| Thread Tools |
| This thread is privately moderated by myrcmart, who may elect to delete unwanted replies. |
Joined May 2009
RCX MG9257 High Speed Digital Servo (4.5kg / 25g / 0.07sec / Metal Gear / Tail & Rudd
RCX MG9257 is a high speed, high torque digital servo built with Metal Gear suitable for 450 & 500 series helicopters. It is an excellent tail locking servo for 3D flight. It could also be used as a Swashplate Servo for larger helicopters (eg. 500 / 600 size helicopters)
http://www.myrcmart.com/rcx-mg9257-h...le-p-3716.html Equipped with two ball bearings. For use with the Futaba GY401 (FUTM0807, FUTM0808) and the GY502 gyros. Does not work with these Futaba radios (4FG, 5FG/K, 6FG, 6FG/K, 7FG/K New Terratop, 3EGX, 3PGE, 2NL, 2LGX, 2FR, 2PK series) These radios have a servo neutral signal of 1310us not compatible with this servo. Do not use with AM radios. Specification * Dead band: 0.002ms (Default) * Control System: +Pulse Width Control * Working Frequence: 1520μs / 80hz Digital mode/Analogy mode * (RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave * Operating Voltage: 4.8~6.0 Volts DC * Operating Temperature Range: -10 to + 60 Degree C * Operating Speed (4.8V): 0.08 sec/60° degrees at no load * Operating Speed (6.0V): 0.07 sec/60° degrees at no load * Stall Torque (4.8V): 3.8 kg.cm * Stall Torque (6.0V): 4.2 kg.cm * 360° Modifiable: NO * Motor Type: Coreless Motor * Potentiometer Drive: Indirect Drive * Driver Type: FET * Bearing Type: Dual Ball Bearings * Gear Type: Plastic Gear * Programmable: YES * Connector Wire Length: 18.0 * Dimensions: 35.5mm x 15.0 x 28.6mm * Weight: ~30g Package Included * 1 X RCX MG9257 High Speed Digital Servo (4.5kg / 25g / 0.07sec / Metal Gear / Tail & Rudder Servo Suitable) * 1 X Set of Servo Arm |
| Thread Tools | |
| Sold Mi Digital High Torque Metal Gear Servo JR/Hitec 11.8kg / 0.07 / 61g $35 shipped | fern420 | Aircraft - General - Radio Equipment (FS/W) | 2 | Jun 13, 2011 11:11 AM |
| Sold Mi Digital High Torque Metal Gear Servo JR/Hitec 11.8kg / 0.07 / 61g $35 shipped | fern420 | Cars - Trucks and Parts (FS/W) | 0 | Jun 11, 2011 07:20 AM |
| Sold INO-LAB D201-HB 9g ULTRA SPEED 0.07sec/60 DIGITAL SERVO w/ AL HEATSINK tail servo | Sonex128 | Aircraft - General - Radio Equipment (FS/W) | 1 | May 25, 2011 11:12 PM |
| Discussion GWS Mini Digital LXF 4.5Kg/ 0.073sec at 4.8V; 5.1Kg/0.065sec at 6.0V | GWS4CEO | 3D Flying | 1 | Apr 26, 2011 11:53 PM |
