If money were no object I'd current have on order: 58" Edge 57" Extra 59" Slick 71" Slick Ah... those would all compliment my current hangar quite nicely!!
SteveT |
Latest blog entry: My hangar...
I have a complaint about the wire landing gear, I landed my airraft perfect on the runway and the gear bent on me and shoved the wooden piece right into my fuse
. I riped the wooded things off and now it all seems fine. the wood made the wire to stiff and it wold not stop bending but now that I removed it it can flex and not bend. 3DHS designed this landing gear tarriably, I am vary dissapointed in this planes LG. the plane flies great but the gear is garbage.
The wire gear does bend, but also absorbs alot of abuse...just as it was designed to do. The wooden fairings make the wire gear a little stiffer and the secret was to cut the corner (that can hit the fuselage) of at a 45 degree angle or so for clearance.
If you are continuing to bend the gear that much then it is likely that you are landing on a grass field and your landing speed it too high. I have found that you need to hold off on touching down until the tail drops a little. Takes some time but you'll get it with practice. |
I am flying of a grass field, but is is vary short grass and always mowed. I tried cutting the ends off as you suggested first and the gear still bent becaues it was just to stiff, so I just removed the wooden pieces and now it can flex and does not bend. other than that the plane flies perfect.
| Thread Tools | |
| New Product 3DHS 41" Edge "$99 Buck Huck" | Ducati Mechanic | 3D Flying | 17299 | Mar 27, 2012 03:37 PM |
| Sold 3dhs 41' edge buck huck bnf | JBuck | Aircraft - Electric - Airplanes (FS/W) | 7 | Jul 02, 2011 06:58 AM |
| Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck | 6L6Amp | Aircraft - Electric - Airplanes (FS/W) | 14 | Aug 22, 2010 07:45 PM |
