Old Dec 04, 2011, 05:43 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I've flown an Easy Glider and an Easy Star with a camera pod offset to the right with no problems..
The pod contains the receiver and video camera from an LT-711 helicopter.
VGA image, but no sound... bummer.
The inverted vee-tail makes for very smooth non-jerky turns.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 05, 2011, 12:38 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
Did you add weight to compensate for the camera pod?
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Dec 05, 2011, 12:45 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
I did at first, but found the launch speed had to be quite high.
Neither plane really needed it.
On your plane, I'd try a landing gear for the first flight..
Old Dec 05, 2011, 05:33 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Oooops!
Checked the CG and found a real problem. My calculations were way off. The nose moment was too short to allow a reasonable amount of lead to bring it into balance.
I unloaded it and found the actual CG of the structure - then recalculated. The spreadsheet says the nose needs another 6 inches.
Hmmm...it did look kind of short. So it got a nose job (6" extension) with a long battery box. I can slide the Lipo fore and aft without any lateral impact. Also, moved the 5V regulator forward. The result is that it balances, without ballast, at an AUW of 80 ounces even. I will add a small ballast box on the right wing tip for trim.
At 80 ounces (includes camera) the wing loading is 15 oz/ sq ft. 12 oz if you include the pod in the wing area.
It could make sense to rig a take-off gear for initial tests. I'll see what I can do. That's not a problem for a few days 'cause we got 8" of snow last night.
Tom
Old Dec 06, 2011, 03:10 PM
Brandano is online now
Find More Posts by Brandano
Then you will need landing skids instead
Brandano is online now Find More Posts by Brandano
Old Dec 06, 2011, 04:18 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Takeoff skids....
Landings are mandatory, takeoffs can be (very) optional!
Old Dec 18, 2011, 05:13 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Lg
Rigged a landing gear by attaching a ply plate to the underside with rubber bands around the fuselage and pod.
Might get to fly it this week.
Tom
Old Dec 18, 2011, 10:43 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Looks great Tom!
How much longer is the nose? I like it that way.
Looking forward to your maiden results.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Dec 19, 2011, 03:10 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
I added 6 inches to get the CG right.
Tom
Old Dec 21, 2011, 04:37 PM
tete is offline
Find More Posts by tete
Joined Sep 2008
Hi lads,
I just ran into this interesting thread and decided to
enclose a couple of photos showing my simple solution for camera underwing pods
The senior telemaster pic dates from 1994 and has in addition to the video camera (old supercircuits B&W job) a Ricoh SLR 35mm camera bolted to the fuselage on the opposite side. Final balancing is done with a lead weight at wing tip. Both cameras pan 90 degrees (down to straight ahead) The servo for the video cam is inside pod.
I have no problem handling the asymetrical drag with rudder trim.
I have also used the same video camera concept on telemaster 40
The Vamp picture shows same idea on newer bird
With the newer small format cameras and tiny 9g sevos I am pretty sure this concept can be implemented on an electric bird
cheers
Description:
Description:
tete is offline Find More Posts by tete
Old Dec 21, 2011, 05:37 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Tete,
Thanks for the pics. Looks like you were operating with plenty of power.
Tom
Old Dec 22, 2011, 04:17 AM
tete is offline
Joined Sep 2008
Yes an OS BGX 35cc on the Senior telemaster which I eventually converted to gas
my new VAMP is 50cc CRRC powered
cheers
Old Dec 23, 2011, 11:06 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Arrgh!
Eight inches of snow last night and more today. Interstate 25 is closed North and South and 60 and 380 are closed East and West.
No flying this week!!
Tom
Old Jan 20, 2012, 08:05 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
At Last!
The snow has finally melted. the field is dried out and everybody's back from vacation, so we scheduled a first flight for this afternoon.
Great idea, but the afternoon wind was up to 15 mph or so. Not good for a first flight, But....who's going home without at least one flight? So, we had to do it.
Take off was nice. The tail came off the ground as soon as it moved (photo 1). It responded to rudder on the ground and lifted off nicely (photo 2). As you can see it has up elevator and left aileron on lift off. The CG is intentionally forward but I need to remove some right wing ballast.
Powell (Pilot) says it flies great, but with the gusting wind we decided to get it back on the ground after one pass. He managed a perfect landing -- then a gust bounced it and the LG folded. No biggie. The gear is just strapped on with rubber bands.
It looks neat in the air. We'll try again tomorrow AM. Maybe I can get some photos with the sun low and at my back.
Tom
Old Jan 20, 2012, 10:29 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Originally Posted by Tom Harper View Post
Powell (Pilot) says it flies great, but with the gusting wind we decided to get it back on the ground after one pass. He managed a perfect landing...
Congratulations on another successful maiden flight, Tom
nmasters is offline Find More Posts by nmasters
Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? rampa202 Coaxial Helicopters 52 Nov 26, 2011 09:58 PM
Discussion AP Full Arducopter UAV Gasser Build. ben1101 Aerial Photography 6 Oct 31, 2011 05:56 AM
Build Log AP UAV like plane , using 10g BL Prime_8 Foamies (Scratchbuilt) 9 Jun 10, 2011 12:51 AM
Small UAV for AP? New project! icebear Aerial Photography 47 Jun 12, 2005 08:51 PM
Asymmetrical AP-plane out of depron century_series Foamies (Kits) 31 Sep 09, 2004 02:49 AM
