Great Planes Goldberg Gentle Lady Glider ARF |
| Wingspan: | 79" (2005 mm) |
| Wing Area: | 674 sq. in. (43.5 sq dm) |
| Weight: | 2.0-2.25 lb (910-1020 g) |
| Wing Loading: | 7-8 oz/sq. ft. (21-24 g/sq. dm) |
| Length: | 41 in (1041 mm) |
| Servos: | Futaba S3004 Standard Ball Bearing Servos (2) |
| Receiver: | Futaba R2006GS receiver |
| Transmitter: | Futaba 6J 6-Channel 2.4 GHz S-FHSS |
| Launch Equipment: | Dynaflite by Great Planes Standard Up-Start |
| Battery: | 4.8V 600mAh NIMH |
| Manufacturer: | Great Planes |
| Available From : | Carl Goldberg Products Retailers |
Now here is a sailplane that really brings back some memories. Released around 1980, the original Gentle Lady has introduced countless sailplane pilots to the art of thermal soaring. Still popular today, the Gentle Lady has seen use in one design contests, power conversions, and slope soaring. One could hand launch and catch a Gentle Lady before purpose built hand launch sailplanes were available. I built a Gentle Lady from a die cut kit when I returned to flying following my teenage hiatus from the hobby and flew it for years.
Nicely packed. |
Fuse packed under the wings. |
Contents of Hardware Pack. |
Hobbico provided a Futaba 6J 6-Channel 2.4 GHz S-FHSS transmitter, Futaba R2006GS receiver, two Futaba S3004 Standard Ball Bearing Servos, and Dynaflite by Great Planes Standard Up-Start for the review.
| Dynaflite Standard Up-Start |
The 15 page instruction manual is loaded with clear pictures and text laid out in a logical order. Much of the assembly is already complete. Anyone capable of reading a following the detailed instructions contained in the manual should have little trouble. The manual also covers initial flights, general flying tips, and details of thermal, slope, and contest soaring.
The instruction manual suggests using a covering iron to remove any wrinkles in the covering, but fails to mention checking the flying surfaces for warps. I recall ¼” of wash-out was specified for each wing tip panel in the kit-built Gentle Lady instructions. The entire plane was virtually wrinkle-free, but each of the wing’s tip panels had different amounts of wash-in. To correct the wash-in condition, the inner wing panel is held between the legs (or by a helper), some wash-out twisted into the outer panel and the wrinkles in the covering shrunk out with a heat gun or covering iron. The amount of wash-out is checked periodically until the desired ¼” is reached. A standard hexagonal pencil makes a handy measurement gauge. The various colors of the finish are layered darker colors on top of lighter colors. The multiple layers of covering makes it somewhat difficult to both shrink-in the desired amount of wash-out AND keep the wing panels wrinkle free. It took several passes on each panel using both a heat gun and iron to get everything just right.
There was insufficient clearance between the pushrods and wing when using the “Z”-bend specified in the instructions. I used a solder-on threaded coupler and 2-56 clevis in place of each “Z”-bend. The result is a neater, more compact, and adjustable control rod. There is plenty of room for the battery, receiver, and switch forward of the wing. I installed the switch under the hatch. Doing so keeps the exterior of the fuselage neat and protects the switch from being tripped inadvertently. The hatch latch facilitates easy removal and replacement of the hatch; making the internal switch location practical. I attached a Hobbico Volt Watch RX battery monitor to the receiver battery with clear heat shrink tubing and plugged it into an unused receiver channel. I used hook and loop material to retain the receiver and battery and padded the battery with foam.
