Old Sep 03, 2011, 11:55 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Tom,
I'm not a big fan of the 9g servo. They always seemed "weak" to me. I found a few places that may help in your decision.
http://www.rcgroups.com/forums/showthread.php?t=631423
http://www.servodatabase.com/?sort=price
http://www.futaba-rc.com/servos/servo-select.php
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Sep 03, 2011, 12:39 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Te
I agree, but I was hoping you'd talk me into it. I'll use a standard size servo.
I finished the cap strips on the top surface and completed the TE using the method Norm suggested. I did not try for a sharp edge, just a straight, sturdy one. It's .1" thick at the tip.
Photos below are TE before cap strips and TE after but without sanding or any finishing.
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Sep 03, 2011, 05:21 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Left Panel Structure Complete
Structure is complete. I'll do the aileron servo and rear wing bolt later. The panel is 2.75 sq ft and weighs 8.25 oz. That's 3 oz per sq ft. Well under my weight budget so I should still be OK when it's covered.
Tom
Old Sep 04, 2011, 01:21 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Right Panel
Made progress last night. I have to keep checking to make sure I'm not building two left wings. Been there done that.
The camera has a LOT of radial distortion.
Tom
Old Sep 05, 2011, 06:10 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Second fitting
I rolled the leading edge this morning and added the top sheet. There's lots of work remaining on the right panel, but I needed to check the mounting hardware and the center line (and I wanted to see how it looks). It all works and the center line (CG) is where it should be.
I'll complete the right panel and start on the stabilizer. Stab doesn't have to be asym but it will look cooler if it is. Also helps the cg a bit.
Tom
Old Sep 06, 2011, 07:05 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Right Panel
Right panel structure is complete. Have to finish sanding and will install conduit tubes for future use.
Old Sep 06, 2011, 01:03 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Check Point
Weighed and assembled the completed components. Total weight is 38 ounces against a budget of 41 ounces. Not bad, but I will go a little over with covering and landing skids.
The CG still looks good.
Norms TE closures extended the TE by 1/2 inch. You can see that makes the pod and center section short. Should be able to fix it with some balsa TE stock.
Tom
Old Sep 18, 2011, 10:32 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Obstacles
I had to take a work break and the wife moved me out of the den. But, I did get a start on the stabilizer.
Also, I checked in to the sub min servos and found some digital, metal gear, bb units. They are pricey but probably worth it.
Tom
Old Sep 18, 2011, 11:11 PM
Murocflyer's Avatar
Joined Nov 2005
Very nice Tom and glad to see you are staying close to your budget weight.
It's great to watch your plane coming together.
Frank
Old Sep 19, 2011, 08:10 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Thanks. It's going to be a busy week but I hope to grab some more time for construction.
Tom
Old Sep 20, 2011, 06:59 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Got the spar web, LE and stringers in place.
Tom
Old Sep 25, 2011, 03:13 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Progress - but slow
Too many distractions. I did get the medium hard sheet on to complete the LE 'D' shape. It's very strong for an 8% section.
I'll complete the rudder next so I can work out the rudder mount before I cover the stab center section.
Tom
Old Sep 25, 2011, 05:17 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Vertical Stabilizer
I made three sets of ribs for the horizontal stabilizer. The third set is for the vertical stabilizer. That makes layout and construction easy - just shorten the rib spacing.
So, it's on the building board, but, for now, domestic chores are calling.
Tom
Old Sep 27, 2011, 05:25 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Fin
Working on it when I can catch a little time. Finished the spar web and added the LE 'D' section. Now for the fairing skirt and the cap strips.
Our new grant is funded on Oct first so I hope to have the Asym in the air shortly after that, maybe by the 15th.
Tom
Old Sep 28, 2011, 10:53 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Rudder is about done
Cap strips and bottom skirt are on.
Tom
Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? rampa202 Coaxial Helicopters 52 Nov 26, 2011 10:58 PM
Discussion AP Full Arducopter UAV Gasser Build. ben1101 Aerial Photography 6 Oct 31, 2011 06:56 AM
Build Log AP UAV like plane , using 10g BL Prime_8 Foamies (Scratchbuilt) 9 Jun 10, 2011 01:51 AM
Small UAV for AP? New project! icebear Aerial Photography 47 Jun 12, 2005 09:51 PM
Asymmetrical AP-plane out of depron century_series Foamies (Kits) 31 Sep 09, 2004 03:49 AM
