Old Aug 19, 2011, 02:40 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Norm,
With the vertical planking on the center spar it is reasonably rigid - however, ref post #43, the aluminum tube is part of the final structure. I too was concerned about the camera hanging out there on a few balsa stringers. I have had a camera come through the bottom of the model on landing.
I am working on the camera mount now. I believe it will be strong enough. I'll post more detail soon.
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Aug 19, 2011, 04:02 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Something to consider is that there is no landing gear. The model will land on skids - one on the inboard side of the pod and one on the outboard side of the fuselage. So there is no large down-force on the pod during landing. Alternatively the model will land in a creosote bush, a mesquite tree or soft sand. Sand is the worst.
Tom
Old Aug 19, 2011, 05:27 PM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Tom
Tom - I guess you should name it Road Runner - or maybe Coyote
HerkS is offline Find More Posts by HerkS
Old Aug 19, 2011, 05:51 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Creosote Cruiser?
Tom
Old Aug 19, 2011, 06:04 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Well, if you're going to fly it into a mesquite tree, how about the thorn bird
nmasters is offline Find More Posts by nmasters
Old Aug 21, 2011, 10:27 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
This looks very interesting. Nice work so far Tom.
Following along.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Aug 21, 2011, 11:37 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Frank,
Go to hear from you.
The pod has slowed me down a bit. I'm installing hatches and the camera mount. Mostly went smooth until I got to the thin section near the TE. Had to lock it in a fixture so I could keep it square long enough to get the sheet covering on. Definitely have to add some plywood doublers to that area.
Tom
Old Aug 21, 2011, 03:46 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Covered pod
Covered the pod with medium hard 1/16" balsa. The forward hatch cover is finished. Still have to do the center and rear hatch covers. The camera mount will be built into the forward hatch. The camera mounts upside down in the hatch cover. That's handy because it's all removable.
Tom
Old Aug 24, 2011, 02:18 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
The frames are in for the middle and rear hatches - sheet cover later. There's room enough to get my fingers in there to turn the wing attachment nuts. That's the important part.
I believe I am well within my weight budget, but it's time to weigh what I have so far as a reality check.
I've started on the large (left) wing panel.
Tom
Old Aug 26, 2011, 11:00 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Left wing framed
Finished framing the left wing panel. It's pretty delicate. I need to get the vertical web in the main spar, then I can sheet the LE to form the D tube.
The wing socket is tight but smooth and looks like it's going to work well.
Tom
Old Sep 01, 2011, 01:27 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Some Progress
Installed the pitot tube plumbing, cut the aileron, installed the soda straw conduit for the servo wire and rolled sheet balsa around the LE.
Have to install the aileron servo and then do the cap strips.
Tom
Old Sep 02, 2011, 01:38 PM
Murocflyer's Avatar
Joined Nov 2005
Looking good Tom! Can the servo connector fit through that straw?
Frank
Old Sep 02, 2011, 01:41 PM
Brandano is offline
Find More Posts by Brandano
I think only the wires need to fit through the straw. probably I'd cut the servo wire to be much shorter, feed the long part through the straw, and then solder connectors where I made the cut. The servo can be easily replaced, the wire stays with the plane.
Brandano is offline Find More Posts by Brandano
Old Sep 02, 2011, 01:44 PM
Murocflyer's Avatar
Joined Nov 2005
Makes sense. Silly me, I didn't think about cutting the servo wire.
Old Sep 02, 2011, 07:18 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Yep, that's the idea.
Question:
I'd like to use a little 9g servo for the aileron. With no linkage to drive it should be up to the task. What do you think?
Tom
Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? rampa202 Coaxial Helicopters 52 Nov 26, 2011 09:58 PM
Discussion AP Full Arducopter UAV Gasser Build. ben1101 Aerial Photography 6 Oct 31, 2011 05:56 AM
Build Log AP UAV like plane , using 10g BL Prime_8 Foamies (Scratchbuilt) 9 Jun 10, 2011 12:51 AM
Small UAV for AP? New project! icebear Aerial Photography 47 Jun 12, 2005 08:51 PM
Asymmetrical AP-plane out of depron century_series Foamies (Kits) 31 Sep 09, 2004 02:49 AM
