since Friday morning.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jul 16, 2012, 07:32 AM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Arg I made a mistake. The glue I put on the joiner stick for the horizontal stab ran into the elevator horn mount. Now I cannot fit the elevator control horn.
Any suggestions on how to remove the glue from the mount and not disturb the glue on the joiner stick?
grovey is offline Find More Posts by grovey
Old Jul 16, 2012, 07:44 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Debonder or Acetone. You really want to remove the joiner stick too and use some 30 minute epoxy to set the joiner,makes a stronger joint.
Eagle34 is offline Find More Posts by Eagle34
Old Jul 16, 2012, 07:48 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
That sounds risky I medium ca'd the joiner stick already, as well as the elevator surfaces.
I wish the build videos I am watching would have mentioned 30 min epoxy before I glued everything.
Can't I drill out the elevator control horn mount carefully?
Old Jul 16, 2012, 08:11 AM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
Medium CA is fine for the elevator. Epoxy would have been nice but isn't completely necessary. If you haven't mounted your elevator servo yet you can try putting it on the other side.I would try to clean out the slot with a sharp exacto blade. If I couldn't get it in I'd try a small amount of debonder or acetone applied carefully with a q-tip or something. Just be patient and work it till it gives.
3DNater is offline Find More Posts by 3DNater
Old Jul 16, 2012, 08:22 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Good advise there. Listen to the master builder/repairer.
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Yeah I tried an exacto knife this morning, hehe that was a no go, I will purchase some debonder and try free the glu when I get home.
Since I have never used debonder before, how strong is it? Would it run through the hole and debond the joiner stick?
Oh I wasn't discounting your advise at all, I am just trying to avoid undoing the glueing I have already done.
Old Jul 16, 2012, 08:31 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Acetone works just as good. It's pretty strong (debonder) just put a dab on with a q-tip and let it sit then redo that and pick at it with a dental pick or an exacto. It will take some work but the acetone or debonder will work. If you are careful it shouldn't run through and get to the joiner stick. Even with the way everything is built it shouldn't get to the joiner.
Old Jul 16, 2012, 08:32 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Excellent thanks so much, this thread is awesome with all the fast replies and help!
Old Jul 16, 2012, 08:34 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
No problem I wasn't thinking about your hinges, much easier the way Nate has suggested.
Old Jul 16, 2012, 08:44 AM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Eagle34 I agree with you that epoxy is better for the joiner but on these small planes the CA is plenty strong. I'm sorry if that came across as rude
If it was a 25% I would recommend taking it apart and redoing it with epoxy.
Old Jul 16, 2012, 08:51 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
No problem Nate, not rude at all. that's the good thing about these forums, you can get more than one idea of how to do something. I agree if he hasn't cut out the servo hole the easiest would be to just put the servo on the other side. The slot in the elevator won't be noticed. Heck you can barely notice the patch I put on my 51" Slick where I cut out the wrong hole for the servo wires near the wing tube.
Old Jul 16, 2012, 08:58 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Thanks again guys
Yeah I have my elevator servo mount cut out on the port side (I had the thought of switching it - but I heard port side elevator is preferred). What is meant by 25%? CA strength?
I am hoping to learn alot by this build so subsequent planes I get will be a lot easier to assemble. I am not the handiest when it comes to work like this but I am hoping to get better.
Old Jul 16, 2012, 09:05 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Grovey, He meant a 25% scale plane, roughly 70 inches (71 slick, 72 Extra, 74 Edge.)
Watch the build videos from IPS Motors on Viemo or U-tube he does a real good job on them, plus he's a team pilot so you are getting good info there.
Old Jul 16, 2012, 09:21 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Thanks, yup, those are the build videos I am going through, he did warn of the CA running from the joiner stick slot, so I can understand the warning now
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
