Old Aug 04, 2011, 02:29 PM
Mactadpole is offline
Find More Posts by Mactadpole
San Marcos, TX
Joined Jan 2010
Originally Posted by Mactadpole View Post
Rusty,
It would be great if you offered some CF (or G10) center plates that were a little bigger than your 6.5" plates so that landing gear like the Droidworx's could be easily mounted. I am not near my copter at the moment so can't give you the size but I think around 7.5" would do it, or even 8" to round it out. The larger diameter would also provide a little more space for all the stuff that tends to get added to heavy-lift machines. I am thinking how nice it would be to make a heavy lift X8 or even flat octo using your center plates and 5/8" arm mounts that would let me easily attach my DW landing gear with camera gimbal. I think you could capture those who want to give a heavy lifter for APV a try but don't want to spend $1000 on the frame alone. I think a lot of folks are willing to spend the money on the expensive gimbal/landing gear but can't afford the expensive frame too. Even if its a little heaver who cares. If APV seems to be something the user decides they want to pursue further then they can buy the $1000+ frame.
What do you think?
Shawn
Or, how about an adapter plate('s) out of g10 that would allow us to mount the DW landing gear to your existing center plates? That is what I am trying to figure out how to do right now. Sure would love it I could just order some from your shop!
Shawn
Mactadpole is offline Find More Posts by Mactadpole
Old Aug 04, 2011, 09:51 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
I ordered some of your motor mounts recently for my 12mm round tube frame. Turns out the mounts were the best part of the frame, the rest is crap. That's what I get for trying some el-cheapo foldable frame.
Anyway, I build most of my quads using the square aluminum towel bars you can get from home depot. I think they say they're 1/2" square but like most things the actual size is 5/8" square. I see you have 5/8" round delrin blocks but do you have anything that will fit the 5/8" square aluminum towel bars?
Like these:
http://www.homedepot.com/h_d1/N-5yc1...kuId=202619692
I really want one of your frames but prefer square arms to the round ones. Or I guess I could ask where people are getting the square arms that fit your current 1/2" blocks? The only thing I can find that measures 0.498" is wood.
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Aug 04, 2011, 09:57 PM
San Marcos, TX
Joined Jan 2010
Like these:
Paul
Hi Paul,
Here where I get mine: http://www.metalsdepot.com/products/...ge=tube&LimAcc. First ones in the list.
Shawn
Old Aug 04, 2011, 10:11 PM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Shawn
Hi Shawn,
The funny thing is that I was planning to reduce the diameter of the next frame from 6.5" to 6.25". I just can't imagine 8", but it's certainly doable if needed.
Adapters are very doable, and if anyone has a camera mount, landing gear, etc that they want to mount, all I need to know is the hole mounting pattern. I'll be happy to make an adapter mount for just about anything.
Cheers,
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Aug 04, 2011, 10:12 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Originally Posted by SeismicCWave View Post
Rusty,
Here are pictures of your Rev 7 frame.
Thanks for the pics, but I'm voiding your warranty on those gear legs
Rusty
Site Sponsor
Old Aug 04, 2011, 10:20 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Paul
Hi Paul,
Amazingly, this is the second time today that someone has mentioned using the 5/8" towel bars. The current Rev-8 plates will almost work without blocks, since the hole spacing is just about 5/8" between the screws. It's just a little bit too big, but with a thin spacer it might work.
A while back, when I decided to make a square tube block, I asked on the forum about the most popular size. I expected it to be 5/8", but I was surprised to find out that 1/2" was more commonly requested.
I believe a 5/8" square block is possible, and if there's really that much interest, I can probably make them available.
Cheers,
Rusty
Site Sponsor
Old Aug 04, 2011, 10:54 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Rusty
LOL, they are just a quick way to take off for now. I will figure out something a bit nicer soon. Three carbon bows bolted to the bottom of the center plate will be nice and light.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Aug 04, 2011, 10:56 PM
AMA 46133
Hawaii
Joined Feb 2003
Hi Paul,
Cheers,
Rusty
Those towel racks are nice and light because they have thin wall. At 5/8" they can be pretty nice and strong for a larger multi rotor.
If I can find thin wall 1/2" square tube I will use that in a heart beat. Unfortunately the 1/2" aluminum tube I found has been very thick wall and heavy.
