Old Sep 09, 2012, 04:52 PM
Georgetown IN
Joined Jul 2010
Set the spoilers up so that full aileron deflection drives the down side aileron even with the trailing edge, and the up side doesn’t bind
Thank you, I set it up this way with flap switch to "land". For mid-flaps, I used half travel. Can't wait to try it....
10AE is offline Find More Posts by 10AE
Old Sep 09, 2012, 05:04 PM
NCSS VP / Event Coordinator
motowncali's Avatar
Napa, CA
Joined Oct 2003
Originally Posted by QDRevenger View Post
Update, second flight this morning, upped the timing a wee bit. 129.9mph this time, I'm happier but still not quick enough.
QDRevenger.
Please confirmation which prop you got these numbers. The 8 X 8 or the 7.5 X 8? Also what is your flight time?
Mo
motowncali is offline Find More Posts by motowncali
Old Sep 09, 2012, 05:58 PM
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
Hey Mo, at the moment I am running the 7.5 x 8. Flew 4mins plus landing time and put back 2550mAh. Plenty of lipo left.
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Sep 09, 2012, 11:57 PM
motowncali's Avatar
Napa, CA
Joined Oct 2003
Thanks. I have a nitro to electric conversion I am thinking of doing and trying to decide which motor prop combo will be best. This is the second thread where the hyperion motor that you are using has come up.
Mo
Old Sep 10, 2012, 03:41 AM
QDRevenger's Avatar
Joined Jun 2011
I would suggest looking at something a little different. I think a bigger prop is required as the cowl is quite fat. I am trying to figure out my next step, prop diameter around 9" or 10" this time. I'm trying my best to keep my Sundowner 4cell and around 100-120A but struggling to find something suitable.
Don't get me wrong, mine with it's curtrent setup flys well, great speed and vertical performance, but I love my speed and this setup doesn't give me the rush i was needing.
QDRevenger.
Old Sep 10, 2012, 02:00 PM
Angry Flyer!
jriley1974's Avatar
washington state
Joined Oct 2008
Question for glow owners,
what do you think of putting a 55ax vs 46ax? I keep hearing that the 46 out rpms the 55. I have both engines but haven't done any taching.
jriley1974 is offline Find More Posts by jriley1974
Old Sep 10, 2012, 05:48 PM
Fighting Gravity
bonnie9496's Avatar
Australia, WA, Perth
Joined Jan 2011
QDRevenger.
I was struggling to get a rush also with my initial setup, but things have improved now. This is my setup;
E-flite Power 25 1250kv, 70amp ESC, 4S 2800mah 30C & 10x10 APC
Static numbers; 1040watts@77amps.
Motor is holding up well to date.
Have added seperate CC 10A BEC for a bit of insurance
bonnie9496 is offline Find More Posts by bonnie9496
Old Sep 10, 2012, 06:02 PM
Pile-it
Alien_Tech's Avatar
United States, CA, Edwards Air Force Base
Joined Nov 2007
Good luck, please report back how it works.
Alien_Tech is offline Find More Posts by Alien_Tech
Old Sep 12, 2012, 02:19 AM
QDRevenger's Avatar
Joined Jun 2011
Had another fly this evening still with the 7.5x8APC. Fastest pass 135.5mph. Its getting faster. Will try a couple of pylon props I have here and see how they go.
Tried a carbon 7.4x7.7 prop, was slower at 128.0mph.
QDRevenger.
Old Sep 15, 2012, 11:03 PM
QDRevenger's Avatar
Joined Jun 2011
Tried something a little different today. Changed out the Hyperion HS-3026-1600kv for a Scorpion HK-3026-1400kv with a clipped down 9x9 to 8.5x9 APC prop to get a bit more prop diameter, the thrust difference was very noticable, about half the distance to take off. Quite a bit faster at 145.4mph today. Makes me want to do a 6 cell setup even more
QDRevenger.
Old Sep 16, 2012, 05:24 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Are you still running the 4S 3850mAh 65C Nano-Tech lipo's? How many amps/watts is this pulling?
GregG is offline Find More Posts by GregG
Old Sep 16, 2012, 05:48 AM
QDRevenger's Avatar
Joined Jun 2011
Yep, same packs. Not sure on amps, I'm guessing around 100-110A, 1400-1500Watts. I will put a meter on it tomorow and run it up. Motor runs cold, ESC and lipo's are just warm nothing strenuous
QDRevenger.
Old Sep 16, 2012, 08:44 PM
QDRevenger's Avatar
Joined Jun 2011
Looks like ecalc was a bit off on this one I put a meter on it this morning and ran it up static, it pulled 150A Thats one tough little motor, wierd how everything was only just warm after my flight. The load must drop off somewhat when flying, not sure how much. Possibly because i'm not flying WOT for the whole flight, just fast passes about 5 or so seconds with a slow turnaround. Anyways, I will give it a few more runs and see how it goes, was happy to leave it like this and focus on building some more dedicated go fast planes.
QDRevenger.
Old Sep 17, 2012, 12:32 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Ya that does sound a bit toasty. Good thing nothing fried.
I think that the next step would be a lower kV and more cells!
Old Sep 17, 2012, 04:44 AM
QDRevenger's Avatar
Joined Jun 2011
Im resisting the urge to go more cells. Ill have few more flights, ordered a data logger, so i can see whats going on. If it fries, it fries, no biggie. New projects becon
QDRevenger.
Article Hangar 9 Sundowner 50 ARF Electric Review dawnron1 Sport Planes 44 Apr 13, 2011 03:04 PM
Build Log Hangar 9 Sundowner Formula 1 ARF Brill 1 Giant Electric Planes 17 Apr 09, 2010 10:21 AM
Sold Relist: New Arf, Hangar 9 Sundowner Giant Scale wellcraft Aircraft - Fuel - Airplanes (FS/W) 6 Nov 27, 2008 10:13 PM
Sold Hangar 9 Sundowner new in box ARF wellcraft Aircraft - Fuel - Airplanes (FS/W) 15 Nov 24, 2008 03:36 PM
Discussion Sundowner 50 ARF Hangar 9 VENDIDO, Gracias !!! Mainland Mexico 11 Nov 20, 2008 06:21 PM
