Old Jul 26, 2011, 04:37 PM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
Bought from hobby king, but any packs with similar specs will work just fine! I know some people are having great luck with packs from hobby partz, value hobby, etc
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Jul 26, 2011, 05:24 PM
corsair214 is offline
Find More Posts by corsair214
corsair214's Avatar
United States, IN, Danville
Joined Mar 2007
352
hi must buy one. will this motor work optima 450 950 kv?
corsair214 is offline Find More Posts by corsair214
Old Jul 27, 2011, 02:38 PM
aerofundan's Avatar
Panama
Joined Jul 2005
It seems like it could work!, only advice i can tell you is to try it, and if it doesnt works just change the motor to something else!
Site Sponsor
Old Jul 28, 2011, 11:47 AM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
I want this!
SD One. is offline Find More Posts by SD One.
Old Jul 29, 2011, 11:33 AM
aerofundan's Avatar
Panama
Joined Jul 2005
So get one!!! you will love it, i can guarantee you that you won't regret it!!!! its my favorite foamy!!!
Site Sponsor
Old Jul 29, 2011, 12:10 PM
philfun is offline
Find More Posts by philfun
Windsor, Canada
Joined Sep 2003
I don't agree with Dan.
GET TWO !!!!!!!!
philfun is offline Find More Posts by philfun
Old Jul 29, 2011, 12:59 PM
JackRC is offline
Find More Posts by JackRC
JackRC's Avatar
Joined May 2011
GET TWO !!!!!!!!
I ordered it on Monday night and it arrive at my door yesterday. Already strated the build and everything should be done tonight, looking forward to the weekend !!! beautiful plane !
Thanks for the build thread, it did clear me some question during the assembly.
JackRC is offline Find More Posts by JackRC
Old Jul 29, 2011, 08:54 PM
maxbee is offline
Find More Posts by maxbee
United States, TX, Houston
Joined Feb 2011
What is your AUW? I finished mine two weeks ago and its sitting around 17.5oz. I went with flat carbon wing spars ( a few others in certain areas also) and a Hyperion Zs2213-18 1042Kv. Man that is one nice running motor.
Maxbee
maxbee is offline Find More Posts by maxbee
Old Jul 30, 2011, 01:33 AM
jofo1 is offline
Find More Posts by jofo1
jofo1's Avatar
United States, CA, San Jose
Joined Nov 2003
Just finished mine. 420g auw. 3S-1300, CC25, Parkbec, and 5045 digi servos.
jofo1 is offline Find More Posts by jofo1
Old Jul 30, 2011, 08:05 PM
JackRC is offline
JackRC's Avatar
Joined May 2011
without battery: 366g or 12.95 oz
with G-Force 1000mAh 30C battery: 448.6 g or 18.84 oz
All recommended setup except that I use carbon fiber push rod insated of pull pull cables. I cut short almost all the servo wires and re-solder it back together to save weight and make it looks clean and nice.
Build is smooth and enjoyable. The only thing I don't like is that there is no pre-cut pilot hole for all the servos so I spent a long time checking out build thread and pictures to make sure I am doing thihgs correctly. Also another thing is that the prop adapter from Twisted Hobby isn't straight (bent) so it spinning funny, will probably call on Monday to see what they can do.
Maxbee
Old Jul 30, 2011, 08:21 PM
JackRC is offline
JackRC's Avatar
Joined May 2011
maiden
Maiden the RS-352 today and it was a blast. so much power at my disposal with good control. However I've extended all the servo travel to 150% percent (max on JR) and still feel like I can manage more. probably will play with the servo arm holes to see if I can squeeze more travel out of it.
The foil wing sure give the plane lot of advantage especially at high speed, very precise and no sign of rattle or flutter like other EPP plane. rolling harrier is smooth even with throttle down. it just keep rolling with the momenteum. 4 points roll is again precise and predictable. Only thing I have concerned is the torque hanging. It seems that rudder travel or thrust angle is not right/enough so it's kinda hard to maintain at perfect still, will figure it out later.
attached is the side by side pictures with my 33" 3DHS Extra 330.
Old Jul 30, 2011, 11:03 PM
biznitch is offline
Find More Posts by biznitch
Wantirna Sth Vic,Australia
Joined Jul 2006
To get more travel just make servo horn extenders like on your 3DHS EPP or use the extra ones in their kit.
biznitch is offline Find More Posts by biznitch
Old Jul 31, 2011, 01:51 AM
maxbee is offline
Joined Feb 2011
I went with the fiderglass horns from Radical RC. They have multi attachment points to get all the throw. I will can some better pics if you like.
Old Jul 31, 2011, 03:17 AM
JackRC is offline
JackRC's Avatar
Joined May 2011
I just drill new holes on the existing horn and that help. will fly it tomorrow and see what's up.
Old Aug 02, 2011, 03:10 AM
JackRC is offline
JackRC's Avatar
Joined May 2011
Problem with ESC
Hi folks, I am having problem with my sunrise model pro 25A ESC from Twisted Hobbies and I wish you guys can shade some light for me.
1. It does not make any sound when switching on. I tried to program it to no-brake without luck, it still applying brake whenever throttle down.
2. It always bump the throttle starting point, and always leave the first 1/8 stick empty on my JR 9303, I tried to adjust my throttle curve and change the throttle starting point but after a reboot it bump the starting point again. EX: from 17% to 25%
Do you guys have the above problems or just me?
Jack
