Old Dec 29, 2011, 03:27 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Originally Posted by Vantagepoint View Post
Try the Scorpion 3026/ 1600kv on a 4s 3300 30c pack. With the APC 8x6, managed to get 128.6 mph. Not a blistering speed, but definitely an improvement over the speed we were able to squeeze from the Pogo with the Eflite Power 25 on 4cells swinging an 8x8 apc prop.
Are you running a from mount frame for the motor?
ViperZ is offline Find More Posts by ViperZ
Old Jan 03, 2012, 03:07 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
67 amps during a bench run with the apc 8x6 e prop The apc 8x8 e prop pushes this setup well above 70 amps. I have tried the apc 8x10,8x9, 7x10, and Graupner 7x7 e props. The 8x6 seems to provide the best performance with the motor (Scorpion 3026/1600kv) battery combo. My setup is not by any means the hottest setup for the Sundowner 36, but since I have smoked 5 motors 3 ESCs (including a Castle Ice 100 amp), it has proven to be the most reliable.
Don't need much to fry a CC Ice 100 just plug it into a Lipo and out comes the magic smoke
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Jan 03, 2012, 05:57 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
@ Vantagepoint.... That should have read:
"Are you running a Front mounted frame for the motor?" such as one of these standoff mounts...
Looking at that Scorpion 3026/1600kV it looks to be a front mount motor and would need something like it. Just wondering what you're using.
Old Jan 03, 2012, 06:20 PM
Adrian_M is offline
Joined Dec 2010
The 3026-1600 is no longer avaliable the new one is HK-3226-1600kv can be front mounted by reversing the shaft
A better motor to use would be the Hyperion ZS-3025-06 and would have a better prop selection i would think that the SD 36 would need a bigger prop than 8" a 10" inch prop would give it more thust
I run that same motor in my DF Hyperion HS-3026-1600Kv with 8x6E apc 4s 265035-70c lipos it pulls 102amps @ 1452watts my best speed so fat is 251kph
Just my opinion
Cheers
http://rcb.shopnz.biz/catalog/produc...513e34871138d7
Old Jan 03, 2012, 07:03 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Just my opinion
Cheers
Once again thanks for the great info Adrian! I notice that mount was no longer available, but needed it just as reference. The funny thing is it came from your post as well in the Sundower 50 Fast Set-ups thread
Is it tough to reverse the shaft on the Scorpions or Hyperions? How much work is involved? It would seem on my SD 50 Scorpion 4025-440kv, the shaft protrudes out nearly the same on each end so it can be front or back mounted.
I have noticed in some of the higher power Turnigy the motor comes with 2 prop adapters, one for the shaft, and one for the frame, so you can use it either way...
I'll look into those recommendations as I do want to run a hotter than legal set-up for my next E-F1 build.
Old Jan 03, 2012, 07:36 PM
Adrian_M is offline
Joined Dec 2010
Hi Viper i have never done it but Steve C has and someone else
I still think that 1600kv motor on the SD36 would limit you to prop size and no more than 4s
I have been looking at the SD36 and my motor would be the Hyperion ZS-3025-06 or the Scorpion equivalent
But i just have too many planes to build and not allot of time in my hands
Old Jan 03, 2012, 07:59 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
I have been looking at the SD36 and my motor chice would be the Hyperion ZS-3025-06 or the Scorpion equivalent
Yeah, I'm not really looking to build a SD 36 right now, rather just trying to see and learn what others are using for power systems outside of the regulated E-F1 arena, that can be applied to my current planned E-F1 project.
