KFm airfoil 48" Flying Wing
Here is my Coroplast version of the KFm airfoil flying wing.
Specs - 48" WS, 23 oz. AUW, 1200kv 450 motor, 3S 1600mah, 8X6 APC I couldn't get her to balance to a good CG during my dry fit, so I had to cut a slot & move the entire motor mount assembly forward. I had started off with the entire motor aft of the body. She was very stable, although a bit sluggish I thought. This is my first wing, so I really don't have anything to compare to. Changing from the 9X5 the 8X6 helped noticeably in the speed department. I will max out the throws on the Tx, plus cut some slots along the hinge lines to make sure I'm getting good free movement of the control surfaces. As evidenced in the video, I did experience a large degree of flutter (how about the entire ship) at higher speeds. I believe I need some additonal supports/stiffeners back by the motor. I will also put in a doubler/splice plate on the underside, where the 2 foldover pieces butt along the centerline - to reduce overall side to side flex. Thanks to Tony65X55 for the design - http://www.rcgroups.com/forums/showp...0&postcount=38
Nice wing, it looks pretty good up in the air too.
You could try putting in some lengths of carbon fibre tubes or rods into the wing. You can get a size that slides snugly in between the flutes. the CF rods do a pretty good job of stiffening up a wing. it might be all you need. |
Latest blog entry: My Low Wing plane
Spar Added
Thanks for the comments, guys.
I decided to use a scrap piece of 3/8" for a lateral spar. On my next build, I will insert some CF rods into the flutes before I fold & glue the wing. I also added a piece of CF on top of the motor mount stick running forward, to help stiffen longitudinally. Next time, I will also move the servos further outboard, to center them on the elevons. I was trying to keep them as far forward (which means inboard, due to the wing sweep) as I could for balance, but I think the elevons need them more centered. I'll put some hinge tape on & see if I notice any difference. I flew 3 batteries today. I think I've got her dialed in close enough for now. To offset the weight of the new spar, I added 1 oz. of lead at the tip. She needed a whole bunch of left elevon up trim/centering to keep from rolling to the right - perhaps due to to torque of the motor/prop? This being my first wing, I don't know if this is normal. Oh, I almost forgot - the flutter is all but gone. It only showed up briefly one time during some high speed manuvering, as the video shows.
Got Bomb ?
Added a Quanum Bomb Drop System to my wing -
I'm going to try to move the base further back closer to the CG, so it won't impact flight performance so much.
I am on my second wing. I felt the first wing needed some improvements, and it was just as easy to cut a new wing out than to mess with opening up the fold, etc. on the first one.
1.The second wing (KFm -V2) has the same electronics. The prop is an APC 8X6EP & the motor is a speed 450 from headsuprc - http://www.headsuprc.com/servlet/the...0-Speed/Detail I am drawing 21 amps & 240 Watts on the wattmeter & the motor is only rated at 20A max, so I try not to fly at full throttle. 2. I don't yet know what the final CG will be. I usually record somewhere what I'm using for CG on my planes once I get them dialed in, but for some reason I didn't on my first wing. The old airframe with the markings on it ended up in the recycling bin & got picked up Friday. I maidened V2 Saturday, and am still in the process of dialing her in. She's balanced about 7.5" from the tip now. I was suprised to find out she was nose heavy, even with cutting from the same plan & locating battery & electronics in the same place. I had to move the battery (rotate it to run fore to aft). I think it's because I eliminated the wood spar in the rear & added some CF in the flutes. I'll post some details & pics in the next day or so. I'm going out in the AM - as the winds from Irene will probably keep us grounded starting tomorrow PM till this weekend. I have a question for you - what are your thoughts or plans for a motor mount? I initially used the stick mount because it's simple, easy and I had one laying around. I think it also helps act as a stiffener. I had also thought about making an "L" shaped motor mount out of gutter pipe or plywood & fanstening thru the Coro to a plate on the other side. This would allow you to slide the motor as needed for balance during your trial fit. |
Andy - I'm not able to answer your question, as it's not a simple answer. If you want to delve into the design aspect, you can lose yourself for days at a time here in these forums, and get the opion & experience of knowledgable people. Here is a link to a thread discussing the KFm airfoil - http://www.rcgroups.com/forums/showthread.php?t=558321
This being a SPAD (to me, the operative letter here is S=Simple), I just built it, knowing it would weigh a bit more than a foamie build. I didn't want to get all caught up in wing loadings, etc. I can tell you my V1 flew well, both power on and off @ 23 oz. I also feel motor/prop selection is important - you need to have enough thrust for the weight. PM me if you want to - I'd be happy to try to help you out. Tim |
I cut a small piece of scrap, to show you how I cut my wing folds. This technique also works for cutting out the control surfaces, or cutting fuselage folds on other models. If it's a control surface or a 90 degree fold, I usually only cut one pass wide. Here is a link to my hinging tool - http://home.comcast.net/~TipsTricksL...nging_tool.htm The curved tips of the blades allow you to cut without worring about cutting through the bottom skin layer. A straightedge (I use a framing square) is used when you're cutting at an angle or perpindicular to the flutes. When you're cutting with the grain of the flutes, the width of the paint stick allows proper blade spacing to be able to cut & remove the entire top skin right from sidewall to sidewall in one pass. |
| Thread Tools | |
| Discussion new 48" / flying wing record | Swoopdown | Dynamic Soaring | 2 | May 28, 2011 07:48 PM |
| Discussion ** SpaFFFnutz - 48" Coroplast/FFF Hybrid Flying Wing ** | jackerbes | Foamies (Scratchbuilt) | 164 | Apr 20, 2011 08:12 PM |
| Sold 48" flying wing 55bucks | steeg | Aircraft - Sailplanes (FS/W) | 0 | Apr 20, 2011 06:13 PM |
| Discussion SpaFFFnutz 48" KFm4 Flying Wing - Electric FFF/Coroplast Hybrid | jackerbes | SPAD - Simple Plastic Airplane Designs | 10 | Nov 25, 2009 02:41 PM |
