Old Jul 07, 2011, 03:57 PM
x4FF3 is offline
Find More Posts by x4FF3
Germany
Joined Mar 2011
Build Log
Flyduspider (Pics)
Hi,
this is a short build log of a FlyduSpider-Hexacopter.
I chose this frame, because the design is very nice and it helps with orientation also i have lifting capabilities. As FC i will use the Flyduino with MultiWii.
Sensors will be WM+ and BMA020. The adavantage of this FC is, i can use MegaPirate as well. So i can easily switch to a 9-DOF-IMU and GPS
I got this nice package from Paul:
It included:
alu-Booms in perfect length
two centerplates
one batteryplate
one topplate
one Flydubution
one sensor bob
connectors for the Flydubution
First impression of the components were very good. Alu-Booms were perfectly cut and the plates were nicely made.
The batteryplate has four slot holes to balance the copter correctly.
My setup:
6x Keda 20-26m
6x Hobbywing Pentium 18A (i know they're to big, but i got them cheap )
8" props: 4x black 2x green
battery: Turnigy 2450mAh 30C
At first i soldered the Flydubution. The connectors fit very tight into the holes of the flydubution. I needed a caliper to get them in.
Then i drilled the booms (no pics off drilling, sry) and mounted the booms to the centerplates with M3x20 and headlock nuts:
then i needed 10mm spacers, which i did not found. So i use this construction:
After drilling and mounting i soldered pins onto the Flyduino and the sensors onto the Sensor BOB:
Next step was to mount the motors (using 16 mm mounting holes on the kedas):
Nearly finished! Mounting the ESCs with wire straps to the frame and connecting them to the motors:
Connecting them to the flydubution was a bit tricky, but it worked out well. It was hard to postion the ESCs that the front remains free, so it looks a little bit crowded.
Here is the maiden flight configuration:
and here is the final version (unfortunatley i broke the topplate from paul, but i will repair it!)
Specs:
Frame weight: 188 grams
Frame with motors: 576 grams
complete setup: still to measure (updated soon)
Probably sunday i am going to make a video of this "beauty"
and sorry for my bad english.
kind regards
david
x4FF3 is offline Find More Posts by x4FF3
Old Jul 07, 2011, 04:06 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Looks NIIIICCE
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Jul 07, 2011, 04:20 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
That beauty is crying for a hood, David!
Very good looking Hexa - do you plan to cover the electronix with a dome or something? And what about landing gears?
Can't wait to get mine from Paul...
kinderkram is offline Find More Posts by kinderkram
Old Jul 07, 2011, 05:07 PM
x4FF3 is offline
Germany
Joined Mar 2011
Hi,
electronics are goot without a dome i like it raw
landing gears only with an camera
at the moment i fly only with wm+ not even activated the bma020 once :X
Old Jul 07, 2011, 05:09 PM
Goofy23 is offline
Find More Posts by Goofy23
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
Thanks David, really nice pictures.
Can send you a replacement plate, next week i will get new Flyduspider plates.
If you want to drill the holes yourself Kinderkram you can have as much as you want (almost).
Goofy23 is offline Find More Posts by Goofy23
Old Jul 07, 2011, 05:10 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
i also thought about a landing gear and decided to get a 450 Helicopter gear.
Hubububi got a nice one from rctoys.de.
Old Jul 07, 2011, 05:21 PM
x4FF3 is offline
Germany
Joined Mar 2011
no problem paul, i had fun building this incredible frame!
topplate would be nice
btw landkamp next year, i also try to be there!
Old Jul 07, 2011, 05:55 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Sure, I love to drill (almost always)
Send me what you got and I'll show you what I did (almost everything)
But don't you expect such a nice build log. It's obsolete now... (anyway)
Old Jul 07, 2011, 08:10 PM
delta27 is offline
Find More Posts by delta27
delta27's Avatar
Joined May 2008
hello! a link to order the flyduspider ?
delta27 is offline Find More Posts by delta27
Old Jul 08, 2011, 12:01 AM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
next week i will have centerplates avaiable at www.flyduino.com
Old Jul 08, 2011, 03:49 PM
tom6696950 is offline
Find More Posts by tom6696950
Michigan
Joined Dec 2008
Nice i will have to do some ordering next week Tom
tom6696950 is offline Find More Posts by tom6696950
Old Jul 08, 2011, 04:14 PM
cyberdog is offline
Find More Posts by cyberdog
Sweden, Norrbotten County
Joined Jun 2007
Where can i order that frame ? Looks really nice.
cyberdog is offline Find More Posts by cyberdog
Old Jul 08, 2011, 06:42 PM
VIDEOMAN3 is offline
Find More Posts by VIDEOMAN3
VIDEOMAN3
VIDEOMAN3's Avatar
New York
Joined Jan 2009
Nice frame. I'll be ordering one along with some boards.
VIDEOMAN3 is offline Find More Posts by VIDEOMAN3
Old Jul 08, 2011, 07:53 PM
Goofy23 is offline
Goofy23's Avatar
Hamburg, Germany
Joined Jan 2011
many thanks.
First i will only have the centerplates avaiable, i think for a reasoable price in matt black with a power distribution integrated in 1.6mm G10.
I may have anodized and predrilled arms later, but time will tell, i will offer a PDF with the meassurements of the holes too, so your local homedepot can help in the meantime.
The Flyduspider is ment for 8" props and does his job in this config very well as Norf and Warthox showed impressively.
Bigger Version will come, but be sure, he is fast, as Warthox told, its one of his fastest copters, only with 8", weight ratio is very good.
I hope i am not wrong there Markus, but you told me
Old Jul 09, 2011, 07:53 PM
hubibubi is offline
Find More Posts by hubibubi
hubibubi's Avatar
Deutschland, SA
Joined May 2011
a picture of this
Originally Posted by goofy23 View Post
i also thought about a landing gear and decided to get a 450 helicopter gear.
Description:
hubibubi is offline Find More Posts by hubibubi
For Sale NEW**Walkera CB100 PRO KIT (*EDIT now has pics*) EN4CER Aircraft - Electric - Helis (FS/W) 5 Aug 08, 2011 08:39 PM
Discussion Bill Bridges Benefit Race Pics!! fastmax Off-road Cars 2 Jun 26, 2011 10:47 PM
Gallery Pics tests - split from the "how to post pics" guide jmtdmt Test Forum 34 May 18, 2011 06:49 AM
Discussion SEFF 2011 Pics/Video Thread! (Post your SEFF pics and video here!) edge5foamy SEFF 2011 76 Apr 29, 2011 11:12 PM
Discussion Seff Pics, pre first day at Mac's (with Pics) brian wallis SEFF 2011 49 Apr 16, 2011 08:08 AM