I'm with you, so many projects I would like to start, but so many that need to be finished too
Old Jan 04, 2012, 11:31 AM
Dave P is offline
Find More Posts by Dave P
United States, CT, Mansfield
Joined Dec 2006
Hi everyone Just received my SD 36 and I'm gonna be starting the build soon.As they recommend epoxing the horizontal stab in place ,I was wondering if anyone was aware of a nice video to show a good way to do it.Cant seem to find one on utube.All the planes ive built so far have always recommended ca for the horizontal stab,so I have never epoxied one in and dont want to screw it up and make a mess.Thanks for any suggestions. Dave
Dave P is offline Find More Posts by Dave P
Old Jan 04, 2012, 11:47 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
I use 30-minute epoxy rather than the recommended 15-minute epoxy to give myself a little more time to be sure things are properly positioned before the glue sets. I also use 90% isopropyl alcohol to clean up the excess. The higher percentage rated alcohol is a little harder to find, but it sure cleans up the epoxy better. As far as a video, I don't think I've ever seen one.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jan 08, 2012, 05:33 AM
Dave P is offline
Joined Dec 2006
Thanks McD I'll give that a try
Old Jan 08, 2012, 08:33 AM
Nachbars Lumpi is offline
Find More Posts by Nachbars Lumpi
Germany
Joined Mar 2011
Hi all,
also building a SD 36 at the moment.
Unfortunately my elevator does not provide much throw up and down maybe 10mm each direction. Is this enough?
How much power do I need to fly it? My motor let's me use 3S or 4S. My prefered prop would be an APC 10x10.
First pic is 3S second pic is 4S.
Nachbars Lumpi is offline Find More Posts by Nachbars Lumpi
Old Jan 08, 2012, 03:31 PM
kingsflyer's Avatar
Joined Sep 2005
I usually look at the watts/pound as a pretty good indication of performance for my electric planes. With your 4-cell setup, you are getting about 150 watts/pound which is normal sport plane performance power. Your airspeed will be about 70 MPH which should be fine for sport flying and aerobatics.
McD
Old Jan 08, 2012, 05:08 PM
Vantagepoint is offline
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
Originally Posted by Nachbars Lumpi View Post
Hi all,
You will not need much throw on the elevator. I had mine set up on a 3 position switch and flew the plane on low rates (approximately 10mm). Unfortunately after more than a 100 flights on my SD 36, it was totalled today as a result of radio lockout. It was definitely a fun plane to fly.
Vantagepoint is offline Find More Posts by Vantagepoint
Old Jan 12, 2012, 12:30 PM
highroller79 is offline
Find More Posts by highroller79
highroller79's Avatar
United States, MS, Ocean Springs
Joined Sep 2011
Power 46
I have just finished a new set up for me, I started out when the sundowner 36 was released with a eflite power 46 with a 60amp esc, and a 5s battery and a 12x12 prop. It flew great and I had no problems. I have re-worked the set up by up-grading to a eflite 80amp esc and a 6s 3300 gen aces battery. I should hit my mark of 135+. I will let yall know.
highroller79 is offline Find More Posts by highroller79
Old Jan 14, 2012, 02:28 AM
mrgriz is offline
Find More Posts by mrgriz
mrgriz's Avatar
Joined Oct 2006
short video from my Sundowner 36
power-train is KDA36-12XL , 770kv similar specs to E-flite 32,
CC 100 amp ICE speedy , 6s 5000mah lipo (Turnigy nano-tech) and 10x10
sundowner 36 (2 min 17 sec)
mrgriz is offline Find More Posts by mrgriz
Article Hangar 9 Sundowner 50 ARF Electric Review dawnron1 Sport Planes 44 Apr 13, 2011 03:04 PM
Build Log Hangar 9 Sundowner Formula 1 ARF Brill 1 Giant Electric Planes 17 Apr 09, 2010 10:21 AM
Sold Relist: New Arf, Hangar 9 Sundowner Giant Scale wellcraft Aircraft - Fuel - Airplanes (FS/W) 6 Nov 27, 2008 10:13 PM
Sold Hangar 9 Sundowner new in box ARF wellcraft Aircraft - Fuel - Airplanes (FS/W) 15 Nov 24, 2008 03:36 PM
Discussion Sundowner 50 ARF Hangar 9 VENDIDO, Gracias !!! Mainland Mexico 11 Nov 20, 2008 06:21 PM