Old Aug 04, 2011, 11:08 PM
aka Helidaho
Joined Jun 2010
Thanks Shawn for that source, looks like a good deal. However, I like having the ability to run down to home depot on a whim and grab replacement arms and be back up and running in the same day. Plus the towel bars are only 1/32" thick instead of 1/16" so I would think they are much lighter... not sure on that though since they are larger.
Just thinking out loud...
Rusty, if you could come up with a foldable quad frame with 5/8" square blocks that would be great! Is that asking too much? hehe
I guess the next choice would be the 450 tail booms, those tend to be available locally.
Paul
Old Aug 04, 2011, 11:37 PM
San Marcos, TX
Joined Jan 2010
Paul
From the Mega Link Index:
Arms material:
--15mm square Towel bar: 2.7g/in @ $.20/in -Lowes, Home Depot
--13mm x .03mm (1/2x.016in) Alum tubing: 1.2g/in @ $.13/in -http://www.hobbylinc.com/htm/k+s/k+s9413.htm and http://www.metalsdepot.com/products/...ge=tube&LimAcc=
While 15mm doesn't equal 5/8" (~1/32" smaller, so maybe same thing), if those weights are correct then the 1/2" is lighter than the 5/8".
I have used the 1/2" for a while now, even with the 2814/22 size motors. I am actually putting together a Y6 with Rusty's 1/2" square motor mounts and 2814/22's right now. If those 1/2" arms successfully handle a coax setup with those motors then I'd stick with the 1/2" because of weight.
Metals Depot ships fast and its pretty cheap. I have placed two orders with them for 4 -48" pieces and then cut what I need and a few extras. I leave the rest in the shipping tube in the corner of a closet for when I need more.
Shawn
Edit: I have also crashed and not had the 1/2" bend on me. When it has, I have been able to bend it back into place pretty well and continue flying before.
Old Aug 04, 2011, 11:41 PM
San Marcos, TX
Joined Jan 2010
Hi Shawn,
Cheers,
Rusty
I will take a look this weekend and see if I can come up with something to submit to you.
Thanks, Shawn
Old Aug 05, 2011, 09:52 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Gents,
Shawn,
Your post made me question those measurements that were supplied to me. I just made corrections to the towel bar measurements in the Mega Index since I now have towel bars to do so I would appreciate if you or someone out there please check the weight of the Alum tubing you have as that looks a bit light to me too as I'm sure the Trex tubing which I also do have and remeasured should certainly be lighter than that aluminum tubing.
--15mm x .4mm (5/8 x.016in) square Towel bar: 2.35g/in @ $.20/in -Lowes, Home Depot
--13mm x .3mm (1/2x.016in) Alum tubing: 1.2g/in @ $.13/in -http://www.hobbylinc.com/htm/k+s/k+s9413.htm and http://www.metalsdepot.com/products/...ge=tube&LimAcc=
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Arms material:
Shawn
jesolins is offline Find More Posts by jesolins
Old Aug 05, 2011, 10:37 AM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
Hey Rusty I am one of the people emailed about using towel rack, if you do the blocks for the 5/8" bar I want one. If not the sandwich idea may come to light.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Aug 05, 2011, 11:01 AM
cyberdog is offline
Find More Posts by cyberdog
Sweden, Norrbotten County
Joined Jun 2007
Had to try out your landinggear so ordered a set
cyberdog is offline Find More Posts by cyberdog
Old Aug 05, 2011, 11:02 AM
aka Helidaho
Joined Jun 2010
Michael64
I second the 5/8" square tube blocks! I would buy a whole mess of them for all my quads Okay maybe 16 to 20 or so... Plus a frame.
Paul
New Product Rusty's Rev-8 Frame Kit 13brv3 Multirotor Talk 19 Mar 12, 2015 09:03 AM
New Product Rusty's Cheap DIY Frame Parts 13brv3 Multirotor Talk 22 Dec 05, 2010 12:16 AM
Alert SOLD- Quadcopter-ARF-Rusty's Rev-7 frame, QP FC board, + extras - US $300 shipped Mactadpole Multirotor Talk 3 Oct 12, 2010 10:16 PM
Sold Quadcopter-ARF-Rusty's Rev-7 frame, Quadpowered FC board, + extras - US $300 shipped Mactadpole Aircraft - Electric - Helis (FS/W) 2 Oct 12, 2010 01:23 PM
Question What Landing Gear for Rusty's Frame? (Or any frame) Zirt57 Multirotor Talk 16 Aug 05, 2010 02:30 PM
