| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Guest
Posts: n/a
Counter-clockwise rotating blades.
Hi there!
I am trying to find an electric model heli which has blades turning anti- clockwise instead of the usual clockwise rotation. Does anyone know a model that has? I have searched and searched some sites but cannot find any that have the anti-clockwise rotation. The reason is because I am putting together a twin rotor heli and I already have the clockwise rotating rotor, but now need the anti- clockwise one. TIA! |
#2 |
Guest
Posts: n/a
Re: Counter-clockwise rotating blades.
This might be a stupid question, but why don't you just change the polarity
of the motor, re-time it and do it that way? Can't you reverse the pitch linkages to the blades? Just a thought that I am sure you have already had! David "PC" <F@you.com> wrote in message news:MPG.19bc2f5275f67f89989720@text.news.ntlworld .com... > Hi there! > > I am trying to find an electric model heli which has blades turning anti- > clockwise instead of the usual clockwise rotation. Does anyone know a > model that has? I have searched and searched some sites but cannot find > any that have the anti-clockwise rotation. > The reason is because I am putting together a twin rotor heli and I > already have the clockwise rotating rotor, but now need the anti- > clockwise one. > TIA! |
#3 |
Guest
Posts: n/a
In article <bita1f$h0s$1@hercules.btinternet.com>,
david_perry@btconnect.com says... > This might be a stupid question, but why don't you just change the polarity > of the motor, re-time it and do it that way? > Can't you reverse the pitch linkages to the blades? > > Just a thought that I am sure you have already had! > Yep, I thought of that, but I was unsure that would give effective control. Not only that, but I was going to use cheap fixed-pitch type blades so I didn't need to use a CP upgrade. I don't like the idea of just putting them on upside down. I just can't seem to find any models that have the blades facing the other direction for anti-clockwise rotation. |
#4 |
Guest
Posts: n/a
Yes, Hirobo has a twin rotor helicopter. Take a look at this site
http://www.hobbytron.net/%20Electric...By-Hirobo.html "PC" <F@you.com> ¦b¶l¥ó news:MPG.19bc3daac66f91c4989721@text.news.ntlworld .com ¤¤¼¶¼g... > In article <bita1f$h0s$1@hercules.btinternet.com>, > david_perry@btconnect.com says... > > This might be a stupid question, but why don't you just change the polarity > > of the motor, re-time it and do it that way? > > Can't you reverse the pitch linkages to the blades? > > > > Just a thought that I am sure you have already had! > > > > Yep, I thought of that, but I was unsure that would give effective > control. Not only that, but I was going to use cheap fixed-pitch type > blades so I didn't need to use a CP upgrade. I don't like the idea of > just putting them on upside down. I just can't seem to find any models > that have the blades facing the other direction for anti-clockwise > rotation. |
#5 |
Guest
Posts: n/a
If the blades are symetrical then upside down or right way up, they wont
know! David "PC" <F@you.com> wrote in message news:MPG.19bc3daac66f91c4989721@text.news.ntlworld .com... > In article <bita1f$h0s$1@hercules.btinternet.com>, > david_perry@btconnect.com says... > > This might be a stupid question, but why don't you just change the polarity > > of the motor, re-time it and do it that way? > > Can't you reverse the pitch linkages to the blades? > > > > Just a thought that I am sure you have already had! > > > > Yep, I thought of that, but I was unsure that would give effective > control. Not only that, but I was going to use cheap fixed-pitch type > blades so I didn't need to use a CP upgrade. I don't like the idea of > just putting them on upside down. I just can't seem to find any models > that have the blades facing the other direction for anti-clockwise > rotation. |
#6 |
Guest
Posts: n/a
In article <bitgc4$afq$1@balder.stud.idb.hist.no>, teddyliu@tedani.com
says... > Yes, Hirobo has a twin rotor helicopter. Take a look at this site > http://www.hobbytron.net/%20Electric...By-Hirobo.html Thankyou for your reply. ![]() |
#7 |
Guest
Posts: n/a
In article <bitmmi$c37$1@hercules.btinternet.com>,
david_perry@btconnect.com says... > If the blades are symetrical then upside down or right way up, they wont > know! Ok cheers for your response. I find it strange that there are so many models that have blades turning clockwise. It almost seems like standard with models. I'll check the symetrical blades out. Thanks! |
#8 |
Guest
Posts: n/a
>models that have blades turning clockwise. It almost seems like standard >with models. That's just a fluke related to which way our glo engines turn. The engine crankshaft turning counter-clockwise, directly geared to the helicopters main rotor mast, thus spinning it clockwise. The few counter-clockwise rotor systems I've flown either had a two stage reduction between the engine and main rotor mast or had a gas engine that turned the opposite direction that our glo engines do. It really doesn't make much difference either way. The only time I "really" prefer a counter-clockwise rotation is on a scale bird. Watching a Jet Ranger fly around with a clockwise rotor system just doesn't look right! ;-) Fly Safe, Steve R. |
#9 |
Guest
Posts: n/a
In article <20030831230137.18054.00000218@mb-m06.aol.com>,
