Old Jul 09, 2011, 06:53 PM
stg61abc is offline
Find More Posts by stg61abc
Joined Oct 2007
MK Curare 40 plans
Howdy all.
Does anyone have the Curare 40 plans set from MK kits?
Many thanks
Carlo
stg61abc is offline Find More Posts by stg61abc
Old Jul 20, 2011, 03:34 PM
jpurcha is offline
Find More Posts by jpurcha
AKA "Three Fingers"
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
PM'd you. I have a copy of the plans.
Jim
jpurcha is offline Find More Posts by jpurcha
Old Jul 30, 2011, 01:28 PM
stg61abc is offline
Joined Oct 2007
Jim
Many thanks Jim
Carlo
Old Oct 07, 2011, 12:48 PM
jpurcha is offline
AKA "Three Fingers"
jpurcha's Avatar
Joined Sep 2004
Link to down load plans
Here are the links to download the plans, root and stab profiles and compufoil ribs.
Jim
This is the file for the tip and root profiles. These are from the German plan.
http://www.4shared.com/get/ccwrIHDm/curare_40.html
File containing the ribs generated by compufoil matching the profiles.
See post #10 below.
Here is the original 18.5MB scanned file.
http://www.4shared.com/document/PFkQ...are_40_MK.html
Have fun.
Old Oct 08, 2011, 12:31 PM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
thanks for posting theses. Now i have no excuses to build one. Phil
mrshea is offline Find More Posts by mrshea
Old Oct 08, 2011, 03:14 PM
daggets is offline
Find More Posts by daggets
all repairs at all times
rouen france
Joined Jan 2007
thank you very much, gentleman!!!
daggets is offline Find More Posts by daggets
Old Oct 08, 2011, 03:44 PM
doxilia is offline
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Jim,
thanks for the docs. I have a printed plan that was kindly sent to me but I haven't gotten around to scanning it. I guess I won't have to anymore. Mine might be slightly cleaner without the dark smudges in the center. If I do it, I'll re-post the clean version.
In the meantime, I was able to reduce the size of the actual MK plan to 10% of it's original - not sure why it was 18 MB - probably a raster to vector conversion.
I'll post it here for ease of access.
David.
doxilia is offline Find More Posts by doxilia
Old Oct 08, 2011, 11:26 PM
jpurcha is offline
AKA "Three Fingers"
jpurcha's Avatar
Joined Sep 2004
Thanks David, and have a nice Thanksgiving Day Weekend (Canada). I swapped your smaller file out from link with the original 18MB file. Could have the been the dpi size it was originally scanned in or scanned at colour or gray scale settings. The Canon printer at the plant will create some pretty large pdf scans from customer drawings if the setting are not correct.
Jim
Old Oct 09, 2011, 03:15 AM
Roguedog is offline
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
Jim,
Thanks for sharing your Curare 40 plan. I took the time to clean it up and resize to the correct wingspan of 57 1/8". I don't know what happened with the original but after downloading it and opening it up mine had a wingspan of about 242 inches. Davids reduced filesize PDF also has a 242 inch wingspan although in a significantly reduced size. Thats a big sized Curare 40! Trying to print this one out would have given someone quite a surprize.
I also took the time to straighten the side view of the fuse so there's an accurate centerline down the fuse and connected the rudder portion that was separate to the side view as well.
I'm working on straightening the topview as it has quite and arc from tip to tail. I will post it later. I love these MK plans. It appears this particular one has seen better days. That paper sure shrinks alot around the edges on these old plans. Hope you like this fixed version.
Bryan
Update topview is straightened, all done.
Roguedog is offline Find More Posts by Roguedog
Last edited by Roguedog; Oct 10, 2011 at 05:38 AM. Reason: Updated pdf with straightened fuse top view
Old Nov 13, 2011, 10:30 AM
jpurcha is offline
AKA "Three Fingers"
jpurcha's Avatar
Joined Sep 2004
Curare 40 Wing Ribs
With some help of an RCU member, I've managed to learn how to set the spar in proper position to match the MK Curare plans. I've adjusted the L.E. for 10mm including the false LE.,and adjusted the TE to 40mm (aileron strip and TE). The spar is drawn at 5X10mm as shown on the MK plans. The ribs are drawn on legal paper 8.5 X 14.00.
Jim
Wanted plans big stick 40 von14 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 09, 2011 05:07 PM
Discussion Berkeley MK 40 Zilch price? fitz21 Control Line 10 Jun 13, 2011 04:05 PM
Discussion Curare Plans how to print hamza_b The Builders Workshop 7 May 26, 2011 06:41 PM
Sold *80's Vintage Pattern* Wolfgang Matt MK Mattlas 40 NIB $225.00 FREE SHIPPING! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Apr 07, 2011 12:59 PM
