Old Jul 08, 2011, 02:24 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
Got my Swamp Dawg.... But need help programing my DX6i
I sent my dx6i back to spektrum to have the throttle stick modded to be self centering.... But I have a problem when I turn turn on the radio and plug the battery into the Swamp dawg it is at half power because of the self centering stick... I need help on programing the radio...
hotrodder is offline Find More Posts by hotrodder
Old Jul 08, 2011, 03:09 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You need to calibrate the ESC to the TX throttle range. Not sure how, but it should tell you how in the instructions for the ESC.
Sometimes it's as easy as having the TX at full throttle when you plug the battery in, wait for a beep then release to neutral and wait for another beep.
wparsons is offline Find More Posts by wparsons
Old Jul 08, 2011, 08:19 PM
hotrodder's Avatar
Joined Jan 2007
There are no instructions with the esc... I bought it at HK...... I called spektrum and the rep said there is no way to do it...
Old Jul 08, 2011, 09:07 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can probably program the TX using a couple mixes and adjusting end points, but it'll be MUCH easier to calibrate the ESC.
Do you have a link to the ESC?
Old Dec 11, 2011, 09:56 AM
OwlPic is offline
Find More Posts by OwlPic
OwlPic's Avatar
United States, MA, Tyngsborough
Joined Jun 2010
Esc
Used the HobbyKing.com: Turnigy TrackStar 18A 1/18th Scale Brushless Car ESC (TTS-18A).
Programmed to the right stick. Elevator = Throttle and Alerons = rudder.
It also gives you an ON/OFF switch so you don't have to open the cover to disconnect the battery when not using
You can solder your Motor wires, because you can use your transmitters ability to reverse the polarity, rather than swapping the motor wires.
NOTE: Main is Swamp-Dawg thread is at: http://www.rcgroups.com/forums/showthread.php?t=1450343
OwlPic is offline Find More Posts by OwlPic
Discussion HobbyKing Swamp Dawg (AirBoat) Jack_Chen Racing Boats - Electric 507 Jul 16, 2016 04:26 PM
Discussion Got my new plane! Getting ready for maiden, question about cg, need help please. cfiiman Electric Plane Talk 5 Jun 07, 2011 11:10 AM
Discussion I got a plane but I need a motor not new to rc's gaaunapoi Beginner Training Area (Aircraft-Electric) 11 Apr 12, 2011 10:12 PM
Discussion Just got my hands on some older gliders but need help identifying them Sackie Sailplane Talk 16 Oct 01, 2010 01:36 PM
Discussion I got my engines running but I need help... Doby Fuel Plane Talk 1 Jan 19, 2009 06:36 PM
