Old Jan 14, 2012, 06:46 PM
Corocrumpler is offline
Find More Posts by Corocrumpler
Watch This!
Corocrumpler's Avatar
United States, LA, Washington
Joined Feb 2007
The spar is from a wrecked out Slow Stick, I used nylon bolts and nuts and bolted it to the wing. I cut small pieces of plastic to use as big washers so the nut won't pull thru the coro. The motor mount is also jammed in by the carbon fiber rod in the last coro flute. It's pretty solid.
Corocrumpler is offline Find More Posts by Corocrumpler
Old Jun 04, 2012, 07:38 AM
gatorlynch is offline
Find More Posts by gatorlynch
gatorlynch's Avatar
United States, FL, Sarasota
Joined Mar 2010
I had stopped flying this wing a few months ago, to use the 450 motor & Rx on other planes.
The motor & Rx has become "available" (OK - yes, I crashed ...), so I took the wing out of mothballs & fired her up yesterday.
I'm flying her with a 9X6 APC this time around. I think I had been using an 8X6 previously.
What I didn't do is verify which size battery I grabbed out of the ammo box .........
Return of the Flutter Wing (1 min 53 sec)
gatorlynch is offline Find More Posts by gatorlynch
Discussion new 48" / flying wing record Swoopdown Dynamic Soaring 2 May 28, 2011 07:48 PM
Discussion ** SpaFFFnutz - 48" Coroplast/FFF Hybrid Flying Wing ** jackerbes Foamies (Scratchbuilt) 164 Apr 20, 2011 08:12 PM
Sold 48" flying wing 55bucks steeg Aircraft - Sailplanes (FS/W) 0 Apr 20, 2011 06:13 PM
Discussion SpaFFFnutz 48" KFm4 Flying Wing - Electric FFF/Coroplast Hybrid jackerbes SPAD - Simple Plastic Airplane Designs 10 Nov 25, 2009 02:41 PM