rhodesst@aol.com says... > >I find it strange that there are so many > >models that have blades turning clockwise. It almost seems like standard > >with models. > > That's just a fluke related to which way our glo engines turn. The engine > crankshaft turning counter-clockwise, directly geared to the helicopters main > rotor mast, thus spinning it clockwise. The few counter-clockwise rotor > systems I've flown either had a two stage reduction between the engine and main > rotor mast or had a gas engine that turned the opposite direction that our glo > engines do. > > It really doesn't make much difference either way. The only time I "really" > prefer a counter-clockwise rotation is on a scale bird. Watching a Jet Ranger > fly around with a clockwise rotor system just doesn't look right! ;-) I know exactly what you mean. I have always prefered counter-clockwise rotation blades. The reason I think was because when I started getting into heli's my favourite was the Jetranger. I always liked the way the blades looked when doing a turn away from observation, especially when going fast. It stuck since then, and I was a little disappointed when I saw models with clockwise rotation. It sounds strange I guess, but it's just my personal preference. ![]() |
#10 |
Guest
Posts: n/a
"Rhodesst" <rhodesst@aol.com> wrote in message news:20030831230137.18054.00000218@mb-m06.aol.com... > >I find it strange that there are so many > >models that have blades turning clockwise. It almost seems like standard > >with models. > > That's just a fluke related to which way our glo engines turn. The engine > crankshaft turning counter-clockwise, directly geared to the helicopters main > rotor mast, thus spinning it clockwise. The few counter-clockwise rotor > systems I've flown either had a two stage reduction between the engine and main > rotor mast or had a gas engine that turned the opposite direction that our glo > engines do. > > It really doesn't make much difference either way. The only time I "really" > prefer a counter-clockwise rotation is on a scale bird. Watching a Jet Ranger > fly around with a clockwise rotor system just doesn't look right! ;-) You mean you can TELL which way the blades are turning when they're flying Steve?? I want your eyes. (Get him guys, I'll get the knife!!!!" :-) -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#11 |
Guest
Posts: n/a
"PC" <F@you.com> wrote in message news:MPG.19bce16c4f80c6ba989725@text.news.ntlworld .com... > In article <20030831230137.18054.00000218@mb-m06.aol.com>, > rhodesst@aol.com says... > > >I find it strange that there are so many > > >models that have blades turning clockwise. It almost seems like standard > > >with models. > > > > That's just a fluke related to which way our glo engines turn. The engine > > crankshaft turning counter-clockwise, directly geared to the helicopters main > > rotor mast, thus spinning it clockwise. The few counter-clockwise rotor > > systems I've flown either had a two stage reduction between the engine and main > > rotor mast or had a gas engine that turned the opposite direction that our glo > > engines do. > > > > It really doesn't make much difference either way. The only time I "really" > > prefer a counter-clockwise rotation is on a scale bird. Watching a Jet Ranger > > fly around with a clockwise rotor system just doesn't look right! ;-) > > I know exactly what you mean. I have always prefered counter-clockwise > rotation blades. The reason I think was because when I started getting > into heli's my favourite was the Jetranger. I always liked the way the > blades looked when doing a turn away from observation, especially when > going fast. It stuck since then, and I was a little disappointed when I > saw models with clockwise rotation. > It sounds strange I guess, but it's just my personal preference. ![]() Easily satisfied with the purchase of a Vario machine. Most of those are anti-clock which looks wrong on an Allouette:-( -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#12 |
Guest
Posts: n/a
>Steve?? I want your eyes. (Get him guys, I'll get the knife!!!!" :-) > > > >-- >Beav Be careful what you wish for, Beav! <g> At almost 48, I'm in bad need of an updated prescription on my eye glasses. :-( It's just that spin up before take-off and the spool down after landing. <shrug> Fly Safe, Steve R. |
#13 |
Guest
Posts: n/a
"Rhodesst" <rhodesst@aol.com> wrote in message news:20030901124919.18258.00000257@mb-m13.aol.com... > >You mean you can TELL which way the blades are turning when they're flying > >Steve?? I want your eyes. (Get him guys, I'll get the knife!!!!" :-) > > > > > > > >-- > >Beav > > Be careful what you wish for, Beav! <g> > > At almost 48, I'm in bad need of an updated prescription on my eye glasses. > :-( I've got a few years on you Steve AND I've been diabetic for donkey's years. Fortunately my eyes are unaffected. > > It's just that spin up before take-off and the spool down after landing. > <shrug> I know, I was just joking. I can still fly a "proper" rotating Jet Ranger though, coz I've got the Kavan here. -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#14 |
Guest
Posts: n/a
The Lite Machines Corona 120 electric has anti-clockwise rotating blades.
http://litemachines.com/ Steve w8an PC wrote: > Hi there! > > I am trying to find an electric model heli which has blades turning anti- > clockwise instead of the usual clockwise rotation. Does anyone know a > model that has? I have searched and searched some sites but cannot find > any that have the anti-clockwise rotation. > The reason is because I am putting together a twin rotor heli and I > already have the clockwise rotating rotor, but now need the anti- > clockwise one. > TIA! |
#15 |
Guest
Posts: n/a
In article <vlahvha323i118@corp.supernews.com>,
sstuart@NOSPAM.glasscity.net says... > The Lite Machines Corona 120 electric has anti-clockwise rotating blades. > > http://litemachines.com/ > > Steve w8an Wow there's some nice looking heli's there. Thanks for the link... I liked the video section. ![]() |
| Thread Tools | |
| Discussion Co-Co Lama Rotating counter clockwise | bmcpeak33@comcas | Coaxial Helicopters | 1 | Jan 29, 2007 07:00 AM |
| motor-counter clockwise | cleanair | Power Systems | 4 | Feb 29, 2004 05:25 PM |
| contra rotating blades help........pls! | Devilfreak | Electric Heli Talk | 5 | May 13, 2002 02:01 AM |
| Hornet won't stop spinning counter clockwise...Help Please | gbagley | Electric Heli Talk | 10 | May 06, 2002 11:24 PM |
| Clockwise Or Counter Clockwise | Steven9026 | Electric Sailplanes | 3 | Jan 07, 2002 06:44 PM |
