Old Apr 30, 2012, 04:02 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Mods
Removed the thrust offset.
Cleaned up the rudder hinge.
Rebuilt the elevator - rounded LE for center line hinge
Working on aluminum can motor cowl
Aileron will take a while
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old May 01, 2012, 04:11 PM
UnDetekted is offline
Find More Posts by UnDetekted
UnDetekted's Avatar
NM Desert
Joined May 2010
Originally Posted by Tom Harper View Post
1) Oscillation - It is critically damped in a right turn but oscillates in a left turn. Well, duh! All of that left thrust increases system gain to the left and critically damps to the right.
2) Power - So, why the power increase? Speed, weight and altitude are constant so lift must be constant. In a left turn the single left side aileron decreases lift on that wing panel. Two things must happen in response: the autopilot must increase angle of attack to maintain lift and it must correct for adverse yaw. That results in a significant drag increase and a compensating increase in power. More power = more system gain resulting in oscillation.
3) Cure - Remove the left thrust - Add a right side aileron - Increase rudder area.
Tom
Tom,
Recall that our best flights were our first few flights with no left thrust (actually, I think there was some right thrust?). As such, I'd say your conclusions are valid. However, I doubt we need more rudder area as it has not showed any lack of effectiveness.
Powell
UnDetekted is offline Find More Posts by UnDetekted
Old May 01, 2012, 04:37 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
The Left Turn Problem
Powell,
I watched the video this morning and had the same thought. It seemed to handle the left turns fine.
Tom
Old May 01, 2012, 05:23 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Hinges
I've been using tape for so long that I had to search for hinges. I salvaged these from a box of stuff.
Don't like to glop up hinges with CA or epoxy, also have had binding problems with 3 point hinges. So, I pinned them with toothpicks - no glop. That gives them some float so they are self aligning.
Tom
Old Oct 12, 2012, 05:16 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Patina of maturity
Asym now carries the patina of experience. It's had a couple bad crashes. Nothing design related - equipment and crew.
I added the right aileron and have spent a lot of time on the electronics. I believe everything is cleaned up. We shall see this weekend.
One of the project criteria was ease of field assembly. The Asym has fallen short in that regard. It takes two people 15 or twenty minytes to assemble this thing. That takes time and can lead to errors.
So, I did some measurements and found that the model will travel on the package cover of the Land Rover. That, and some autopilot packaging changes, removes over half of the assembly time.
Should be back in the air by Sunday.
Tom
Old Oct 14, 2012, 11:58 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
A bit windy
Nice day but a bit of a gusting wind. Hand launch was uneventful.
This was the first flight after the addition of the right aileron. CG and lateral balance look good. Needs a calmer day to get the trim adjusted.
Still having Autopilot problems, will work on them this week.
Brought it home in one piece, so it was a successful day!
Tom
Old Oct 14, 2012, 09:11 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
It sure looks unique in flight, like it was built with a purpose in mind.
HELModels is offline Find More Posts by HELModels
Old Oct 15, 2012, 03:24 AM
Brandano is offline
Find More Posts by Brandano
Looks very sleek for sure. But those low set tail and wing seem made to catch in any possible clump of grass or bush even in the smoothest landing. I understand that it will spoil the aerodynamics a bit, but wouldn't it be better off with a few wire skids under the nose and wings?
Brandano is offline Find More Posts by Brandano
Old Oct 15, 2012, 08:00 AM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Thanks guys,
It has 1/4" square spruce longerons on the bottom of the fuselage and pod. So far they have been sufficient.
I am concerned about field operations. This thing is big. We have been using a county road for landing - narrow with lots of sand (photo). Be interesting to see how it does.
Tom
Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? rampa202 Coaxial Helicopters 52 Nov 26, 2011 09:58 PM
Discussion AP Full Arducopter UAV Gasser Build. ben1101 Aerial Photography 6 Oct 31, 2011 05:56 AM
Build Log AP UAV like plane , using 10g BL Prime_8 Foamies (Scratchbuilt) 9 Jun 10, 2011 12:51 AM
Small UAV for AP? New project! icebear Aerial Photography 47 Jun 12, 2005 08:51 PM
Asymmetrical AP-plane out of depron century_series Foamies (Kits) 31 Sep 09, 2004 02:49 AM
