Old Jan 08, 2013, 12:08 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Ok...here is my newest rendition of the rusty frame...need to clean up the wiring and get some matching props...but i will be using wooden props in the end...
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Jan 08, 2013, 12:34 AM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Originally Posted by featherodd View Post
So around 15-16" booms?
Yes, I was actually stuck with 15" booms when I used to get the 30" carbon weave tubes. I use the motor mount with the vibration isolator and that brings the motors in 1/2" each boom so my motor to motor distance is 29".
SeismicCWave is offline Find More Posts by SeismicCWave
Old Jan 08, 2013, 07:25 AM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Interesting battery mounts. I might have to try that. I also like the makeshift gear leg plates
Cheers,
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Jan 08, 2013, 08:45 AM
Joined Apr 2011
Cheers,
Rusty
Thanks rusty...yea...want to see if the side saddle battery mounts will work...and i only had 3 of the tube leg mounts...so i will be ordering a set art the end of the week probably...but that should work for now...
Old Jan 13, 2013, 04:11 AM
featherodd is offline
Find More Posts by featherodd
Canada, BC, Bowen Island
Joined Sep 2012
If using Rusty's Universal Anti-Vibration Mounts with a UAP-1 setup as a Y6, is it ok to put two mounts onto one Delrin block? (top & bottom)
featherodd is offline Find More Posts by featherodd
Old Jan 13, 2013, 09:14 AM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Sure, one block is fine. That's all I use for any coaxial setup, and the anti-vibration mounts are actually less of a strain on the block.
Rusty
Site Sponsor
Old Jan 13, 2013, 04:26 PM
jxvot is online now
Find More Posts by jxvot
Joined Jan 2012
Rusty have your seen this Super Simple Gimbal?
I came across this today and amazed by the ideas that come out of RCGroups!
http://www.rcgroups.com/forums/showthread.php?t=1793759
The pieces would look to be easy to cut and you could offer additional gimbal solution at a fraction of the cost for your frames...
Hats off to Crezzee design... amazing and simple!
jxvot is online now Find More Posts by jxvot
Old Jan 13, 2013, 04:28 PM
jcmonty is offline
Find More Posts by jcmonty
Joined Apr 2012
I saw that thread as well and am comptemplating it for my small FPV quad. I just want to be able to change my APM code to do the mixing rather than get a KK board.
I would support Rusty cutting parts
jcmonty is offline Find More Posts by jcmonty
Old Jan 13, 2013, 06:57 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
I saw that when it was first posted. It's definitely simple and clever, but not likely something I'd make. Fortunately, it's simple enough that anyone should be able to make their own.
Cheers,
Rusty
Site Sponsor
Old Jan 13, 2013, 07:56 PM
Mactadpole is offline
Find More Posts by Mactadpole
San Marcos, TX
Joined Jan 2010
Recent updates to asymmetrical X8 on Rusty's UAP-1
Finally got around to adding Rusty's leg mounts with CF tube. Much more rigid and stable than my previous G-10 Cinestar style legs. And I saved almost 200g in weight. The rest of the updates were mostly electrical like a second battery connection from the power distribution board and an extension-PCB for lighting and camera trigger. I changed up the mixer so that motors 1&2 are on arm 1 and motor 3&4 are on arm 2 and so on. I also managed to get MK electronics stack lower. The pics are without its hood. Need to tidy up some wiring but otherwise it is ready to go. Flew it today with two 4s 5800mah batteries and got almost 16 min just hovering at 15-20'. Figure I'll still get around 12 min. with GH2 mounted.
Shawn
Mactadpole is offline Find More Posts by Mactadpole
Old Jan 13, 2013, 09:14 PM
dcoplan is offline
Find More Posts by dcoplan
Joined Aug 2012
This is a bit off topic, but I'm thinking of getting a cheap ready-to-fly quad that I can use to practice more aggressive maneuvers, nose-in flying, etc. so I'm more comfortable when I take my Rusty quad up in the air. Something that would be ok indoors but is also ok to fly outside in a light breeze. Blade has the mQX for $150 but I'm also seeing 4-channel quads for as little as $40 like the Syma X1. Any of you have suggestions based on experience with these things?
