Old May 07, 2012, 01:09 PM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
Originally Posted by NFA Fabrication View Post
I am about 10 flights into my 3DHS 48" Edge, and I love it! Except...
The landing gear, even on some very smooth landings, still bends... Is there any thoughts on converting this to the carbon fiber strut style that I see on other planes? I simply can't live with how it is, and will come up with something, but I figured I was not the only one, and there had to be some tried and true methods out there. Thanks for any advice!
agree 100%
a plane this size should never have wire gear. its just too heavy. although its nice for the rough landings, they still get bent with smooth landings. I dont think it would have been a problem if 3DHS would have put CF gear on this plane to start with. If I would have known this I would have went with a Slick.
big_poppa4904 is offline Find More Posts by big_poppa4904
Old May 07, 2012, 01:17 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Originally Posted by turnerm View Post
I'll measure my throw and let you know what I'm getting.
How much throw do you get using the 3DHS long servo arm? And what hole are you using?
About 45 with Stock arm maxed outer hole. Phenolic is one hole longer out from the stock hole.
heritageflyer is offline Find More Posts by heritageflyer
Old May 07, 2012, 02:05 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Hmmmm... maybe my issue is something else. I think the last time I measured I was getting over 50 degrees. The reason I think I'm getting blowback is because when I try to elevator down my nose drops.
Maybe it's a CG thing.
Mine does the same. I run the CG a bit forward as well. I've also found that now mine won't flat-spin without some throttle to pull the nose up a bit, probably also due to the CG being a little fore. When I had it more aft, it would flat spin no problem without throttle.
I flew a few packs Saturday, and did several "walls" about 10' from myself, the elevator didn't appear to blow back any at all.
quadracer is offline Find More Posts by quadracer
Old May 07, 2012, 02:07 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Cool. I think you guys have "solved" my problem. I used to fly with my battery/CG back quite a bit and I had forgotten about that. It's a simple test, I'll slide my battery back again and see how she behaves. I started moving it forward to get rid of wing rock in harriers. Just need to find a happy medium I guess because I love doing flat spins and elevators and stuff like that.
turnerm is offline Find More Posts by turnerm
Old May 07, 2012, 02:12 PM
quadracer's Avatar
Joined Feb 2012
The million dollar question, how do we cancel the wing rock AND still flatspin like a frisbee?
If anyone knows, SPILL THE BEANS!
Old May 07, 2012, 02:14 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
For that I think you need a set of Joe Smith thumbs...
Old May 07, 2012, 02:21 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Or a Joe Smith CG...unfortunately no longer available on Ebay....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old May 07, 2012, 02:25 PM
quadracer's Avatar
Joined Feb 2012
SteveT
Yeah, oddly enough, they're NOT listed on 3DHS' website, either.
Old May 07, 2012, 05:36 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Nope, I bought the last one, so they are "not in stock"....
SteveT
Old May 07, 2012, 06:01 PM
quadracer's Avatar
Joined Feb 2012
Anyhoo, I've been looking for a ~60" airframe to replace the outdated Fliton I've got. Just a simple electronics swap, and go for it. But lately, I've been tossing the idea around of selling that whole setup, and putting together a 30cc gasser. (likely a 74 Edge, maybe a Slick)
I'm only equipped for electrics right now, so what are some of the things I would be looking at hauling around (aside from the obvious, gas.) Is there more kit to pack around, or less?
Old May 07, 2012, 06:08 PM
theK2 is offline
Find More Posts by theK2
3D-wanna-B
theK2's Avatar
Lynchburg, VA
Joined Dec 2008
^ This post is likely better suited for the Fanatics thread. (not that it bothers me - but more gas pilots there)
theK2 is offline Find More Posts by theK2
Old May 07, 2012, 06:17 PM
quadracer's Avatar
Joined Feb 2012
True, I thought that's where I was....
While I'm here though, how much did the wire gear cost from 3DHS? I just shipped one to a guy, and have no idea what the price was, and of course, it's not on their site anymore. Thanks!
EDIT: Just found it on ADC's site.
Old May 07, 2012, 09:47 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
Turnerm, instead of removing the elevator horn and trimming it why not just drill another hole in it closer to the elevator? Sorry with the late reply and now I see you figured out it was CG related. That's the problem of sleeping in the afternoon and early evening. Might help someone else out though.
Between the wind; fog, cold, rain and drizzle I haven't flown the Edge since Wednesday and that bites. I killed my F-27C a few weeks ago so I currently have no foul weather flier. Sim is only slightly better than not flying at all. Looks like this Wednesday is good for the winds so maybe some stick time then.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
Old May 08, 2012, 06:24 AM
Olie is offline
Find More Posts by Olie
Serial Lurker
Australia, SA, Adelaide
Joined Sep 2007
Weather has been crapola down here in South Australia, so my maiden is still yet to happen. However this does mean that I have been buying up more bits for mine.
Todays Purchase:
PA 1.8" Carbon Spinner
Vox 14x7 Beech Prop
Looks the biz now.
(Click for larger)
Olie is offline Find More Posts by Olie
Old May 08, 2012, 08:01 AM
Joined Nov 2010
Todays Purchase:
Vox 14x7 Beech Prop
Looks the biz now.
(Click for larger)
how was that fit on the CF spinner? Any modification needed?
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 03:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 06:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 07:45 PM
