Old Jul 03, 2012, 09:18 AM
fmw
fmw's Avatar
Joined Jul 2009
I'l give that a shot. I don't think I have any 14X7 but I do have some 13X6.5 props around here somewhere. I'm guessing about 40 amps. If so, that will be OK.
fmw is offline Find More Posts by fmw
Old Jul 03, 2012, 11:43 AM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
The 13 x 6.5 should do well. I have seen some guys have issues with the 14 x 7 due to prop strikes if landing on a grass field.
KE Spin is offline Find More Posts by KE Spin
Old Jul 03, 2012, 11:45 AM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
I fly off a grass field and have no issues with a 14x7 unless my temperamental wire gear decides to bend flat on me.
3Daddict is offline Find More Posts by 3Daddict
Old Jul 03, 2012, 11:51 AM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
Ok, I was starting to not like how this plane flew. Then I found I was to nose heavy, so I backed my battery back about half an inch and now she flies even better, not as good as the 47'' SHP but close. I am now doing snap to hovers an takeoff with ease and rolling harriers are a lot better on it. though I still can not get it to KE spin where as my 47'' SHP will do it all day long. I have tried everything with it adding a little aileron and what not with no luck. I think I might need to move my battery back a little more and see what happens. I am running the heavier Hacker A30-14L with 2200 MAH 3-cell 30c packs swinging a 14x7.
Old Jul 03, 2012, 02:53 PM
fmw
fmw's Avatar
Joined Jul 2009
Mine is a little nose heavy too. I need to relocate my receiver so I can push the battery further to the rear. The balance is perfect for a sport plane but a bit nose heavy for 3D with the motor I'm using. I have also had to straighten out the landing gear a few times. I'm thinking about soldering a brace between the struts.
Old Jul 03, 2012, 03:18 PM
TEAM K.G.B.
FIXXIN2FLY's Avatar
Roscoe, IL
Joined Jul 2008
mines seems to ke spin like no tomorrow. My batt placement is all the way back against the spar but Im using a Motrofly 2820-950
FIXXIN2FLY is online now Find More Posts by FIXXIN2FLY
Latest blog entry: The family continues to grow
Old Jul 03, 2012, 03:20 PM
Bad Mother Hucker
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
+1.
quadracer is offline Find More Posts by quadracer
Old Jul 03, 2012, 04:44 PM
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Did some experimenting with the gear today. Made some new out of the rod I bought yesterday still need to try to heat treat it. Got rid of the wheel pants as they keep coming loose and flopping around. Switched out the stock wheels for Dubro 2.5 inch Micro Sport Wheels # 250MS. Ran a piece of plastic cord from a set of disposable earplugs axle to axle on the stock gear with a bit of tension on it. That seemed to work well on keeping the stock wire from spreading apart. All these gear test went well then my new problem started.
When I went to pull out of a parachute/elevator at about 10 feet up punched the throttle and the motor crapped out after about a second. Had full control but no motor. No choice but to drop as softly as possible into 3 foot tall grass. Edge was fine no damage at all. ESC was going beep beep beep. Was about 4 minutes into the flight when this happened and battery had 11.82 volts left in it when I pulled it out. Checked everything I could think of but could find no problems. Put my 40c battery in and had a normal uneventful flight. OK put my newest 30c battery in and about 40 seconds into the flight the motor crapped out again. This time I had enough altitude to dead stick it on my landing area with only a slight gear bend. Could clearly hear beep beep beep as it glided past. After it landed just for giggles I gave it some throttle and the motor was working again. Taxied back and did some ground tests. All was fine until I got above 3/4 throttle. You could hear a click from the ESC as the motor cut out followed by beep beep beep. After 5 seconds or so you had power to the motor again and the beeping would quit until you went to full power again. What gives? Omega 130 motor, Castle Thunderbird 54 ESC, Hobbywing * amp external UBEC, APC 14x7E prop.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old Jul 03, 2012, 05:06 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
Ran out of space. I have about 150 flights on this combo with no problems until today. It was nearly 100 degrees out there when this happened. This is the hottest temp I have flown in yet. I will get it all hooked up to my power meter and do some static pulls later on tonight. Doing a bunch of updates on my notebook so I can use my Castle link to check the ESC. Anybody have any ideas what is going on? One thing I have noticed is my motor is and always has been tight, as in hard to turn by hand. Gave the bearings a squirt of WD-40 recently should I try some real oil? Motor was not hot either time it cut out. Have to wait until I do the power meter test to check the amps I guess.
Old Jul 03, 2012, 05:11 PM
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
If the esc is beeping that means you lost power, and it started up again. What caused the power to cut out I cant say without checking it out. Sounds like a short somewhere. Just guessing though.
3Dplank is offline Find More Posts by 3Dplank
Old Jul 03, 2012, 05:14 PM
Inverted-I-Fly's Avatar
United States, CA, Petaluma
Joined Mar 2011
cold solder joint at the esc, exact thing happen to a friend at the field today
Inverted-I-Fly is offline Find More Posts by Inverted-I-Fly
Old Jul 03, 2012, 05:17 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
Ah like I should check my crappy soldering jobs?
Old Jul 03, 2012, 05:21 PM
Joined Mar 2011
what connectors do you use?
Old Jul 03, 2012, 05:22 PM
Fly Naked !
Waynesboro VA USA
Joined Dec 2010
Deans and I have some trouble getting them soldered right.
Old Jul 03, 2012, 05:23 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'm in the process of switching all my stuff to Anderson Power Poles. MUCH easier to install.
turnerm is online now Find More Posts by turnerm
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
