Old Jul 09, 2011, 04:47 PM
No1Daemon is offline
Find More Posts by No1Daemon
Joined Jul 2011
Magnetic compass servo control
Hi all
I was given the suggestion to post this here instead of where I did originally.
I have built what we call a kontiki here in New Zealand and I am looking for a bit of gear to autopilot it with a servo controlled rudder that is controlled in turn by a magnetic compass.
In other words I want to power the thing on with it pointed in the direction I want it to head and then the servo to control the rudder to maintain the magnetic compass bearing it was pointed in.
It is not entirely a submerged vessel as it skims the surface of the water so wind isn't really a factor but swells and white water may throw it off.
Have a google at tuckertiki.co.nz for more info. That is exactly what I want to achieve.
Not wanting to reinvent the wheel could someone point me in the direction of an arduino or similar project that will achieve what I want to do.
I can build the rudder/servo arrangement but wanted to get an off the shelf board and chip for the control.
I believe I can get a honeywell magnetic compass that outputs the bearing as an integer so 2165 would be 216.5 degrees. So I believe I need some gear to take that integer and convert it to a pwm control signal to send to the servo which controls the rudder.
Steve
No1Daemon is offline Find More Posts by No1Daemon
Old Jul 10, 2011, 08:53 PM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
Hey, Kontikis are neat. I used to live in NZ. And I would say your best bet would be to post this on an electronics/ computer forum. I think how it would work is you have some kind of interface to plug the compass into a small cuircut board (peeps on electronics forum could help with that) and then convert the readout of the compass into a RX like signal for the servo.
zanek is offline Find More Posts by zanek
Old Jul 10, 2011, 09:41 PM
Joined Jul 2011
I will do that. I thought you guys would have it all sorted already. Most of the people on here seem to have been there already.
Thanks for the suggestion.
Discussion Eagle Tree: Request for Magnetic Compass Sensor WEREE Eagle Tree Systems 14 Aug 30, 2013 07:54 AM
Discussion Directional compass control No1Daemon Submarines 10 Dec 19, 2011 02:17 AM
Discussion Servo, video downlink and compass philgib Blimps 3 Sep 28, 2006 10:11 PM
DIY - magnetic compass Rox DIY Electronics 1 Oct 26, 2005 03:39 PM
Aspire for Sale (magnetic mayhem & speed control)- $85 austinflyer Aircraft - Electric - Airplanes (FS/W) 0 Apr 12, 2003 03:31 PM
