Old Nov 13, 2011, 09:28 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Do any of them have a groove for a c-clip at 34mm? If not I'll look for a small locking collar of some sort for the back of the motor.
Ace4 is offline Find More Posts by Ace4
Old Nov 13, 2011, 10:42 AM
graham1352 is offline
Find More Posts by graham1352
Huck On,Huck Off, The Hucker
graham1352's Avatar
Philippines, Northern Mindanao, CDO
Joined Oct 2009
Pretty close, looks one of them is about 35mm from the end with the groove
for the set screw.
graham1352 is offline Find More Posts by graham1352
Old Nov 15, 2011, 11:35 AM
Ace4 is offline
Stick banger
Ace4's Avatar
USA, AZ, Chandler
How long til the 74" Edge maiden?
Old Nov 15, 2011, 12:14 PM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
Not sure on 74", don't have electronics for it currently and have been spending way too much $ lately including the Yamahah generator I just bought, receiver hitch being installed next week in my escape, and rec storage rack still to come to haul more stuff including genny to the field
I do have some JR 8717 lying around I could use and was thinking I may pull Motrofly 4325, ICE100 and rec out of my 72 to get the 74" airborn sooner.... hmm....
weaser42 is offline Find More Posts by weaser42
Old Nov 15, 2011, 01:38 PM
graham1352's Avatar
Joined Oct 2009
Sweet, you finally went gas
Old Nov 15, 2011, 01:46 PM
Ace4 is offline
Stick banger
Ace4's Avatar
USA, AZ, Chandler
8717's would make for some wickedly fast control surfaces...
Old Nov 15, 2011, 03:53 PM
PlanePhil is online now
Find More Posts by PlanePhil
PlanePhil's Avatar
United States, AZ, Chandler
Joined Oct 2010
OMG out of control. What generator model did you get?
PlanePhil is online now Find More Posts by PlanePhil
Old Nov 15, 2011, 04:16 PM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
Yes, I have had some control issues of late
I was all over the board on the genny, first thought was cheap as possible 800 watt 2 stroke (perhaps small enough to shoe horn in car somewhere), but that would not have enough juice for full power of charger. Then started looking at mid range 4 stroke, almost pulled the trigger on a Honeywell. In the end I figured it was a buy once deal so why not get something nice. I ended up buying a Yamaha EF2000is which is supposedly quieter than the Honda 2000.
Old Nov 15, 2011, 05:06 PM
PlanePhil's Avatar
Joined Oct 2010
Nice.. How many watts do the power supplies draw when the charger is at full tilt?
Old Nov 15, 2011, 05:53 PM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
No clue, there will be overhead in both the charger and power supplies but not sure how much. I'm sure the genny will handle it with ease though.
Old Nov 15, 2011, 06:58 PM
PlanePhil's Avatar
Joined Oct 2010
Ok, just tested my I charger with the 24 volt power supplies.
The power supply draws 6 amps or 702 watts at 117 VAC out of the wall while charging at a full 30amps.
Specs on generator:
Max Watts: 2000W
Rated Watts: 1600W
Rated Current: 13.3A
Looks like there should be plenty to run your charger and say....one more of your buddies i chargers if he gets in a pinch.
Old Nov 15, 2011, 09:24 PM
btsai is offline
Find More Posts by btsai
It took me 30 years?!?!!!
Chandler, AZ
Joined Apr 2007
I'm surprised you went for a generator...
Didn't like the two deep-cycle 12V batteries idea like Chris and Everyday Flyer do?
btsai is offline Find More Posts by btsai
Old Nov 15, 2011, 09:33 PM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
How many cells were you charging? Max amps 30 regardless but higher cells=more watts at same Amps. But I did figure genny could support more than one charger
My original thought was a gen could fit inside car, perhaps still could. Batts would be bigger, I'd have to worry about charging them all the time, and I was unsure how much I could charge from them. Perhaps that would have been better, who knows.
Old Nov 15, 2011, 09:39 PM
graham1352's Avatar
Joined Oct 2009
Hmm, maybe the gen could power spotlights for night flying too
Old Nov 15, 2011, 09:42 PM
btsai is offline
Chandler, AZ
Joined Apr 2007
I just looked up Charles' set up. Cool, but not uncomplicated.
Here's the thread:
http://www.rcgroups.com/forums/showt...t=728847&pp=50
I wonder how Chris has his set up...
Discussion Over 300 flights at W Arl Site and new slope site Ftworth Jan 2012 kewhite Soaring League of North Texas (SLNT) 2 Jul 03, 2011 05:49 PM
Discussion Joyriding general that almost exposed Area 51 Usta Bee Life, The Universe, and Politics 1 Jun 03, 2011 11:29 PM
Question Tucson az area float fly area Retired Relic Waterplanes 0 Oct 20, 2009 12:19 AM
Careful! BEWARE! Rogue pilot with no radio-etiquette roaming Marin County / Bay Area Matt Galland Slope 165 Mar 23, 2009 09:44 AM
Any slope site in Tucson, AZ area ?. ktoey Slope 6 May 11, 2003 07:17 PM