The threaded portion of the included tow hook was too short to reach the installed tee nut. I removed the factory installed tee nut using a 3 mm machine screw and a soldering gun to heat and gently push the nut out. I countersunk the mounting hole from the inside, lowering the installed position of the tee nut so the tow hook could be used. Unfortunately, the 3mm tow hook threads stripped when tightened. I used a 4-40 tow hook and tee nut in place of the factory hardware. Both stock tow hook mounts appear excessively stout. Historically, a birch plywood insert in the fuselage bottom and 1/8” birch plywood doubler on the inside of the fuselage floor have proven to be plenty strong for 2-meter (and larger) wooden sailplanes. The wings would likely give way well before the tow hook pulled out of the fuselage.
I added a nose skid to the nose and a tail skid to the rear. Neither of these items is included. A nose skid should be. The skid protects the bottom of the nose from landing damage and keeps the plane from sliding along the ground after touchdown. I repurposed a Great Planes nylon wing tip skid for the tail skid.
The Standard Up-Start requires some basic assembly. Special knots used to tie the various components together are clearly illustrated and easy to tie. Wind the assembled Up-Start on the provided reel starting with the parachute end.
There are some notable improvements in the Gentle Lady ARF over the original kit version. The use of laser cutting improves the overall fit and finish of the model and makes use of lightening holes throughout the model practical. The wing is retained with rubber bands using traditionally located dowels installed through the fuselage sides. The original kit design used centrally located dowels in the fuselage formers. The original arrangement required significantly beefier fuselage formers immediately fore and aft of the wing and required removal of the hatch to mount or remove the wing. The original kit design used only the mounted wing to retain the hatch. As a result, the hatch on the original kit design was prone to loss during storage and transport. The Gentle Lady ARF incorporates a mechanical latch that secures the hatch independent of the wing.
I programmed the Futaba 6J transmitter to the control throws specified in the product manual. I found it necessary to forcibly deflect the rudder left and right several times to “soften” the hinge line in order to obtain the 1-5/8” inch high rate rudder travel specified in the instructions. I marked and checked the specified center of gravity at 3 5/8 inches aft of the wing leading edge at the fuselage. 3.2 oz. of weight was added to the nose to obtain the recommended CG. The rear tow hook location is approximately 1/8” forward of the recommended center of gravity and should provide a steep climb and stable handling on launches. Ready to fly weight of the review model was 2.0 lbs.
A few hand throws confirmed that the center of gravity, control throws and trim were in the ballpark. Javelin style throws can result in sufficient altitude for quick low level thermal hunting followed by a hand catch or landing practice.
Select the launching location and walk directly upwind 140 paces. Stake the end of the Up-Start to the ground. Unroll the tubing and line as you walk back to the selected launch area. You should run out of line about 40 paces short of the selected launch area. Stretch the Up-Start approximately 40 paces for a full launch. Over-stretching the Up-Start will not result in higher launches, but will significantly reduce the useful life of the tubing. Use a helper if possible. There is a significant amount of tension on the line when fully stretched. Always handle the line with the chute folded in your hand. Never put your finger through the ring or wrap the line around the fingers or hands. Confirm that the radio is switched on and the aircraft is ready to launch before hooking the Up-Start to the tow hook.
The Gentle Lady launches with ease. Light winds work in the plane’s favor when launching. A five mile-per hour wind will result in a significantly higher launch then one under dead calm conditions. Throw the plane directly into the wind, firmly and slightly upward with the wings level. Thrown properly, the Gentle Lady will fly itself all the way through the launch. When the tension between the Up-Start tubing and the aircraft has equalized, the parachute will detach and fall back to earth.
The Gentle Lady can also be winch launched provided the pilot has a well trained foot. Modern winches can easily tear the wings off the Gentle Lady if the launch conditions (wind) are not considered and a very gentle touch used on the pedal. It is also worth noting that the relativity heavy line used on most of today’s winches limits the launch height attainable by smaller wooden sailplanes. The Up-Start, using a reasonable amount of tension results in a gentler, more consistent, and higher launch than those using a winch.
