Norm,
No. It was a section for a wing replacement on the red model above. I expanded my spreadsheet calculations. The result shows that it's tough to make the lateral CG with the motor in the nacelle. So, I switched to the BV 141 configuration. It appears that BV had the same problem. The Ha 141-0 put the engine in the pod. All subsequent variants had the engine in the fuselage. Tom |
Blohm und Voss didn't have a massive battery to move around. Can't you just design it as a twin and use the battery in the other wing to simulate the weight of the dead engine? If the battery is lighter than the engine and pod move it farther outboard. Your left and right roll rates might not be the same but so what. ![]() --Norm |
| Thread Tools | |
| Discussion Asymmetrical Flybar Travel on the Big Lama - Related to Death Dives? | rampa202 | Coaxial Helicopters | 52 | Nov 26, 2011 09:58 PM |
| Discussion AP Full Arducopter UAV Gasser Build. | ben1101 | Aerial Photography | 6 | Oct 31, 2011 05:56 AM |
| Build Log AP UAV like plane , using 10g BL | Prime_8 | Foamies (Scratchbuilt) | 9 | Jun 10, 2011 12:51 AM |
| Small UAV for AP? New project! | icebear | Aerial Photography | 47 | Jun 12, 2005 08:51 PM |
| Asymmetrical AP-plane out of depron | century_series | Foamies (Kits) | 31 | Sep 09, 2004 02:49 AM |
