Old Jul 10, 2011, 10:06 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
canard w/ sweep forward wing for 6400
just watched flying a tiny (some 16"ws) epp foamie plane with 6400 components (brick, motor and gear box).
it did stunts and still could fly very slow. it is a kit that comes painted black, with some red trim. it uses just 2 servos connected to the main wing. front wing (stab?) is fixed.
it looks like a scale version of a full size experimental, but can't remember which 1 is it.
does anybody knows who makes it?
thanks
phil alvirez is offline Find More Posts by phil alvirez
Old Jul 10, 2011, 10:42 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
http://www.rcgroups.com/forums/showthread.php?t=1040782
http://www.2dogrc.com/catalog/electr...icro-rc-bomber
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 10, 2011, 11:05 AM
Joined Jul 2007
that's it!
thanks. that is the 1.
the 1 i saw has the 6400 brick and the 4site motor/gearbox, and a gws 5/3 prop and flies just great. it uses the 2 servos on the 6400 for elevons only and seems to be all that it needs.
thanks again.
great model. congratulations to the designer.
Old Jul 10, 2011, 12:33 PM
Joined Nov 2007
No prob
Old Jul 10, 2011, 12:59 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Heres the main thread Phil.
TODD
http://www.rcgroups.com/forums/showt...hlight=firefox
I R Irv is offline Find More Posts by I R Irv
Old Jul 10, 2011, 02:11 PM
Joined Jul 2007
now and then...
thanks. seems that it started when the technology was not as advanced as is today. the 1 i saw uses lighter components and flies great. i think it does better than what there was available at the time.
Old Jul 25, 2011, 06:16 AM
Joined Jul 2007
firefox
ok. so now we know it is the firefox.
whoever has flown it, could you post here your experiences with it?
thanks
Old Jul 25, 2011, 06:34 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
thanks
I've flown the Super Jet which is the conventional wing version. Flies fast and slow. Very relaxing. Easy to fix. Long flight times. I'm on my second one now. Check HK for reviews.
MegaTesla is offline Find More Posts by MegaTesla
Old Jul 25, 2011, 07:50 AM
Joined Jul 2007
swept forward
thanks, MT. great advice.
at this time am trying to evaluate the swept forward wing-with canard. what i know is that a swept forward wing makes an airplane more maneurable-and that means unstable, too, but i saw a firefox (with swept forward wing and canard) flying seemly very stable and maneurable, although that could be just that the pilot is very good. that's why am trying to learn how i can do with that.
and am also trying to learn where it balances.
anybody?
regards
Old Jul 25, 2011, 08:12 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
At this scale and weight and with flat wings I doubt there will be a big difference between forward and backward swept wings. Balance on the firefox is 2-3cm in front of the leading edge according to Metroidrc in the other thread.
Old Jul 25, 2011, 09:19 AM
Joined Jul 2007
sweep forward or not
i have to admit that, at the end of the day, the results may be the same.
still, maybe i will try both and see. but it takes lots of testing to be absolutely sure if really there is any difference.
thanks a lot for your comments.
and about balance: would it be measured from the tips? that he does not say.
Old Jul 25, 2011, 09:58 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
I think it is measured from where the leading edge makes a V close to the body.
Old Jul 25, 2011, 10:43 AM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Felipe, this plane is a twist from ELF concept maybe some more scale is nice, the X-29 is a good subject.
Saludos de Mexico.
Al
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old Jul 25, 2011, 11:06 AM
Joined Jul 2007
balance
that's where i would do it. thanks.
and about your plane (the super jet): where does it balance? measured from where?
thanks
Old Jul 25, 2011, 11:41 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Sounds like at the intersection between the center triangle and the main leading edge. So at that shallow "V" go back 2-3 cm and then do some test glides.
derk is offline Find More Posts by derk
Discussion Clean Sweep - a 48" sportster with a swept forward wing! tim hooper Sport Planes 120 Nov 25, 2015 11:14 AM
Build Log The Frog - lifting body with canard and forward swept wing (Plans) mardimardigras Foamies (Scratchbuilt) 28 Aug 19, 2013 10:29 AM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 10:24 AM
Discussion 6400 brick-motor no go forward phil alvirez Power Systems 10 May 30, 2011 03:37 PM