I use a sim on my computer but I'm thinking that actual flying will provide a better way of practicing.
dcoplan is offline Find More Posts by dcoplan
Old Jan 13, 2013, 11:53 PM
Joined Sep 2012
WLToys v949 is a deadly little quad that will natively bind with the 9x radios stock modules. The v929 is the older version without the super chinese LEDz. Both are clones of the Blade mQX and I believe spare parts are interchangeable. They have BNF versions of both the 949 and 929, as well a much smaller quad the v939 ladybug and a fantastic little single rotor heli, the v911. All will bind with a 9x radio's stock module and they're all fantastic.
The default software of the 9x is a mess, so it's strongly recommended to flash it with latest er9x (or Open9x) firmware. For this, the SmartieParts programming board is the easiest but you can also simply use a USBasp (tutorial). The the new version of the 9x, the 9XR, already has er9x preinstalled and has an easily accessible programming port, but it is currently out of stock and doesn't come with the a compatible module. I believe you can pick up this module on ebay and use it to bind a 9XR with the v9xx series models.
If you already have a DSM compatible radio like a Spektrum, you might want to stick with the Blade though a 9x radio and a couple BNF clones are similar in price.
Another option is a decent programable DEVO radio plus Walkera's BNF models. Their stuff a bit more expensive but the latest Deviation firmware could make their supported DEVO radios quite a bit more interesting.
Old Jan 16, 2013, 12:32 PM
janoots2 is online now
Find More Posts by janoots2
janoots2's Avatar
Joined Jan 2012
Sweet setup Mactadpole! Where did you find those (metal?) black standoffs that flange out on the ends?
janoots2 is online now Find More Posts by janoots2
Old Jan 16, 2013, 12:44 PM
janoots2's Avatar
Joined Jan 2012
Hey Rusty, any thoughts on adding something like this to your product line? I've been looking for a way to mount my gps centered and on top of my rig above my battery. The top could be designed to accommodate the different flight controllers' GPS designs. A "universal GPS mount/roll over cage" if you will. Inset on the top though to protect the gps and then the cage would protect whatever you decide to put under it from a roll over. I'd buy one :-)
Description:
Old Jan 16, 2013, 01:22 PM
13brv3 is offline
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Man, I'd better check my workshop for hidden cameras
The bad news is that I made these mostly for crash protection, and after smashing a few in drop tests, I wasn't happy, so I scrapped the idea. They also use tab-in-slot construction which I try to avoid at all costs. The variation in G10 thickness just makes it impossible to maintain any decent fit with tabs and slots.
Lots of people are starting to put GPS antennas on the arms, or just on an accessory plate mounted to some unused block holes on the center plate.
Rusty
Site Sponsor
New Product Rusty's Rev-8 Frame Kit 13brv3 Multirotor Talk 19 Mar 12, 2015 09:03 AM
New Product Rusty's Cheap DIY Frame Parts 13brv3 Multirotor Talk 22 Dec 05, 2010 12:16 AM
Alert SOLD- Quadcopter-ARF-Rusty's Rev-7 frame, QP FC board, + extras - US $300 shipped Mactadpole Multirotor Talk 3 Oct 12, 2010 10:16 PM
Sold Quadcopter-ARF-Rusty's Rev-7 frame, Quadpowered FC board, + extras - US $300 shipped Mactadpole Aircraft - Electric - Helis (FS/W) 2 Oct 12, 2010 01:23 PM
Question What Landing Gear for Rusty's Frame? (Or any frame) Zirt57 Multirotor Talk 16 Aug 05, 2010 02:30 PM
