Old Jul 05, 2011, 09:51 PM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Why are the rear wheels angled inward?
I have a Traxxas Stampede and the rear wheels angle inward. I've noticed other Monster trucks with the same setup. There doesn't seem to be any adjustment, either. I assume there's a reason, but it escapes me. Can someone enlighten me?
Balr14 is online now Find More Posts by Balr14
Old Jul 05, 2011, 10:01 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Its called toe in (or toe out where the wheels point outward) -
http://www.rc-truckncar-tuning.com/toe-in.html
Rear is typically fixed. On some MTs you can buy parts that change it.
Duster_360 is offline Find More Posts by Duster_360
Old Jul 05, 2011, 10:08 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Toe in on the rear helps the car drive out of the corners.
If you can imagine the outside tire taking most of the load because of the body roll and suspension compression this means that the rear tire with the most grip/thrust coming out of a corner is pointing in the direction of intended travel and not thru the berm if they had no toe.
Power off the car and turn the wheel hard to the right. Now push the car into the corner like its turning and you will see how the tire is pointing the way you want to go.
1320fastback is offline Find More Posts by 1320fastback
Old Jul 06, 2011, 01:35 AM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Thanks, I have to remember that. I'm always getting toe-in mixed up with caster/camber.
Discussion From a newbie, are the rear wheels on my E-Revo turned in to much? OgtheKing Electric Power Cars 10 Dec 21, 2015 03:47 PM
Discussion What are your favorite battery connectors and why? lacofdfireman Batteries and Chargers 13 Jun 29, 2011 09:32 AM
Discussion Why is the trailing edge of the wing angled on a Balsa Bandit? Tumbler Electric Ducted Fan Jet Talk 4 Mar 16, 2011 05:12 PM
Why are the rear tyres on everyones bikes nice and fat and mine are thin? tod438 Motorcycles 6 Jul 23, 2004 01:28 PM
Multi engines - why are the engines angled outwards on full size? Moogee Power Systems 11 Jul 16, 2001 09:22 AM
