Old Oct 18, 2011, 10:22 PM
graham1352 is offline
Find More Posts by graham1352
Huck On,Huck Off, The Hucker
graham1352's Avatar
Philippines, Northern Mindanao, CDO
Joined Oct 2009
Originally Posted by Ace4 View Post
If you guys are going to be there, I'll check it out on Saturday. I finally got a shipping notice from Castle, so I should be able to fly the heli this weekend. 7 weeks of no heli flying sucks.
Guessing I should bring my ezup and a table if I can fit them in the car?
Bringem if you need them. Not sure if I'll be out Sat. or not yet,depends on if my brother whants to fly gas or not. I know the guys will welcome you out there,and you'll have great time.
Good people flying at the rogue spot, you can have some heli fun with weaser.
graham1352 is offline Find More Posts by graham1352
Old Oct 19, 2011, 01:57 PM
graham1352's Avatar
Joined Oct 2009
EPP Slickers,post up yur AUW minus battery, when you get there
My brother is thinking of getting one to teach his son some more flying.
He's wanting to use his equipment from his LUM edge which is about 13oz minus battery.
Old Oct 19, 2011, 07:51 PM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
Will do, foam is a bit thicker and perhaps denser than Edge and CF bracing is thicker as well.
weaser42 is offline Find More Posts by weaser42
Old Oct 21, 2011, 07:15 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Ok plans changed, I won't be able to make it out on Saturday. Maybe next weekend.
Ace4 is offline Find More Posts by Ace4
Old Oct 21, 2011, 08:38 PM
graham1352's Avatar
Joined Oct 2009
Dad,brother, and I will be at EVA Sat. New 42 Slick maiden
Have fun rogue flyers
Old Oct 21, 2011, 09:23 PM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
My EPP Slick came in about 12oz with no battery, Hacker A20+X20, 4X 65MG, xps nano Rx.
Old Oct 21, 2011, 09:42 PM
graham1352's Avatar
Joined Oct 2009
Cool, lighter than I was expecting. Maiden tomorrow too?
Guess I'll miss it being at EVA.
Started on the 104 yet?
Old Oct 21, 2011, 10:10 PM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
Yep, EPP Slick should fly Sat.
I put LG on 104 and epoxied all horns into control surfaces, that was about it. Still waiting for some bits and have not ordered any packs yet. I may get it ready for next weekend but more likely the one after that.
Old Oct 21, 2011, 10:34 PM
graham1352's Avatar
Joined Oct 2009
Take your time on the biggun,do some good ground testing
Plenty of winter left
I'll surely not miss the maiden of that one.....exciting
Have fun tomorrow
Old Oct 24, 2011, 10:11 AM
graham1352's Avatar
Joined Oct 2009
Hope you all had a fun weekend. Sat. was a bust at EVA, we forgot it was a "work day",
got one flight in before being put to work. Sun. at EVA was much better New 42
slick flys great, happy to have this one back.
How are the EPP slicks flying?
Old Oct 24, 2011, 10:20 AM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
Mine was the only one flying and I had some setup issues where ail servo's were being blocked by some bracing on one side and inhibiting full travel on both. I did fix that Sat night and flew it in front of my house Sun morning a bit. It was much better but I'd still like more aileron. I have more travel in end points but the servo's looked like they were going to pull away from the wing if I went further, I may need to check the bevel to be sure it's not binding.
Plane does feel pretty stiff and does fly more like a balsa than the other foamies but also still feels a bit odd to me, hover actually seems a bit harder than it should be. I did get it into a KE spin once but I really struggle getting it into one.
I think my build is a bit shoddy in other areas as I messed up durning the build. I had mounted the bottom fuse to the wing and horizontal fuse and was going to be done for the night. Watched a TV show then decided to do another step but did not look at destructions or really think about things and I glued the top fuse on. Then the next day I realized I was supposed to do all bracing and mount ail servo's before doing top fuse so all would be totally flat. One wing on mine looks to have same washout which may be causing some issues.
We'll see when Phil builds his the correct way
Old Oct 24, 2011, 03:00 PM
PlanePhil is offline
Find More Posts by PlanePhil
PlanePhil's Avatar
United States, AZ, Chandler
Joined Oct 2010
We will see how it goes. I did find that the slots for the aileron horns are too far forward. I had to cut the slots rearward so the holes on the horn that hold the pushrod wire were directly over the hinge. I had to move about 1/4 inch. This may be why you don't have enough aileron throw. Check out your model Kevin.
You can fly it after I get done and we will compare.
PlanePhil is offline Find More Posts by PlanePhil
Old Oct 25, 2011, 11:52 PM
PlanePhil's Avatar
Joined Oct 2010
Are we expecting a 104 maiden this weekend?
Old Oct 25, 2011, 11:54 PM
PlanePhil's Avatar
Joined Oct 2010
Great news about the 42 slick. I have more flights on mine than you. At least for this month.
Old Oct 26, 2011, 12:05 AM
weaser42 is offline
House of Paine
weaser42's Avatar
Joined May 2007
Doubtful, still have not ordered batts, have not seen shipping notice on hardware for motor.
I did get rudder and elevator all setup I think. THIS THING IS BIG! The horizontal stab is close to 46" across when mounted. The servo's on 2S lipo are crazy fast as well
Discussion Over 300 flights at W Arl Site and new slope site Ftworth Jan 2012 kewhite Soaring League of North Texas (SLNT) 2 Jul 03, 2011 05:49 PM
Discussion Joyriding general that almost exposed Area 51 Usta Bee Life, The Universe, and Politics 1 Jun 03, 2011 11:29 PM
Question Tucson az area float fly area Retired Relic Waterplanes 0 Oct 20, 2009 12:19 AM
Careful! BEWARE! Rogue pilot with no radio-etiquette roaming Marin County / Bay Area Matt Galland Slope 165 Mar 23, 2009 09:44 AM
Any slope site in Tucson, AZ area ?. ktoey Slope 6 May 11, 2003 07:17 PM