The Gentle Lady has a rather sedate flight envelope. Stalls are predictable and easily recoverable by simply releasing the elevator stick and allowing the plane to stabilize itself. The plane indicates lift well. Its light weight means, that when flying in light conditions, almost any unintended deviation in flight path is probably an indication of lift. Turning back into the flight path deviation and flying big flat circles will usually have the Gentle Lady gaining altitude in even the weakest lift. The low control rates were quickly dispatched in favor of the high rates. High rates provide more control when it is needed without making the plane feel too sensitive to stick movements. The Gentle Lady really shines in light wind conditions. Five to seven MPH winds are easily manageable with ten MPH winds being a reasonable upper limit for an experienced pilot using high control rates. The plane can be flown in windier conditions with the addition of ballast weight to increase the wing loading. Doing so makes pilot skill critical as the airframe will be more subject to damage on launch and landing due to both the additional weight being carried and the windy conditions.
The lack of spoilers means that energy is managed with the elevator. The airframe bleeds off excess energy (airspeed and altitude) well. An afternoon or two spent shooting landings will provide an excellent feel for how to manage the approach and landing. Flying the same landing pattern every time and adjusting all three “legs” of the pattern for conditions are keys to success. The Gentle Lady’s flight performance makes landing consistency fairly easy.
Setup Tip for landing: If the transmitter supports a mix that will mix throttle to elevator, setup a “landing mode” with the mix adding the equivalent of a click or two of down elevator trim when the throttle stick is lowered. The tad of down elevator helps the plane maintain airspeed (energy) during the approach and landing. Use of the throttle stick for the landing flight mode is standard practice for sailplanes and is a good habit to develop early on.
Absolutely! The Gentle Lady is well known as an excellent thermal soaring trainer. A bit of assistance from an experienced sailplane pilot is advisable until the student is familiar with the basics of launching and energy management. Following that, the Gentle Lady makes an excellent, low cost, thermal soaring trainer. Skills acquired can be applied directly to larger and more advanced sailplanes and won’t have to be “un-learned” as the pilot chooses to advance.
My son Phillip did an excellent job of shooting the following video in a single take from launch to landing. The video was taken in the mid-morning flying in variable winds of five to seven MPH.
Great Planes has updated the design and made this excellent first sailplane even more accessible in a quality, affordable, Almost Ready to Fly form. The Standard Up-Start is ideally suited to the airframe and provides consistent worry-free launches. The Futaba radio gear performed flawlessly. The simple pleasure of a High-Start launched wooden sailplane can be easily lost among the costly and complex, molded, full-house sailplanes of recent years. The Gentle Lady ARF brings simplicity back in spades. The relativity small size, light weight, and affordable Up-Start launching make the Gentle Lady an ideal sailplane for park flying. The light, rugged, and time-tested design is equally at home flying at the club field.
• Light finished weight.
• Stunning appearance and color scheme provides excellent contrast and distance visibility under various light conditions.
• Excellent flying manners.
• Poor quality tow hook.
• Nose skid not included.
• One piece wing makes storage and transportation difficult.
| Thread Tools |
Lots of memories with the Gentle Lady for me. Built them with different groups of boy scouts. Added battery powered Christmas lights inside the wing with clear covering for my first night flyer in the 90s. Die crunch kit and some fit together better than others but they can fly great. Mike H
Latest blog entry: New receiver packs and asking Castle for...
| Thread Tools | |
| Wanted Goldberg Gentle Lady and/or Oly II | tkhero | Aircraft - Sailplanes (FS/W) | 8 | Jun 17, 2011 02:45 PM |
| Discussion Carl Goldberg Gentle Lady old stick build questions | Nescent | Electric Plane Talk | 6 | Jun 13, 2011 09:17 AM |
| Sold Gentle Lady KIT by Carl Goldberg NIB | slopepilot | Aircraft - Sailplanes (FS/W) | 4 | May 15, 2011 01:26 PM |
| Found Goldberg Gentle Lady Plans | mpotter187 | Aircraft - Sailplanes (FS/W) | 1 | Apr 21, 2011 12:59 PM |
