Old Feb 09, 2013, 08:55 PM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
The UAP2 is here!
Greetings,
One thing led to another, and the task of adding the UAP2 ended up being a huge task. Probably 75% of the items on the shop ended up being modified in some way, and I've spent nearly the whole week trying to get this straightened out. I ended up making new builders manuals for both the UAP1, and UAP2, but don't expect to see correct pictures for all the frame configurations anytime soon
Biggest news is the UAP2 kit is now online! This is something people have wanted for a while, and now it's (finally) here. The kit uses larger 8-1/8" plates, larger 21.5mm tubes, and is actually cheaper than the UAP1 used to be!!!
The other significant bit of news is that the UAP1 kit has been reconfigured. I've reduced the kits to 3 main plates, rather than 4, since the UAP2 will be the choice for anyone wanting more plate space to put gear. That helped with the price, but I've also reduced the UAP1 block prices, so the overall UAP1 kit prices have gone way down. The kits now include removable arm blocks standard, since they also help with frame stiffness.
The CF tubes are really news now, but all sizes are listed. It's funny how small the 16mm tubes look now that I'm used to handling the 21.5mm size.
Cheers,
Rusty (AQ testing is next in the queue)
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Feb 11, 2013, 10:35 AM
BayAreaCrasher is offline
Find More Posts by BayAreaCrasher
BayAreaCrasher's Avatar
Joined Feb 2011
congrats Rusty! that is awesome. your frame continues to be my favorite "it can be anything you want" frame.
so to be clear, the UAP1 is just a "larger UAP1" with larger tubes right?
BayAreaCrasher is offline Find More Posts by BayAreaCrasher
Old Feb 11, 2013, 12:22 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
>>so to be clear, the UAP1 is just a "larger UAP1" with larger tubes right?<<
LOL Rusty better not hear that. He spent months trying to figure out how to make the UAP2. Well yes, it is another frame with center plates, boom blocks and arms. However the UAP2 gave Rusty some challenges. Most of them just flew over my head. So I would have to think that he did put quite a bit of thoughts into the UAP2. It is most likely not simply an enlargement of the UAP1.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Feb 11, 2013, 12:24 PM
Joined Feb 2011
Sorry, didn't mean to seem like it was just a larger version. I'm sure a ton of work went into the new design. I was just reading from the site and couldn't quite tell all the differences, that's all
Old Feb 11, 2013, 12:39 PM
mattchase is offline
Find More Posts by mattchase
United States, TX, Seguin
Joined Mar 2005
I would have must stuck my copter on a copy machine and set it to enlarge. But then that's probably why I'm not designing frames.
Hmm, I wonder how much weight a paper copter could handle...
mattchase is offline Find More Posts by mattchase
Old Feb 11, 2013, 01:15 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
This looks great. I love the extra space and rigidity this frame is going to allow. Time to convert my current y6 to a smaller quad for my autoquad board + BL gopro gimbal and a bigger Y6 with this frame and my HF Pro.
jcmonty is offline Find More Posts by jcmonty
Old Feb 11, 2013, 08:57 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
The funny thing is that my first version of larger plates was just an enlarged version. Then I scrapped it, and went to different layouts, then ultimately scrapped those and went back to the original. So yes, it IS just a larger version, but I did trash a couple hundred dollars of material trying other ideas before confirming that's what I wanted to do
Don't get me started on the blocks... I've made 4 versions, and killed quite a few Delrins along the way.
Rusty (frantically cutting blocks as I type)
Site Sponsor
Old Feb 11, 2013, 10:46 PM
jcmonty is offline
Joined Apr 2012
Rusty, I just saw that you have a PDB available. Have you tested that to it's upper limits and know what that is?
Old Feb 12, 2013, 01:06 AM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
The current limit of the PDB is a common question, with no good answer. It all depends on how you solder the wires. If you put them as far apart as possible, it won't have the current limit that it will if you put them all near each other in the same big pile of solder.
I solder the battery in the center, and the ESCs around the edge, and it's been no problem for Avrotos. That being said, I'm going to be switching from 1oz copper PCB to 2oz on the next batch, so maybe I can advertise "double the current capacity". At least it's an honest claim
Rusty
Site Sponsor
Old Feb 13, 2013, 02:54 PM
photism is offline
Find More Posts by photism
photism's Avatar
United States, AK, Homer
Joined Dec 2012
Hi all. I've been spending an unreasonable amount of time reading on this and other forums. Thanks to all of you for sharing so much knowledge. It's very overwhelming and interesting!
I'm about to build my first multirotor after flying a blade mqx around for a few weeks. I've decided to build the UAP2 Y6 and UG-1 2 axis gimbal. I'll be shooting still photos with a GH3 and also play/practice with video. After considering many different frame options and budget ranges I like the concept behind Rusty's frames. Tough, simple, well supported, and flexible. Seems like a great way to get started for me - something easy and inexpensive to repair!
I have a couple questions, not surprisingly.
- For those of you flying a rusty Y6, roughly how long does it take to disassemble the frame if I needed to pack it into a pelican case. I'm thinking just removing the landing gear, UG-1 gimbal, and arms should be enough. Is the UAP2 frame quicker to disassemble?
- I've attached a graphic of my shopping cart from Rusty's site. I just placed the order but if you see anything I missed or mismatched please let me know. I have 7 avroto 2814 motors, 6 rc timer 30A ESCs, and 8 APC 12x3.8 slow flyer props coming from another rcgroups user.
And if you would be so kind, I'd really appreciate suggestions on the rest of the gear I'm going to be needing as well. I'm pretty much starting from scratch except I picked up a DX7s and a full MK okto XL electronics package (2 x FC, GPS w/shield, Navi ctrl, BL, PD board etc) on a great deal which I'm thinking I should just sell and get something like a Naza, Hoverfly or APM 2.5.
