Old Jan 21, 2012, 02:18 PM
Tom Harper is online now
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Second Flights
Norm et al,
Beautiful morning!
I removed the ballast from the right wing. It still has a little roll to the right.
Do not have all the data yet, but it looks like 8 Amp cruise at 60 kmh is likely. Max speed was 100 kmh and stall is 25 kmh. 50 to 60 kmh cruise is comfortable.
Norm's NM57 is excellent for this application.
Will probably try some auto flights tomorrow.
Tom
Tom Harper is online now Find More Posts by Tom Harper
Old Jan 21, 2012, 02:20 PM
kcaldwel is offline
Find More Posts by kcaldwel
_______________
kcaldwel's Avatar
Joined Jan 2007
Nice!
I like to see something besides the same old planforms out there flying.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Jan 21, 2012, 02:35 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Kevin,
It leaves the ground at about 1/3 throttle. So, I think we will be able to hand launch - after developing some confidence.
Tom
Old Jan 22, 2012, 06:44 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
The wind is howling this morning, so flights are unlikely.
Tom
Old Jan 22, 2012, 02:33 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Glad it's turned out well so far and I hope this plane makes a good photo platform. Concerning the heavy wing issue: Nobody likes non functional ballast so maybe you could increase the area of the heavy wing. Either by increasing the chord of the aileron or the wing span by gluing a tip extension on. Of course it would increases the spar bending moment but that shouldn't be too hard for you to deal with.
I'd probably just put a strip of fiber reinforced tape across the center on the bottom, but I'm a butcher
--Norm
nmasters is online now Find More Posts by nmasters
Old Jan 22, 2012, 02:49 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Norm,
The tip ballast is small.
I removed the right wing tip ballast and that lessened the roll. However you can see in photos 1 and 2 above that the left aileron is still deflected upward.
Removing the right wing ballast moves the CG toward the thrustline. As an experiment I will add ballast to the left tip until the roll force is gone. I suspect that will happen when the CG is on the thrustline. That would mean that the added wing area to the right of the thrustline is carrying the weight of the pod. In that case it really is asymmetrical.
My original assumption was that the CG would be at the half span point.
Tom
Old Jan 22, 2012, 05:26 PM
Brandano is offline
Find More Posts by Brandano
Then the proper "cure" would be to increase the span of the right wing and decrease that of the left wing, I guess. Something for the next iteration?
Brandano is offline Find More Posts by Brandano
Old Jan 22, 2012, 05:37 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
That is essentially what happens when I move the CG left to the thrustline.
We can fondle the numbers when I get it balanced.
Tom
Old Feb 12, 2012, 09:47 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
I added a ballast box to the left wing tip. I'll add lead shot until it does not require roll trim. It looks like the CG is going to approach the thrust line. It will be interesting to analyze the result.
Weather's bad, but hope to fly this weekend.
Tom
Old Feb 16, 2012, 05:49 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Add span to the right panel
I did some sketches and played with the layout and came to the same conclusion as Norm in #125. I need to add span to the Pod side wing panel. So, I'm building a 7 inch section to add to the tip. I should be able to complete it by tomorrow and fly Saturday morning.
Tom
Old Feb 16, 2012, 09:41 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
That's bigger than I would have guessed.
Old Feb 16, 2012, 11:34 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
To go along with the asymmetry theme, a winglet on the right tip would be interesting (I'm assuming you're looking for more lift on the right wing).
DPATE is offline Find More Posts by DPATE
Old Feb 16, 2012, 11:41 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
That would add a jaunty touch
Old Feb 17, 2012, 06:34 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Norm,
I probably overkilled it, but I'll have another data point. If it's too much I can trim the added section to the center rib.
I intend to add tip plates after I have good performance data. Be interesting to see if they make any difference.
Tom
Old Feb 17, 2012, 02:54 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Extension
Not perfect, but a reasonable match.
Tom
Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? rampa202 Coaxial Helicopters 52 Nov 26, 2011 09:58 PM
Discussion AP Full Arducopter UAV Gasser Build. ben1101 Aerial Photography 6 Oct 31, 2011 05:56 AM
Build Log AP UAV like plane , using 10g BL Prime_8 Foamies (Scratchbuilt) 9 Jun 10, 2011 12:51 AM
Small UAV for AP? New project! icebear Aerial Photography 47 Jun 12, 2005 08:51 PM
Asymmetrical AP-plane out of depron century_series Foamies (Kits) 31 Sep 09, 2004 02:49 AM
