Sep 14, 2011, 12:14 PM
Charlotte, NC
Joined Jan 2011
Originally Posted by Fliprob17
*My plane seems to balloon quite a bit when cutting throttle. I've got my CG back at 90mm so I assume that it why. But it makes it tough to land. Should I add some more down thrust to my motor?
1. this is fairly typical of a lightly loaded 3D style airframe. If you are trimmed for level flight, hands off @ 60% throttle, and when you roll it inverted and do the same it ever so slightly noses down or remains level, don't mess with the CG. If it climbs inverted, then yes you are tail heavy. Learning to land this style airframe is the more important factor. Don't chop the throttle, don't flare, fly it to the ground and use the throttle to control it. You may need to ever so slightly keep the nose down until just before you are ready to reach terra firma.
*I couldn't get it to tumble very well. I'd take it way up high, kill throttle and then when it started to stall I'd give full down elevator and full throttle and it would simply do this small loops but it wasn't tumbling. My elevator throw is 45 degrees. Thoughts?
2. you need to have speed to tumble. Fly across horizontally at 3/4 throttle, and throw the sticks in opposite corners. Throttle stick off, full rudder one direction, full up on the elevator stick (down elevator) and matching aileron to rudder input.
*How DO you KE spin officially? When I did mine I tried to start a tumble and then I gave it full left rudder and wham... it was KE spinning tight and FAST! But like I said I couldn't replicate this.
3. you need to control the spin with throttle, that's what gets you into it consistently and controls how fast it spins.
*I'm currently flying a 12x6 prop. Will the 13x4 help with some of these maneuvers?
4. if you are running 4s stick with the 12x6
Thanks Rob. That's what I was thinking on the ballooning issue - I don't think I'm used to flying an airframe like this with an AFT CG. Most of my planes I just use elevator to control speed (on landing approach) and throttle to control decent rate and I usually come in at a nose up attitude. For this plane, you're exactly right - it feels like I have to push the nose to the ground (at least with the CG back at 90mm). On my maiden I had the CG more forward and it landed the way I'm used to. So this will just take practice I guess.
I think I used the wrong terminology on the tumble - what you described to me is what I think of as a snap roll. I was tying to do a waterfall type thing where the plane goes into a tail over nose type tumble. I was under the impression that I could do this will just throttle and elevator only (and maybe some rudder/aileron to keep it straight). But I read somewhere that I may have to modulate the throttle (on to get the nose up and then off during the downward tumble).