The other little items I know I'll be needing:
- battery charger and power supply
- batteries (sounds like this zippy 4s 45C 5000mah is a good choice) I think I'll go for 4 batteries.
- servos for the gimbal (I'll try and sort this out on the rusticwave gimbal thread I guess)
- receiver for my radio
- Transmitter/receiver for the camera's view
- Display for camera view (would like to mount on my radio)
- What else am I missing? I'm sure plenty!
If you know of any good build logs that are similar to what I'm doing, I'd appreciate the link. I know much of this has been discussed before but it can be hard for a beginner like me to decipher what is and is not applicable to my goals.
Thanks again for all of your help.
photism is offline Find More Posts by photism
Old Feb 13, 2013, 03:08 PM
Ryan5508 is offline
Find More Posts by Ryan5508
Ryan5508's Avatar
United States, MI, Wyoming
Joined Dec 2012
The woman has given me the go ahead to Build an X8 UAP2. She plans on purchasing a Zenmuse for a gimbal (I was going to get a AG600/700). For those familiar with both do I need a Damper kit? and if so what one would be recommended?
Also need some advice on what legs/landing gear.
I was also originally looking at Avroto 2814 or Tiger motors MT3515-15 and ZTW 30A ESC- SimonK but I'm open to suggestions.
Feel free to point me in any direction I have a month to plan this build out
CF Tube 21.5mm x 19.5mm Length: 13 inches (330 mm)
PD-1 Power Distribution
UAP2 X8 Frame-Motor Mount Type: Anti-Vibration Mounts (Avroto)
UAP 8 Damper Kit?
Ryan5508 is offline Find More Posts by Ryan5508
Old Feb 14, 2013, 01:26 AM
Ryan5508 is offline
Ryan5508's Avatar
Joined Dec 2012
Using Tiger MT3515-15 with 6s lipo
Old Feb 14, 2013, 11:28 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
I dont know about that UAP2, but with the UAP1 the arm mounts are sort of thecore of the frame structure. Depending on how you put the center sections together and what electronics are mounted you might not be able to access the screws for the arm blocks without removing a few layers of plates above it. If you can get to the blocks and pull the arms out I suppose it would be simple enough to replace the arms with some dowels of the same diameter to keep the center section rigid.
epyonxero is offline Find More Posts by epyonxero
Old Feb 14, 2013, 09:48 PM
Mike SF is offline
Find More Posts by Mike SF
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
I put all my electronics on an extra plate above the core section and use Mini Deans for all wires between the sections. This makes it easy to remove the top section and then have good access to the screws that hold the arms. Make sure you use the removable arm blocks. It just takes a few minutes then to disassemble and reassemble the arms.
Mike SF is offline Find More Posts by Mike SF
Latest blog entry: Video: an abandoned shipyard
Old Feb 14, 2013, 10:21 PM
Mike SF is offline
Mike SF's Avatar
Joined Sep 2011
This is clearly a big project you are jumping into. Make sure you don't under estimate the time you need to make all of this work.
Once you have the copter flying and got a feeling for it, you might want to try Graupner 11x5. They are much more expensive, but easy to balance, less vibrations and less noisy. They produce a little less thrust though.
You need a lot of big batteries and probably want to charge them fast in your job. You will need enough power to supply appropriate charge rates. Check out the Cellpro PowerLab 6 EC5 Combo 7 that let you charge multiple (same type) batteries at the same time. You can get a good but cheap power supply from here. Choose the 24V47A power supply.
Battery capacity depend a lot on your weight, motors and props. Adding more battery capacity will not increase flight time at some point, so there is an optimum for each copter. To save some money, I suggest you just buy two of the batteries first (maybe even smaller ones like 4000mAh). Then once you are flying and know your final payload, record the flight time and add some extra weight to simulate additional battery weight. Calculate what the 'extra' battery capacity will bring you in flight time and then decide on your final batteries.
I'm using 2x4000mAh Nano Tech 35C lips with Avroto, 11x5 Graupners and 4kg/9lbs on my Y6 which gives me around 7 min. flight time with 20-25% left in the batteries.
I'm using Immersion RC 5.8 GHz, 600 mW Tx and the Immersion Duo 5800 Rx with 5.8 GHz Circular Wireless Long Range Antenna Combo (ReadyMadeRC). Works pretty well. If you want to use your camera HDMI port, you need an HDMI converter.
Display for camera view (would like to mount on my radio).
I'm using the Pirate Eye video classes and really like them. You can fly LOS and still see the video image, or you can fly whole FPV sessions by closing your left eye. The advantage compared to std. googles is that you can easily look down at your radio when you need to use some of your switches or knobs, e.g. for the camera tilt. With FPV googles you are kind of blind, which at least for me I found difficult. When you fly over water and your adrenaline is up, you easily hit the wrong switch
New Product Rusty's Rev-8 Frame Kit 13brv3 Multirotor Talk 19 Mar 12, 2015 10:03 AM
New Product Rusty's Cheap DIY Frame Parts 13brv3 Multirotor Talk 22 Dec 05, 2010 01:16 AM
Alert SOLD- Quadcopter-ARF-Rusty's Rev-7 frame, QP FC board, + extras - US $300 shipped Mactadpole Multirotor Talk 3 Oct 12, 2010 11:16 PM
Sold Quadcopter-ARF-Rusty's Rev-7 frame, Quadpowered FC board, + extras - US $300 shipped Mactadpole Aircraft - Electric - Helis (FS/W) 2 Oct 12, 2010 02:23 PM
Question What Landing Gear for Rusty's Frame? (Or any frame) Zirt57 Multirotor Talk 16 Aug 05, 2010 03:30 PM
