Old Oct 19, 2011, 03:24 PM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Sounds like you've got a winner there Richard. I agree that the SD36 attracts a lot of positive comments at the field and always brings a big grin to my face every time I fly mine.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Oct 26, 2011, 12:01 AM
stegl is offline
Find More Posts by stegl
stegl
Kelowna , BC
Joined Nov 2008
Sundowner 36
The speeds I am reading at arround 100 mph and higher ; are thes wishfull or how are they measured ?
stegl is offline Find More Posts by stegl
Old Oct 26, 2011, 07:46 AM
kingsflyer's Avatar
Joined Sep 2005
100+ MPH is the norm for EF-1 racers. Exact speed measurements are possible using Doppler Shift APPS available for your smart phone or by using radar guns.
McD
Old Nov 18, 2011, 07:57 PM
mrgriz is offline
Find More Posts by mrgriz
mrgriz's Avatar
Joined Oct 2006
Just a comment for anyone thinking of buying this plane , it fly's really nice and smooth , its a real enjoyable plane
I don't race it , just fly at my club.
my one runs stuff that I had from another project but has proven to work well and be 100% reliable in this plane.
The motor is a KDA36-12XL , 770kv similar specs to E-flite 32,
CC 100 amp ICE speedy , 6s 5000mah lipo (Turnigy nano-tech) and 10x10e apc prop .
looking forward to the E-flite shoestring
mrgriz is offline Find More Posts by mrgriz
Old Nov 30, 2011, 08:07 AM
kingsflyer's Avatar
Joined Sep 2005
Looks like the Sundowner 36 is on sale!
http://www.horizonhobby.com/products...36-arf-HAN4520
Check it out!
McD
Old Dec 03, 2011, 07:56 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Check it out!
McD
You know I would consider it if I didn't already have 2 new E-F1 planes coming....
ViperZ is offline Find More Posts by ViperZ
Old Dec 20, 2011, 01:01 PM
edubs2121 is offline
Find More Posts by edubs2121
If you got 'em, fly 'em
United States, TX, The Woodlands
Joined Aug 2009
As quoted from the reviewer:
"The E-flite Power 25 1250kV motor has been officially approved by NMPRA for the EF-1 event and has become the motor of choice for this event. Since E-flite made two versions of the Power 25 motor, I made sure I had the 1250kV NMPRA version for this Sundowner review. When I tried to mount the motor, I found that Hangar 9 had updated the spacer and bolt lengths for the Power 25 and that the manual still referred to the original shorter dimensions. The Power 25 motor used 30 mm (1-3/16") spacers and 45 mm (1-3/4") bolts to mount the motor to the firewall. Future versions of the Sundowner manual will reference these longer dimensions."
AAAAAAAARG!! Now you tell me! I spent about an hour trying to thread the recommended lengths in the assembly manual through the drilled holes. The two bottom holes on the fire wall were easy to thread through but the upper two were another matter. Since I need to use the longer (45mm) bolts, are there any suggestions to make it easier to thread these through the top two holes?
Thanks for your expertise.
edubs2121 is offline Find More Posts by edubs2121
Old Dec 20, 2011, 08:16 PM
kingsflyer's Avatar
Joined Sep 2005
Sorry, but there is no easy way to get them through the holes. You may want to try using the fuel tubing trick shown on page 39 of the manual. That will hold the bolt to your ball driver wrench and help guide it to the hole in the firewall.
McD
Old Dec 22, 2011, 01:23 AM
ace1726 is offline
Find More Posts by ace1726
United States, FL, Orlando
Joined Aug 2007
Hey Guys, I also love my 36 but I must admit I was hoping it would be quicker. I am using the OS 30 outrunner with an APC 12x10 prop, Eflite 60 ESC on a Turnigy 4S 300 mah pack. Overall I am happy with it as it flies great and is easy to land, but a little dissapointed in the speed. I figured that at just over 1000 watts it would be faster. Any advice?? I am thinking about going to a 6S 3000 setup and just run a smaller prop.
ace1726 is offline Find More Posts by ace1726
Old Dec 22, 2011, 08:26 AM
kingsflyer's Avatar
Joined Sep 2005
The stock racing setup is running about 1000 watts with 4S 2600 mah battery packs and the speed is right about 100 MPH on an APC 8x8 prop. The OS 30 only has a 750 kV so you are going to have to go to more cells to even get stock performance levels with that motor. More cells will mean more weight and that will degrade performance somewhat. I'd recommend getting the OS 25 or the E-Flite Power 25 and trying the stock setup if you want more speed.
McD
Old Dec 26, 2011, 08:30 PM
Vantagepoint is offline
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
Try the Scorpion 3026/ 1600kv on a 4s 3300 30c pack. With the APC 8x6, managed to get 128.6 mph. Not a blistering speed, but definitely an improvement over the speed we were able to squeeze from the Pogo with the Eflite Power 25 on 4cells swinging an 8x8 apc prop.
Vantagepoint is offline Find More Posts by Vantagepoint
Old Dec 27, 2011, 05:28 AM
GregG is online now
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Has anyone tried an APC 8 X 10 or 7 X 10 on this plane?
GregG is online now Find More Posts by GregG
Old Dec 27, 2011, 11:12 AM
Joined Aug 2009
Just wanted to report that I successfully maidened my Sundowner yesterday. My setup includes the Power 25 1250 kv on a 8 X 8 propeller. I first used an eflite 4S 3200 as well as a CC Pheonix 80 amp esc. Having flown the eflite Pogo extensivley, I flew her with less throw (75%) and a lot of expo (45%).
I fully expected a strong torq roll to the left and the Sundowner did not disapoint. I corrected with a good bit of rudder.
She flew much more stable than the Pogo and nearly as fast. The approach and landing was a lot more forgiving than the Pogo and not as hot.
A buddy let me run her on a Turnigy nano 5s 4000 and I think that's the right battery for my set up. I would guess she's flying at about 110 to 115 mph with that battery.
All in all, love this plane. The peanut gallery commented on how stable and smooth she is in the air along with her good looks. Video and photo to come shortly.
Old Dec 27, 2011, 01:36 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
What are the amps WOT on that setup?
Rifraf is offline Find More Posts by Rifraf
Old Dec 29, 2011, 04:15 PM
Joined Aug 2008
67 amps during a bench run with the apc 8x6 e prop The apc 8x8 e prop pushes this setup well above 70 amps. I have tried the apc 8x10,8x9, 7x10, and Graupner 7x7 e props. The 8x6 seems to provide the best performance with the motor (Scorpion 3026/1600kv) battery combo. My setup is not by any means the hottest setup for the Sundowner 36, but since I have smoked 5 motors 3 ESCs (including a Castle Ice 100 amp), it has proven to be the most reliable.
Article Hangar 9 Sundowner 50 ARF Electric Review dawnron1 Sport Planes 44 Apr 13, 2011 04:04 PM
Build Log Hangar 9 Sundowner Formula 1 ARF Brill 1 Giant Electric Planes 17 Apr 09, 2010 11:21 AM
Sold Relist: New Arf, Hangar 9 Sundowner Giant Scale wellcraft Aircraft - Fuel - Airplanes (FS/W) 6 Nov 27, 2008 11:13 PM
Sold Hangar 9 Sundowner new in box ARF wellcraft Aircraft - Fuel - Airplanes (FS/W) 15 Nov 24, 2008 04:36 PM
Discussion Sundowner 50 ARF Hangar 9 VENDIDO, Gracias !!! Mainland Mexico 11 Nov 20, 2008 07:21 PM
