Old Jul 11, 2011, 03:04 AM
ac333666 is offline
Find More Posts by ac333666
Joined Jan 2007
help my tx for walkera 4f200 got reset .
help my tx for walkera 4f200 got reset what do i do http://static.rcgroups.com/forums/im...lies/frown.gif
ac333666 is offline Find More Posts by ac333666
Old Jul 11, 2011, 05:53 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Link- http://www.rcgroups.com/forums/showp...&postcount=155
Bravo47 is offline Find More Posts by Bravo47
Old Jul 11, 2011, 08:49 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
basic settings for 4F200
First, choose a new slot on TX 2801, name it 4F200.
Begin to put all data shown here to appropriate function. Don't forget to save it before proceding with another input!
-STICK = Mode2
-COMPTB = 2801
-SWASH = 1 servo normal
-MDSET:
* REVERS: channel 1 & 2 reversed. All others are Normal
* GYRHLD: GYROSENS=90%
* DR & EXP: all ELEV, AIL, RUDDER: D/R=100% , EXP= LIN
* CURVES:
THRCURVE: NOR=0 ,1=25%, 2=50%, 3=75%, 4=100%
ST-1: 0=100%, 1=75%, 2=70%, 3=75%, 4=100%
ST-2: same as ST-1 above
PITCURVE: 0=36.5%, 1=51%, 2=65%, 3=74.5%, 4=84%
ST-1: 0=21,5%, 1=37,5%, 2=52,5%, 3=67,5%, 4=82.5%
HOLD: 0=0%, 1=25%, 2=50%, 3=75%, 4=100%
With these configurations, you can easyli fly it without hasle, just slowly throtle up about a few inches from ground, pay attention to forward/aft movement of heli ( FBL heli always tend to move back and forth a bit when hover near ground). Also slightly correct tail if there's some dragging on left( with tail in hovering). Never take off heli while using left/right input, this will cause 3aXis to react and will make heli tip over, resulting broken blades and stripping servos!just give enough throtle to make heli lift off a few inches then use cyclic sticks to correct.
However, if you're still afraid to handle heli, use the HOV.P/ FLAP switch on TX( top left) to increase pitch near max (all up), this will make heli less agressive and easier to fly.You can leave it as is or return it to midle once dominate heli.
note: always activate timer on TX between 4~5' flight for better Lipo's life and crash prevention. Stock lipo is 5' sport fly.
2011/Jan/27
ALWAYSCRASH
Alwayscrash is offline Find More Posts by Alwayscrash
Discussion Got my Swamp Dawg.... But need help programing my DX6i hotrodder Racing Boats - Electric 4 Dec 11, 2011 09:56 AM
Discussion Got my new plane! Getting ready for maiden, question about cg, need help please. cfiiman Electric Plane Talk 5 Jun 07, 2011 11:10 AM
Found Used Tx for my Walkera CB-180Z, or combo package jjetmec Aircraft - Electric - Helis (FS/W) 4 May 19, 2011 04:34 PM
Question walkera 4f200 stock setup on a tx 2801 pro xx_vengeful_xx Micro Helis 1 Mar 26, 2011 08:43 PM
Help! Walkera 4F200 - change of Main Gear HM-4F200-7-09 JumboA5 Micro Helis 1 Dec 27, 2010 12:46 PM
